  Removing the headlight control module and wiring.
Removing the headlight control module and wiring. by Rsvl-Rider
Started on: 07-12-2014 08:28 PM
Replies: 3 (246 views)
Last post by: Rsvl-Rider on 07-14-2014 11:37 AM
Rsvl-Rider
Report this Post07-12-2014 08:28 PM Click Here to See the Profile for Rsvl-RiderSend a Private Message to Rsvl-RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I understand that the 88 employs an upgraded (Gen 2) headlight setup that is sought after for previous year upgrades. I considered removing a wiring harness and module from an 88 coupe today but it looks like a PIA job. Is there a particular way to do this? It looks like one end has to be routed back between the nose assembly and the radiator? Can someone recommend the correct way to do this? Doesn't seem practical from above. Maybe from below somehow? Anyway, I may or may not bother depending on the time and complexity - although the module itself is fairly easy to remove.
If anyone has any interest in the harness and/or the module let me know.
John Wayne as John Bernard Books in The Shootist.
I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them.
My rides...
1988 GT with a 3.4L V6 automatic
2006 Harley Sportster
'cause I love the twisties on two wheels or four.
Total ratings: 154
Report this Post07-12-2014 10:12 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
One guy I know said he pulled each wire through the slit in the harness cover and extracted one or several wires at a time, then pulled the harness cover out. A friend and I removed the hood and managed to pull the complete harness up and between the nose and front assembly.
Spoon
Total ratings: 61
Report this Post07-13-2014 10:26 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 1st 88 harness I pulled was a challenge. I ended up cutting the harness to get it out. The next two I pulled by removing the hood,, then loosening the upper radiator support and leaning the radiator towards the windshield by a couple inches. Turned out to be a 20 minute job with no cuts.
Spoon
Rsvl-Rider
Report this Post07-14-2014 11:37 AM Click Here to See the Profile for Rsvl-RiderSend a Private Message to Rsvl-RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK, thanks for the help guys. I might give it a try.
