  246 Dino LSx Replica Build (Page 4)
246 Dino LSx Replica Build by Archie
Started on: 12-28-2012 09:15 PM
Replies: 162 (24415 views)
Last post by: Lurate on 08-17-2016 09:20 AM
Archie
Total ratings: 547
Report this Post03-19-2013 04:58 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
We had the cradle Powdercoated & also had the Mounts for the bumpers powdercoated.
Final assembly of the engine/trans to the cradle
Installed Poly bushings into the cradle & installed engine/trans onto cradle.
Mounting up all the accessories.
Archie
dobey
Total ratings: 371
Report this Post03-19-2013 06:45 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Archie,
Don't see any headers on there yet. Just curious if it's getting your standard exhaust for the LSx swaps, or if this is getting a turbo or something special, as it was previously stated the engine was built based off the concept of the big twin turbo 4.8 build that was in Hot Rod.
Archie
Total ratings: 547
Report this Post03-21-2013 10:08 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by dobey:
Hey Archie,
Yes, the engine was built by a LS Turbo guy in TX & the Hot Rod magazine thing was about a Twin Turbo setup. The plan is for us to build it without the Turbo(s)we will be able to get it running for some test driving but not doing a lot of Hot Rodding. Then the car will go to San Antonio for tuning & to put together the turbo plan for it. The the owner will drive it a while while the Turbo guy gets all the parts together & schedules it back in.
We are putting the headers on it & a simple 2.5" dual exhaust system (but it won't be ceramic coated) Then they can modify the exhaust as needed to feed the Turbo(s).
I know, It needs to be lowered but (It Ain't Done Yet)
Archie
bjc 350
Report this Post04-04-2013 10:15 PM Click Here to See the Profile for bjc 350Send a Private Message to bjc 350Edit/Delete MessageReply w/QuoteDirect Link to This Post
Archie and crew, I'm having withdrawals! More progress, please.
RCR
Total ratings: 102
Report this Post04-13-2013 05:39 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
update Archie??
GODFATHER
Report this Post04-15-2013 10:36 AM Click Here to See the Profile for GODFATHERSend a Private Message to GODFATHEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Agreed what he ^^^^^^^^^^^^ said
s550w
Report this Post04-25-2013 09:46 PM Click Here to See the Profile for s550wSend a Private Message to s550wEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump!
fourpoint9
Report this Post04-29-2013 01:37 PM Click Here to See the Profile for fourpoint9Click Here to visit fourpoint9's HomePageSend a Private Message to fourpoint9Edit/Delete MessageReply w/QuoteDirect Link to This Post
looks nice in black
kitcars.com/classifieds
[This message has been edited by fourpoint9 (edited 05-01-2013).]
GODFATHER
Report this Post05-15-2013 11:06 AM Click Here to See the Profile for GODFATHERSend a Private Message to GODFATHEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Archie
Total ratings: 547
Report this Post05-17-2013 05:37 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well it's time for an update.
We've been doing quite a bit on the car lately. Including some of the conversion from an automatic car to a stick shift car & hoking up some of the shift cables, hyd. lines, throttle body, battery box, Big Brakes & the like.
Mostly we've been working the interior.
The owner has supplied us with a lit of information on how he wants the interior to look & we've been executing his plan with our own twist & ideas.
Mocking up ideas for dash.....
We like the style of the instrument pod we've seen pictures of. By scaling it we determined the gage sizes in the picture & the pod size.
From that we made a pattern.
The customer wants 5" dia. Speedo & tach. & to do that we had to increase the size of the instrument pod & made a new pattern.
Making sure the top of the pod isn't going to e too high avove the steering column.
Then, from parts in the parts bin labeled "Parts I've had long enough that I don't remember where I got them.", we pulled out this dash to begin with....
From there Kris made some flat fiberglass sheets & built the initial version of the dash pod.....& back to Mock Up.
You'll notice that when scaling the original pod size up to be able to handle 5" gages, the pod also got wider. Wider to the point where it's into the canter section of the dash & ctr. console. Not to worry, we've got a plan.
We also are going to modify a set of my inside door panels from my Interior Kit, so we fitted one of them into the car too.
More glass work to get the bottom line of the pod established where it sets on the top of the doner dashboard.
More fitting.....
We decided that we wanted the top of the pod more rounded where it sits on the top of the dash....
Kris modified that & we started on what we call the center pod. We also glassed in the speaker openings in the top of the dash & glassed in the mounting for the defroster vent. Starting to get somewhere now.....
While doing this, he's building the center pod from scratch.....
Note how we got the center pod on the center of the car by tucking it up under the end of the instrument pod.
Here you can see where we rounded up the top of the Instrument pod....
Sanded it up & made new speaker openings.... Note the oval theme.....LOL
We also are modifying the door panels but I'll show you more on that in the next post.
The customer is also considering having a Turbo (or 2) put on the car by his engine builder. He wanted us to make provisions so he could add a couple of gages to monitor the Turbo(s).
Here the fiberglass face of the center pod as holes in it to allow 2 gages that can be added later. The brushed aluminum plate that we are going to cover the pod with will not have the 2 holes for the gages. But now they can be added easily by the Turbo installer with just the correct size of hole saw.
