To add: this does work well,
things to think about, if you use heat around the bushing shell, blow out the cradle with compressed air to remove any leaves and twigs that may catch fire, I don't know if it would work with out heat, unless they are trashed, (have a fire extinguisher close just in case, it is a Fiero after all) Make sure the collar you use fits on the sleeve of the bushing or the whole thing will pop out, (found this out) A harmonic balancer washer works great for the washer, yes it can be done without removing the whole cradle, proving you have poly or something to easily put back it, it does require suspending the engine. I used a wire wheel on a drill to remove any rubber left.
If you pull the cradle you may as weld in solid mounts as it can be done for under $10 (did I ever post that 'how to' I forget)
BTW you got a + from me for this.
I did this on a nice Indy today.
"DRIVE IT LIKE A FIERO"
'87 Quad 4 H.O.
