  3800sc swap in California means EVAP et al...HELP!
3800sc swap in California means EVAP et al...HELP! by lesterpablo
Started on: 10-10-2012 03:05 PM
Replies: 6 (711 views)
Last post by: RCR on 11-28-2013 09:42 AM
lesterpablo
Report this Post10-10-2012 03:05 PM Click Here to See the Profile for lesterpabloSend a Private Message to lesterpabloEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm a greenhorn on this forum so please be kind. I tried to search the topic in previous threads but none were completely on point. My issue is in order to swap in a 3800sc from a 1998 Buick Regal in Cali (from what I understand) I'll need to also use the donor car's gas tank sender and gas tank pressure sensor plus the entire EVAP system. Has anyone ever had to install a pressure sensor on a fiero gas tank before? ...and no, moving out of Cali is not an option.
Total ratings: 291
Report this Post10-10-2012 03:59 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Doesn't the entire sender/pump unit for the 3800 tank fit in the Fiero tank hole?
You also have to run the fuel level sender through the PCM.
You have to use both the evap purge and evap vent solenoids.
PM sent
[This message has been edited by phonedawgz (edited 10-10-2012).]
lesterpablo
Report this Post10-10-2012 04:09 PM Click Here to See the Profile for lesterpabloSend a Private Message to lesterpabloEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
I haven't had my hands on a 3800 sending unit and was unfamiliar with gas tank pressure sensors. That makes perfect sense that it's part of the sending unit! Thanks, and Yes, I was told the sending unit will go straight into the fiero tank as almost all GM tanks are pretty much the same.
NorCalFiero
Report this Post11-26-2013 01:28 PM Click Here to See the Profile for NorCalFieroSend a Private Message to NorCalFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I also thought the fuel pump along with the pressure sensor would fit. Turns out that the 3800 fuel pump is too large to fit the fiero tank. I ended up using a fuel pump from an 88 corvette and running the pressure sensor in line. Works and I passed California BAR about a month ago.
FIEROFLYER
Total ratings: 180
Report this Post11-26-2013 08:16 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Mount the fuel tank pressure sensor in the fuel filler steel tube just below the gas cap this area is accessible with the wheel well removed and keeps from drilling a hole in your fuel tank. Some of the early to mid 90's cars also had a round charcoal canister with the needed EVAP solenoid right on it that are just a little larger then the Fiero canister so it will fit in the stock spot then that just leaves the solenoid on the engine.
This is what I have done in the past for California customers when making kits and they had no problems with it. Dan
DARN Cars now open with
MstangsBware
Total ratings: 459
Report this Post11-26-2013 10:43 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 3800 swap I did for a guy in Cali did not use the donor sendor..I used the Fiero sender...
RCR
Total ratings: 102
Report this Post11-28-2013 09:42 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Check Rick's thread for lots of info on a California swap...
https://www.fiero.nl/forum/Forum3/HTML/000114.html
Bob
PS, Welcome to the madness.
[This message has been edited by RCR (edited 11-28-2013).]