Archie
TXOPIE
Report this Post05-17-2013 10:55 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie,
Looking Amazing as always!
Thanks for sharing.
Archie
Total ratings: 547
Report this Post06-07-2013 09:18 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update time.
We got the engine running & drove it just a little this week but you gotta read thru all this before you can see.
We started fabbing the lower dash comsole.
We are using the console from my Interior Kit (IK2) & installing a center glovebox/armrest that the customer supplied.
We have an Alumium gage face, it will be brushed Alum. finished later. We also have a similar face on the Center Pod.
We are modifying a pair of my IKS Door panels tochange the shape a bit & take the A/C vents. They will also have storage under the armrests.
We fabricated up the exhaust with 2.5" mandrel bent pipe. It's paints a high temp black.
We also installed the bigger fuel pump in the tank & the braided fuel lines.
more to come.....
Archie
Total ratings: 547
Report this Post06-07-2013 10:39 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie
Member since Dec 1999
Working on the armrests & A/C vents in the door panels.
The pocket in the arm rest.
It's fiberglass pocket is done on the back of the door panel.
The A/C vent,
Air box for vent is fiberglassed into back of door panel
Filling & sanding
On the engine, we are installing the oil temp sensor into the oil level sensor hole.
We drilled & tapped the plug for the oil temp sensor.
Wiring engine, mounting waterpump & hoses, ECM. Getting ready for 1st start.
Finished CAI.
And, here's the video http://youtu.be/lWkg-d91yO0
Archie
bjc 350
Report this Post06-08-2013 12:36 AM Click Here to See the Profile for bjc 350Send a Private Message to bjc 350Edit/Delete MessageReply w/QuoteDirect Link to This Post
Great progress. It's been worth the wait!
jb1
Report this Post06-08-2013 04:18 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Car is looking GREAT, Awesome work as always . Wouldn't expect anything but exceptional from you guys...
87 GT
(series II swap in progress)
85GT Northstar
86GT 3800 n/a
LEEEZARD
Report this Post06-08-2013 04:33 AM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
very nice work archie
couldahadaV8
Report this Post06-08-2013 02:01 PM Click Here to See the Profile for couldahadaV8Click Here to visit couldahadaV8's HomePageSend a Private Message to couldahadaV8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I suppose the customer is always right, but that instrument pod looks way too big. Very nice work on it, but it sure fills a lot of the dash.
bubbajoexxx
Total ratings: 112
Report this Post06-08-2013 03:29 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have to agree the pod intrudes into the windshield to much put the clock and fuel gauge into the center pod and drop the dash pod over the steering coloum to lower its profile
couldahadaV8
Report this Post06-09-2013 08:54 AM Click Here to See the Profile for couldahadaV8Click Here to visit couldahadaV8's HomePageSend a Private Message to couldahadaV8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like the shifter could use a little blue pill to help it out (or up)!
Archie
Total ratings: 547
Report this Post07-03-2013 01:44 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Time for another update on the Dino.
Here, we have hardwired the instrument panel. At to top, you can see 2 plugs, this will allow someone to service the gages & remove the gage panel by just unplugging the 2 plugs.
Then with notes in hand, we get inside the car & wire up the Fiero harness with the mating plugs.
Rob made some custom exterior door handles from 1" x 1.5" Alum. bar stock...
We will be rounding off the edges & polishing the handles & then getting them chrome plated.
Next time we get to door panels off, we will be making an extension of the door panel to cover the shaft od the door release.
Continuing the building of the Radio/AC control console & the forward end of the center console.
Mounting the shift boot....
Making the cover for under the steering column.....
Here we have th main dash out & are glassing to close up the spaces around the pods.
A little more work on the column cover & revising the mounting of the instrument pod cover...
Checking the fit of the dash mods...
We made a little fiberglass radius mod directly under the column....
The chrome lower boot retainer snaps right into a crrectly sized upening in the top of the console.
BV MotorSports
Total ratings: 189
Report this Post07-03-2013 01:58 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice, very nice!
TXOPIE
Report this Post07-03-2013 02:01 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking Great...Thanks for the Updates!
Love the door handles
Archie
Total ratings: 547
Report this Post07-03-2013 03:20 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys, It's looking better all the time.
We built what I call a Cell phone tray below the radio & towards the shifter. It goes up under the radio a little bit.
Glassing up both sides of the rear bulkhead cover.....
The ECM for this engine is larger than for the later LS engines, so we're building an ECM cover...
When we build something like this, we do it out of flat fiberglass sheets. We typically hot glue it together & it will initially have sharp corners.
To round off the corners (as in the pics above) we use some body filler & lay down about 1/2" of a radius of filler on the inside corners. Then after that cures, we hand lay fiberglass mat & resin over the filler radius & about 1 inch up onto each of the 2 walls. Then later when it's cured, we use a grinder on the outside of the square corner. Removing the fiberglass corner & the filler to get to the new "rounded" corner on the inside.
Ok, back to the ECM cover......
The ECM cover will fit over the ECM when mounted like this.....
