  pr0j3c1 turbo 3800 71k mile guru wheelie machine (Page 4)
This topic is 13 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13
pr0j3c1 turbo 3800 71k mile guru wheelie machine by Justinbart
Started on: 01-13-2013 02:55 PM
Replies: 505 (22430 views)
Last post by: Justinbart on 02-21-2015 08:58 AM
Justinbart
Total ratings: 119
Report this Post01-19-2013 12:18 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 87antuzzi:
I know AL is better for a number of different reasons if you can hook while launching under boost but I gotta ask...Why not 2 step for some sweet ass fireballs?
You can't cut spark without cutting fuel with the 3800 pcm. You could get a stand alone ignition system. I think Jcomutt did it.
Turbo 3800 E85 F23 5spd spec5
11.17@132.6
87antuzzi
Total ratings: 228
Report this Post01-19-2013 12:25 PM Click Here to See the Profile for 87antuzziSend a Private Message to 87antuzziEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ahh,that makes sense. I wonder how well a boosted 3800 would respond to MS3 with COP?
Formula
Total ratings: 96
Report this Post01-19-2013 12:30 PM Click Here to See the Profile for FormulaSend a Private Message to FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you really wanted a 2-step, you could probably make this work instead of going stand alone:
http://www.npcompleteperformance.com/wotbox
I don't think there is anything engine specific about them (they just cut power to the ignition coils)
[This message has been edited by Formula (edited 01-19-2013).]
Justinbart
Total ratings: 119
Report this Post01-19-2013 12:46 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Something like that would be nice on my car....hmmm
11.17@132.6
darkhorizon
Total ratings: 451
Report this Post01-19-2013 12:47 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not that easy. Unfortunately spark is fuel and fuel is spark.... the only possible way to cut the coils off is to run a spacer under the coil packs that you can intercept the signal with.
A standalone with a KILLER spark pickup could gain a significant amount of power over 6000rpms assuming you have the heads for it as timing drift is really bad with 3800s.
Formula
Total ratings: 96
Report this Post01-19-2013 12:58 PM Click Here to See the Profile for FormulaSend a Private Message to FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Forgot about the icm. It probably wouldn't like being turned on and off rapidly.
34blazer660
Report this Post01-19-2013 03:59 PM Click Here to See the Profile for 34blazer660Send a Private Message to 34blazer660Edit/Delete MessageReply w/QuoteDirect Link to This Post
LFiero67
Report this Post01-19-2013 05:59 PM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm running the bailey two step on mine. I had some issues getting it to work with the series two ignition and had to send it back to Bob to add a opto-isolator. Not sure if it was an issue with my car or the box, but it didn't work right when i first got it. You have to use mds coil spacers to allow the power to be cut from the coils without turning off the ignition module. I haven't talked about it much due to the issues I had. Don't want to recommend something that might not work. Bob was awesome and got me squared away eventually. He also has a ignition module that allows coil near plug like LS engines and incorporates the two step. That would be awesome for high rpm use, if it would work with our crank sensors and PCM.
Tweeder
Report this Post01-19-2013 07:09 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is this anti-lag that you speak of?
86 GT Convertable 3800
darkhorizon
Total ratings: 451
Report this Post01-20-2013 03:36 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well...
anti-lag is magic....
Originally posted by mattwa:
anti-lag is the shizz-nit
Justinbart
Total ratings: 119
Report this Post01-20-2013 10:43 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
11.17@132.6
Tweeder
Report this Post01-20-2013 12:48 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]Originally posted by mattwa:
[/QUOTE]
I googled it and all I could find for a system is a mixture of nitrous and methanol. Then something about something with controlling spark and timing to act like a stalled converter to allow the vehicle to be in boost before take off.
Formula
Total ratings: 96
Report this Post01-20-2013 12:51 PM Click Here to See the Profile for FormulaSend a Private Message to FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://en.wikipedia.org/wik...m#Retarding_ignition
I prefer thinking its magic though...
Tweeder
Report this Post01-20-2013 04:48 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
I read that article but I'm more of a visual person. What and how are y'all using to achieve this?
Justinbart
Total ratings: 119
Report this Post01-20-2013 05:27 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is a micro switch on the shifter. When you click it the timing retards.
11.17@132.6
Tweeder
Report this Post01-20-2013 06:06 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guesS its connected to an additional ignition controller? which one is preferred? If that's the case it's more like a launch control than an ALS. Which I read is quite hard on the system.
[This message has been edited by Tweeder (edited 01-20-2013).]
Justinbart
Total ratings: 119
Report this Post01-20-2013 06:12 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
You'll have to PM darkhorizon. It's all in the pcm tune.
11.17@132.6
Tweeder
Report this Post01-20-2013 06:28 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
K thanks
mattwa
Total ratings: 88
Report this Post01-20-2013 07:19 PM Click Here to See the Profile for mattwaSend a Private Message to mattwaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Quote from DH in a previous thread. But -49 degrees? Justin said (and showed) -14 is too much already.
