  Fiero Pumpkin Carving - with template!
Fiero Pumpkin Carving - with template! by Silicoan86
Started on: 10-28-2013 04:40 PM
Replies: 14 (1286 views)
Last post by: virtuetovice on 10-14-2014 09:17 PM
Silicoan86
Report this Post10-28-2013 04:40 PM Click Here to See the Profile for Silicoan86Send a Private Message to Silicoan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rather than carving yet another standard pumpkin from a generic set of templates this year, I decided to make my own Fiero jack-o'-lantern. I created my own template by making some minor adjustments to the Pegasus badge. Here's the finished result:
I figured I'd post this here in case anyone else wanted to use the template that I made to make their own. Just print it out, tape it to your pumpkin, and poke holes around the pattern just like any other pumpkin pattern. When you get to carving, start with the center parts - head, then legs, and move outward. I saved the badge outline for last, you could go without the outline as well if desired.
NEVERDONE
Report this Post10-28-2013 05:20 PM Click Here to See the Profile for NEVERDONESend a Private Message to NEVERDONEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Man that is flippin sweet! I don't do carvings but I may try that one!
rbell2915
Report this Post10-28-2013 05:25 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
That is seriously cool, I love it.
FIEROPHREK
Total ratings: 137
Report this Post10-28-2013 07:15 PM Click Here to See the Profile for FIEROPHREKSend a Private Message to FIEROPHREKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very Cool! Looks like the back of my helmet!
12.3 is faster than a 13.2
IMSA GT
Total ratings: 250
Report this Post10-28-2013 07:34 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
One of the things that you can try if you don't feel comfortable cutting all of the holes is to trace the design, cut only the skin, and remove only the skin of the design leaving the actual pumpkin "pulp" alone. Then shave down the inside walls of the pumpkin to make the front wall thinner. The light will shine through the pumpkin "pulp" but the skin that you did not remove will block out the light creating dark areas.
Like this:
Silicoan86
Report this Post10-28-2013 08:23 PM Click Here to See the Profile for Silicoan86Send a Private Message to Silicoan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's a great way to do it as well IMSA GT. I almost did that for the badge outline so that I could keep it as one continuous line.
Awesome helmet!
TheDigitalAlchemist
Total ratings: 94
Report this Post10-28-2013 08:25 PM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome job, man!
Khw
Total ratings: 134
Report this Post10-28-2013 11:09 PM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is pretty kewl. We skipped "carving" this year. I have 4 black lights lighting up our porch, sso instead of carving, we drew what we wanted on the pumpkins and then I painted the designs in with glow in the dark paint. My daughter wanted Applejack, a My Little Pony. My wife wante a Franken Goofy (Disney Goofy). I just did a scary face, my son wanted a smiley facr and my other daughter wanted a cat. I've got 2 more to finish tomorrow night, one a haunted house scene and the other I haven't completely decided yet. I was thinking science beekers, and cutting out the tops of them as this will be the only hollowed out and carved pumpkin we do this year. It will be filled with water and dry ice (it's a rather large pumpkin, 30+ lbs).
[This message has been edited by Khw (edited 10-28-2013).]
gen2muchwork
Report this Post10-30-2013 06:04 AM Click Here to See the Profile for gen2muchworkSend a Private Message to gen2muchworkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for posting that. I had fun!
I should have used a larger pumpkin, I had to print as 5x7 and the detail was tight, but it looks cool!
Also, I've never carved a white pumpkin before and it's awfully hard to see my transfer.
Report this Post10-30-2013 12:14 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nice job
Silicoan86
Report this Post10-30-2013 09:18 PM Click Here to See the Profile for Silicoan86Send a Private Message to Silicoan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Looks great! It definitely helps to have a good sized pumpkin to begin with, but it looks like yours turned out great anyway!
Silicoan86
Report this Post10-14-2014 12:12 PM Click Here to See the Profile for Silicoan86Send a Private Message to Silicoan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's that time of year again! I'm thinking about doing another one of these, but possibly switching up the design a bit this year.
gen2muchwork
Report this Post10-14-2014 01:34 PM Click Here to See the Profile for gen2muchworkSend a Private Message to gen2muchworkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was just thinking about that pumpkin. Good luck with your new design! it was a hit on my block last year. Thanks again!
Silicoan86
Report this Post10-14-2014 08:06 PM Click Here to See the Profile for Silicoan86Send a Private Message to Silicoan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome! Last year I did mine a few days before Halloween and tried to preserve it using various methods that I found online. Unfortunately, none of them worked and by the time Halloween rolled around it was pretty much unrecognizable. This year I'll have the design ready in advance, but I'm not going to carve it until the 31st.
virtuetovice
Report this Post10-14-2014 09:17 PM Click Here to See the Profile for virtuetoviceSend a Private Message to virtuetoviceEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not gonna lie I LOL'd but only because it's AWESOME. Nice carving.
