  Where did I screw up on this throttle body selection?
Where did I screw up on this throttle body selection? by Sir Ken
Started on: 04-07-2018 01:29 PM
Replies: 7 (547 views)
Last post by: Sir Ken on 04-10-2018 02:06 PM
Sir Ken
Report this Post04-07-2018 01:29 PM Click Here to See the Profile for Sir KenSend a Private Message to Sir KenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Throttle body supposedly came off a 2003 Cadillac Northstar 4.6.
I'm trying to get all my parts lined up for my 3800SC Series III swap and thought I needed a 2000-2005 Northstar throttle body and a L36 gen 5 adapter plate which is what I thought I had purchased. None of the holes in the parts fit together or line up.
Adapter plate from ZZP is the "Gen 5 to L67/L36 Throttle Body Adapter Plate"
They do not line up with each other in any way, shape, or form.
Where did I mess up?
IMSA GT
Total ratings: 253
Report this Post04-07-2018 09:53 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
It appears this is the adapter you need for that throttle body but I'm not 100% sure:
https://zzperformance.com/3...r-adapter-plate.html
[This message has been edited by IMSA GT (edited 04-07-2018).]
Sir Ken
Report this Post04-07-2018 11:05 PM Click Here to See the Profile for Sir KenSend a Private Message to Sir KenEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think you're correct. Already ordered and requested a RMA to return the first one.
Thanks too.
Total ratings: 206
Report this Post04-08-2018 10:06 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yuppers, wrong adapter.
Are you using an LQ4 MAF?
Sir Ken
Report this Post04-09-2018 10:41 PM Click Here to See the Profile for Sir KenSend a Private Message to Sir KenEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm still shopping for parts but it looks like ZZP has everything I need.
How do you attach the LQ4 to the N-star throttle body?
Total ratings: 206
Report this Post04-09-2018 11:30 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Short section of ducting.
Available from Jegs, Summit, AutoZone....
Grantman
Report this Post04-10-2018 08:21 AM Click Here to See the Profile for GrantmanSend a Private Message to GrantmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
you can sorta see the tube I used. It's one with a 45 degree angle because I've got an intercooler which is also why I had to notch the lid. the tube connects to the LQ4 which in turn is connected to one of those corrugated tubes from ZZP that connects to the cone air filter.
[This message has been edited by Grantman (edited 04-10-2018).]
Sir Ken
Report this Post04-10-2018 02:06 PM Click Here to See the Profile for Sir KenSend a Private Message to Sir KenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the info... just waiting my turn for a plug-n-play harness and pcm to be completed.
Engine trans alternator mounts, fuel pump, and of course Series III in hand.
Axles have been sourced through S. Poe... just need to rob another bank to finish my purchases.