...Antilag is easy. Just toss a switch inline with the air temp sensor so that it unplugs when you press a switch (the safer way is to have it "plug in" when you hit the switch, but you cant watch IATs). When it plugs or unplugs, command -49 degrees of timing in the air temp spark table... Just dont press the button without your foot on the pedal at least 30%. The switch has to be manhandled at all times so I mounted mine on my shifter.. press to lag, release to go, so I could use it in any gear, any speed... You could wire it to your brake switch as well if you wanted to make launching it a bit less reliant on your skill to pop your finger off the button when you lift the brakes.
ericjon262
Total ratings: 67
Report this Post01-20-2013 07:40 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
that's pretty clever.
nosrac
Total ratings: 51
Report this Post01-20-2013 07:47 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]
s of timing in the air temp spark table... Just dont press the button without :your foot on the pedal at least 30%. The switch has to be manhandled at all times so I mounted mine on my shifter.. press to lag, release to go, so I could use it in any gear, any speed... You could wire it to your brake switch as well if you wanted to make launching it a bit less reliant on your skill to pop your finger off the button when you lift the brakes.
It is conflicting information like this which makes me uneasy about
the best way how to implement without destroying my engine or turbo.
[This message has been edited by nosrac (edited 01-20-2013).]
darkhorizon
Total ratings: 451
Report this Post01-20-2013 08:08 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
butsigh... you guys just dont read. I said COMMAND -49 degrees, which just removes all of the commanded advance and the actual timing is just going to be whatever you set your min timing to.
darkhorizon
Total ratings: 451
Report this Post01-20-2013 08:39 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
darkhorizon
Member since Jan 2006
-14 wasnt too much, it is just that -6 was proper for this setup.
mattwa
Total ratings: 88
Report this Post01-20-2013 09:04 PM Click Here to See the Profile for mattwaSend a Private Message to mattwaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool, good to know when I build mine.
nosrac
Total ratings: 51
Report this Post01-20-2013 09:29 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, i hear ya but it's still a little confusing for us noobs.
I know how to remove the advance using the air temp table but I was thinking more like -20 * actual an NOT -6*.
Jncomutt
Total ratings: 221
Report this Post01-21-2013 09:52 AM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
I run an AEM system on mine, and I've ditched the 3800 coil packs for 6 individual LS style coils and little short vette plug wires.
rcp builders
Report this Post01-21-2013 07:38 PM Click Here to See the Profile for rcp buildersSend a Private Message to rcp buildersEdit/Delete MessageReply w/QuoteDirect Link to This Post
1. What size cross-over do the 3800's use, 2 1/2"?
2. Would there be a difference in how the turbo spooled or responded in any way if the exhaust feeds were the same lenght?
3. I see alot of the turboed V8's on the other sites with singles, always try to have even feeds to the turbo, is that for looks only?
Thanks Ray
Justinbart
Total ratings: 119
Report this Post01-21-2013 07:49 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Idk. This goes against every turbo book out there.
11.17@132.6
mattwa
Total ratings: 88
Report this Post01-21-2013 09:14 PM Click Here to See the Profile for mattwaSend a Private Message to mattwaEdit/Delete MessageReply w/QuoteDirect Link to This Post
My thoughts are that, once under boost, the entire exhaust system before the turbo is under the same pressure regardless of length.
KurtAKX
Total ratings: 128
Report this Post01-22-2013 03:32 PM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
...timing drift is really bad with 3800s.
Try living with a distributor!
revin
Total ratings: 234
Report this Post01-23-2013 09:38 AM Click Here to See the Profile for revinSend a Private Message to revinEdit/Delete MessageReply w/QuoteDirect Link to This Post
4 pages and NO WHEELIES?!?!??!?!?!?!
slackers
Justinbart
Total ratings: 119
Report this Post01-23-2013 10:15 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
slackers
I think we got the wrong drag radials. When it gets warmer out i'm going to have to do a massive burn out just to give it a chance. Ain't nobody got time fo dat.
I need to find out what superchargedV6 used for tires.
Originally posted by SuperchargedV6:
Normal was about 6 inches high but once I got it to go over a foot and bounce pretty good on the let down. I miss that 3800 SC. Rick B
11.17@132.6
[This message has been edited by Justinbart (edited 01-23-2013).]
Formula
Total ratings: 96
Report this Post01-23-2013 10:59 AM Click Here to See the Profile for FormulaSend a Private Message to FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by RumbleB:
The tires that were on that car were pretty much like a drag tire to begin with. They were a BF Goodrich tire that really stuck to the pavement. This is how Rick's car was able to pop a wheelie.
bfgoodrich ftw! Looking at the pictures they look like they are all seasons too
revin
Total ratings: 234
Report this Post01-23-2013 01:44 PM Click Here to See the Profile for revinSend a Private Message to revinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like over inflated front tires ( ie. bounce)
KurtAKX
Total ratings: 128
Report this Post01-24-2013 09:56 PM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
Something about "a guy followed me down the street to tell me I was wheeling" definitely sounds over-inflated.
Justinbart
Total ratings: 119
Report this Post01-31-2013 05:33 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
From my phone with the torque app, I wouldn't trust this too much. I spun in first pretty good. Not bad for 15psi and a little rich, high 10's afr. I did another run but I must have let off too soon because the numbers were all wrong.
11.17@132.6
[This message has been edited by Justinbart (edited 01-31-2013).]
Formula
Total ratings: 96
Report this Post02-01-2013 07:06 AM Click Here to See the Profile for FormulaSend a Private Message to FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you get the bluetooth adapter for torque?
Justinbart
Total ratings: 119
Report this Post02-01-2013 08:16 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes.
11.17@132.6
darkhorizon
Total ratings: 451
Report this Post02-01-2013 09:38 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
350hp is weak
Justinbart
Total ratings: 119
Report this Post02-01-2013 10:50 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
350hp is weak
lol, yea. It said 390 on another run but I let off before the 1/8th and it said 0-60 in 10 seconds.
11.17@132.6
