  Other Cars
  94 Suburban Service Engine Soon
94 Suburban Service Engine Soon by Phirewire
Started on: 01-09-2013 12:38 AM
Replies: 12 (443 views)
Last post by: 1988holleyformula on 01-10-2013 05:52 PM
Phirewire
Report this Post01-09-2013 12:38 AM Click Here to See the Profile for PhirewireSend a Private Message to PhirewireEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just traded for a suburban but the service engine soon light keeps coming on and off, I don't really feel any change in engine or sound when its on. Any ideas?
Monkeyman
Total ratings: 182
Report this Post01-09-2013 05:01 AM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could be a million things, mostly emissions related. I've had a check engine light on on my Blazer for 18 months. I know what the diagnostic deal says it is, it's not hurting my gas mileage or drivability so I haven't messed with it. Most Autozones (maybe other car parts stores) should have the OBD II reader they'll use (for free) to tell you what the code is.
jaskispyder
Total ratings: 205
Report this Post01-09-2013 08:14 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup, stop in to an auto parts store and have them read the code.
86soon3.4
Report this Post01-09-2013 10:25 AM Click Here to See the Profile for 86soon3.4Send a Private Message to 86soon3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
94 uses OBD I.
Steve
jaskispyder
Total ratings: 205
Report this Post01-09-2013 11:50 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
easier...
"To pull that code you need to jump the diagnostic port. Take a wire or paper clip or something like that and use it to connect the 2 holes on the top right of the port. Turn the key to the "on" position (but don't start it) and the Check Engine light will flash to indicate numbers. It'll start out with code 12 which will show up as "flash" pause "flash flash". It'll do that a total of 3 times. After that it'll give you the code (or codes if there's more than one). It'll flash the number of times corresponding with the first digit, then a pause, then it'll flash the number of times corresponding with the second digit. Each code will be flashed a total of three times. All OBDI trouble codes are two digits. Once it's given you all the codes it'll flash code 12 three more times to let you know it's done. "
[This message has been edited by jaskispyder (edited 01-09-2013).]
1988holleyformula
Total ratings: 68
Report this Post01-09-2013 01:52 PM Click Here to See the Profile for 1988holleyformulaSend a Private Message to 1988holleyformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
My money is on o2 sensor. I always had that code popping up randomly in both my 94 and later in my 97 Suburbans. Never really affected drivability, so I never took the time or money to replace it.
weaselbeak
Total ratings: 76
Report this Post01-09-2013 02:56 PM Click Here to See the Profile for weaselbeakSend a Private Message to weaselbeakEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 97 has seen this light off & on for 10 years. If it's full of oil and water, runs good and the mileage is there, I tend to not worry about it. Mines over 230,000K and doing fine. I found out years ago that I could spend a fortune chasing those little emissions codes around. I knew a Catholic nun music teacher who's brand new Taurus always popped up that service engine crap. After 5-6 times she said to heck with it. It never gave her any grief.
[This message has been edited by weaselbeak (edited 01-09-2013).]
jaskispyder
Total ratings: 205
Report this Post01-09-2013 04:03 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
The only time I would be worried is if it is the O2 sensor and you have a cat. converter. Otherwise, if it is an EVAP code..... ignore
Phirewire
Report this Post01-09-2013 08:37 PM Click Here to See the Profile for PhirewireSend a Private Message to PhirewireEdit/Delete MessageReply w/QuoteDirect Link to This Post
Alright, anyone have a list of info on the codes? So when i check similar to what the fiero list is?
Also Does cutting the cat off improve fuel efficiency?
jaskispyder
Total ratings: 205
Report this Post01-09-2013 09:24 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a chiltons. What is the code?
Phirewire
Report this Post01-10-2013 03:34 PM Click Here to See the Profile for PhirewireSend a Private Message to PhirewireEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is as followed:
This is what it did:
(Flash pause flash flash) Code 12
1 flash, pause 3 flash. (Flash pause flash flash flash)
3 flashes, pause 5 flashes. (Flash flash flash pause flash flash flash flash flash)
4 flashes, pause 3 flashes. (flash flash flash flash pause flash flash flash)
If someone could tell me what code that is and What it stands for that would be awesome
jaskispyder
Total ratings: 205
Report this Post01-10-2013 05:00 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Phirewire:
It is as followed:
13. Oxygen sensor
35. Idle air control.
43. ESC - electronic spark control. Knock sensor not sending signal to ESC.
1988holleyformula
Total ratings: 68
Report this Post01-10-2013 05:52 PM Click Here to See the Profile for 1988holleyformulaSend a Private Message to 1988holleyformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by jaskispyder:
13. Oxygen sensor
