Several years ago I bought a serial ALDL cable from Dodgerunner and it worked fine on my old Dell laptop (1 GHz, 512 MB) running XP Pro SP3. I misplaced the cable (getting old and forgetful), so a friend of mine gave me a USB ALDL cable he doesn't use which is the same style as what
Madscanner has.
Do you think I can get this thing to work... not a chance!
I'm trying to get some readings from my '88 Formula. I understand the jumpers on the cable. Doesn't matter where I put them. When using WinALDL, the communication box never turns green. It's always red with number 1 or 2 being displayed. ECM chosen is 1227170. I've tried using Com3 and Com4 for the cable and the Bits per second has been set to 2400. There are a few lines of gibberish that show up under RAW Data, but nothing at all happens in the Sensor Data section.
| quote | Originally posted by phonedawgz:
There is a problem with some FT232RL chips and the latest drivers.
Download my install disk at the bottom of this page and unzip it. - http://reddevilriver.com/aldl.html - it is the yellow box at the bottom. Also I just updated the file now so if you downloaded it earlier and you are not seeing the headings I reference here, they may not be on this morning's copy.
Unzip it and click AutoRun.exe or just AutoRun. A menu will pop up. Go to Overview - and under "Troubleshooting" look for "If you suspect the incompatible drivers were installed"
Follow the instructions there.
To determine if your drivers are working correctly follow the procedure marked "Testing the cable"
My drivers and install disk will work with my competitors cable you already have.
Phonedawgz, I downloaded your install disk and unzipped it. When I click on "Read First - Overview & Troubleshooting", a whole lot of HTML looking stuff opens up in Notebook. I suspect that's where I'd find "If you suspect the incompatible drivers were installed" and/or "Testing the cable". How can I access this properly so I can read and hopefully follow it?
EDIT: Okay, the solution to the "HTML looking stuff" was to open it up on my desktop computer. I'll follow the steps mentioned on my laptop, and see what happens. When I return, I'll either be thanking phonedawgz profusely, or asking a bunch more questions.
[This message has been edited by Patrick (edited 05-19-2014).]
