Appreciate PFF? Please consider making a donation.
Pennock's Fiero Forum has been the largest source for Fiero related information during the past 23 years and it has always been free for everyone - members, vendors and visitors. However, it isn't free for me to maintain. If you want to help me keep PFF up and running, please consider a donation. Your support will be greatly appreciated. Not only by me, but by the thousands of daily visitors that use PFF. If you want to make a donation (PayPal, Bitcoin, Ethereum, etc.) please (or simply send your PayPal donation to info@pennock.nl).
Thanks!
Cliff Pennock
  How I repaired my EGR Solenoid and eliminated my Code 32
How I repaired my EGR Solenoid and eliminated my Code 32 by Timpilot
Started on: 05-02-2012 09:09 PM
Replies: 15 (6762 views)
Last post by: Vintage-Nut on 11-11-2023 09:22 PM
Timpilot
Report this Post05-02-2012 09:09 PM Click Here to See the Profile for TimpilotClick Here to visit Timpilot's HomePageSend a Private Message to TimpilotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have been driving my '88 Formula with 58,000 miles for a year now and getting a Code 32 every day.
Finally got tired of that Service Engine Soon (SES) light and pulled the EGR solenoid off and apart.
After repair documented below, I have been SES-free for 2 weeks now.
First checked the two terminals closest to the mounting bracket and got "infinity" Ohms - an open coil.
Then did initial disassembly. Everything looking pretty good, right?
Then this mess
Noticed the broken (corroded off) magnet wire right away
Cleaned up the corrosion with "The Must for Rust" from Home Depot.
Stripped the magnet wire with 1000-grit sandpaper, cut back and stripped insulated leadwire.
Soldered magnet wire to leadwire.
Ohms-checked several times along the way and always got 96.4 Ohms.
Stuffed soldered connection into recess and encapsulated/waterproofed with Plumber's Goop.
Wrapped coil with heavy-duty package tape - one wrap.
Put everything back together and sealed the tube and the rubber cover with Goop to prevent moisture entry.
Hope this helps/encourages someone else to repair his or her EGR Solenoid.
[This message has been edited by Timpilot (edited 08-20-2013).]
Report this Post05-02-2012 09:55 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice post....thank you
BuddyCraigg (guru of code 32) will be pleased....
85 SE VIN 9
Report this Post06-14-2012 03:48 AM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good to know! That's a three figure part, well worth a little work to fix!
Bloozberry
Total ratings: 311
Report this Post06-14-2012 06:34 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great write up, awesome pictures. Thanks for taking the time to post this info. A "+" for you!
Timpilot
Report this Post06-14-2012 09:25 AM Click Here to See the Profile for TimpilotClick Here to visit Timpilot's HomePageSend a Private Message to TimpilotEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's been over 7 weeks now and still no SES light.
Timpilot
Report this Post02-24-2013 08:06 PM Click Here to See the Profile for TimpilotClick Here to visit Timpilot's HomePageSend a Private Message to TimpilotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Almost 10 months since EGR Solenoid magnet wire repair and solenoid is still good.
TK
Total ratings: 200
Report this Post02-24-2013 10:27 PM Click Here to See the Profile for TKSend a Private Message to TKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good job! There isn't much to them so they are easy to repair or make a good one out of parts.
Timpilot
Report this Post05-14-2013 11:50 PM Click Here to See the Profile for TimpilotClick Here to visit Timpilot's HomePageSend a Private Message to TimpilotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Over a year now (and 7,000 miles later) and still Code 32-free.
[This message has been edited by Timpilot (edited 05-14-2013).]
VF1Skullangel
Report this Post08-20-2013 02:34 PM Click Here to See the Profile for VF1SkullangelClick Here to visit VF1Skullangel's HomePageSend a Private Message to VF1SkullangelEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just got a 32 code this morning. Lots of folks from Facebook pointed me in the direction of this thread. Can't wait to tear into my solenoid and do this on my days off.
Total ratings: 291
Report this Post08-20-2013 03:29 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Timpilot:
...First checked the two terminals closest to the mounting bracket and got "0" Ohms - an open coil....
Zero ohms would be a direct short. I think he meant to say infinite ohms.
[This message has been edited by phonedawgz (edited 08-20-2013).]
Timpilot
Report this Post08-20-2013 04:26 PM Click Here to See the Profile for TimpilotClick Here to visit Timpilot's HomePageSend a Private Message to TimpilotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good catch phonedawgz. You are absolutely correct.
Boostdreamer
Total ratings: 98
Report this Post07-05-2014 11:59 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
My EGR solenoid Code 32 has come back to visit a few times. It has not been consistant in any way. It always happened during a long drive but the next time I would start it up, the light would be out.
I decided that it might be caused by a slight vacuum leak in the unit. Maybe temperatures or humidity or vibration would trigger the code. I got a brilliant idea to fix any slight leaks, I PLASTI-DIPPED the solenoid! I used the spray-on kind instead of the actual dip. Got a nice thick coat all over the little jumper hoses and into all the cracks, nooks, and crannies.
I have driven about 400 miles since then and so far, the code has not come back. It is a cheap fix that is worth a try!
Total ratings: 465
Report this Post09-21-2015 01:31 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I missed this thread originally. Thanks for a very helpful how-to!
neek
Report this Post11-11-2023 07:47 PM Click Here to See the Profile for neekSend a Private Message to neekEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are these pictures from the original post still available anywhere? They show up as missing images now (> 10 years after the original post). I just bought an '88 Fiero and I think my solenoid is bad.
thanks
Total ratings: 465
Report this Post11-11-2023 08:55 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
For all intents and purposes... no.
There have been much more recent threads with EGR solenoid solutions.
[This message has been edited by Patrick (edited 11-11-2023).]
Vintage-Nut
Report this Post11-11-2023 09:22 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
See as the "Why"
"Has anyone heard from isthiswhereiputausername recently? by Cliff Pennock" 07-08-2023
https://www.fiero.nl/forum/Forum1/HTML/100475.html
"All my old PIP images show broken link symbol by seajai" 09-26-2023
https://www.fiero.nl/forum/Forum1/HTML/100535.html
And I think that Patrick means to say "search EGR Solenoid solutions" like:
"EGR Solenoid Easy Economical Replacement by Dennis LaGrua" 07-11-2021
https://www.fiero.nl/forum/Forum2/HTML/145280.html