But that is kind of awkward where it meets the rear of the console, so we're mounting it a little forward at the base.
We are making a couple of wings on the rear bulkhead cover so that it goes up to the inside edges for the MR@ window.
We'll continue from here next time.
Archie
Archie
Total ratings: 547
Report this Post07-13-2013 02:04 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Right now Jim can't get to his EMails, but he can get to PFF, here's an update Jim.
Continuing on the interior.
We are adding a "triangle" to the "B" pillar covers to go back into the pockets on either side of the MR2 window.
Working on finishing up the door panels.
Inside door handles & building pocket that doubles as the inside door pull.
We also built a boss on the door skin to surround the shaft of the exterior door handle & installed the new Dwe Wipes.
More work on finishing up the door handles & pockets.
And installing the lid on the armrest storage.
Inside & outside door locks....
Get well soon
Archie
Archie
Total ratings: 547
Report this Post12-01-2013 11:07 AM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Due to the passing of Jim Buell, this last August, his family wants me to sell this car for them.
They're not giving it away & it's not a Fire Sale.
Please feel free to contact me.
Archie
jb1
Report this Post05-18-2014 02:44 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
what ever happened with this car?
85GT Northstar/ 4t80e
86GT 3800 n/a---sold
Northstar Rebuild
Archie
Total ratings: 547
Report this Post05-18-2014 09:05 AM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
It has been sold to a PFF member in Florida.
Archie
PaulJK
Total ratings: 237
Report this Post05-20-2014 04:06 AM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie, Do you have a paint code or description of the blue paint used for the lambo ? I'd like to paint my car that color
[This message has been edited by PaulJK (edited 05-20-2014).]
ttt123
Report this Post05-20-2014 08:25 AM Click Here to See the Profile for ttt123Send a Private Message to ttt123Edit/Delete MessageReply w/QuoteDirect Link to This Post
wow this was a really great build. archie you really do nice work at your shop.
Lurate
Report this Post03-23-2015 08:11 PM Click Here to See the Profile for LurateClick Here to visit Lurate's HomePageSend a Private Message to LurateEdit/Delete MessageReply w/QuoteDirect Link to This Post
I ended up with this car. I couldn't stand to see all that work sit go unappreciated. I actually have that same Dino kit on a car I've had for 23 years and currently redoing it as well. Current challenge is to get a engine builder/programmer to tame that race engine. Holy Schmoly!! Whiplash. Archie smoothed out the rear quarter panel to get rid of the unusual step off there. He also did a great job getting smoothing out the fiberglass to match the side view mirrors. I'm especially happy with the MR2 rear glass instead of the Fiero glass I have on my other Dino.
Archie
Total ratings: 547
Report this Post03-23-2015 09:27 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
We want to see pictures as you go.
RCR
Total ratings: 102
Report this Post03-24-2015 05:49 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
We need pics...
Bob
Lurate
Report this Post04-11-2015 02:03 AM Click Here to See the Profile for LurateClick Here to visit Lurate's HomePageSend a Private Message to LurateEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those familiar with the Robert Carter / Norm Dino kit will know of the raised area on the rear quarter panel. Not sure what the thought was since it is not seen on any Ferrari Dino. Archie did a great job of eliminating it. Need help on how to post photos
[This message has been edited by Lurate (edited 04-11-2015).]
Neils88
Total ratings: 56
Report this Post04-11-2015 03:52 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Click on "Pennock's Image Poster"...it's the red/blue icon at the bottom of the webpage. Just follow it's directions. I use Microsoft Paint to resize images to .jpgs that are no wider than 1024 pixels, and compressed to less than 300KB.
[This message has been edited by Neils88 (edited 04-11-2015).]
Tony Kania
Total ratings: 305
Report this Post04-12-2015 11:32 AM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have always been in awe of the work coming out of Archie's shop. This by far is my favorite. Thank you for letting us know where this fine automobile ended up. Pics will always be welcome here.
Lurate
Report this Post04-12-2015 07:21 PM Click Here to See the Profile for LurateClick Here to visit Lurate's HomePageSend a Private Message to LurateEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie is incredible, no doubt. I looked at the picture posting instruction above; and, unfortunately, it is for Windows and I have only Macs. Bummed. If you don't mind sneaking over to the MadMechanics forum, I started a thread there:
http://www.madmechanics.com...o-gt.html#post210210
wftb
Report this Post04-14-2015 11:40 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a mac now too and can not use PIP anymore .I just use photoshop now , works fine .Thanks for posting the link to your build .
kwagner
Total ratings: 62
Report this Post04-15-2015 11:28 AM Click Here to See the Profile for kwagnerClick Here to visit kwagner's HomePageSend a Private Message to kwagnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking good
kevin
Report this Post04-16-2015 12:16 PM Click Here to See the Profile for kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any videos👍😋❓
Dslice
Report this Post04-17-2015 03:51 PM Click Here to See the Profile for DsliceSend a Private Message to DsliceEdit/Delete MessageReply w/QuoteDirect Link to This Post
The sheer amount the work put into these conversions is mind blowing. Awesome work, excited to see what it looks like when all done!
