  PCV Valve Update/Upgrade
PCV Valve Update/Upgrade by RWDPLZ
Started on: 06-12-2012 05:48 PM
Replies: 3 (1452 views)
Last post by: Indypacecars on 05-28-2014 11:16 AM
RWDPLZ
Total ratings: 305
Report this Post06-12-2012 05:48 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
A lot of stores now don't list a PCV valve for the 84 Fiero, but list one for the 86. I decided to upgrade mine to the 88 style, to make it simpler and easier to find the parts for in the future. It also cleans up the look of it quite nicely.
84 original layout:
88:
Parts:
2 X PCV valve elbows, HELP! part # 47038
1 ft length of 5/16" brake line
88 duke PCV valve, AC Delco part # 25095452
Simply put one elbow on the PCV port on the TBI, and the other on the valve. Cut one end off the brake line, slide the fittings off, and deburr the end. Stick the barbed end into the elbow with the PCV, and bend the line to fit down to the one on the TBI. Slide the end into the TBI-side elbow, and insert the PCV into the valve cover grommet, and it's done!
I think I'll take it back off and bend it a little more, and paint it black.
1984 Fiero SE
Report this Post06-12-2012 08:46 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice job.
Ang84Indy
Report this Post06-12-2012 10:13 PM Click Here to See the Profile for Ang84IndySend a Private Message to Ang84IndyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good idea, thanks for posting!
Indypacecars
Report this Post05-28-2014 11:16 AM Click Here to See the Profile for IndypacecarsClick Here to visit Indypacecars's HomePageSend a Private Message to IndypacecarsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is this an easier solution than using the parts listed for the '85? Because those seem to be available. In that case, the PCV would go in the same location and use the same hose, right? I did find that the PCV itself for the '85 is a different part number from the '84, probably to fit in the elbow.
