  1988 Front Upper Ball Joint Taper
1988 Front Upper Ball Joint Taper by Steven Snyder
Started on: 02-11-2014 05:58 PM
Replies: 7 (957 views)
Last post by: Steven Snyder on 03-11-2014 08:58 PM
Steven Snyder
Total ratings: 106
Report this Post02-11-2014 05:58 PM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
What's the taper angle on the 88 front upper ball joint?
Total ratings: 237
Report this Post02-11-2014 07:32 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe I have some upper control arms at my dad's house. While I'm there over the weekend I'll see if I can take some measurements.
Total ratings: 259
Report this Post02-11-2014 08:01 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gotta thank Bloozberry again for these drawings!
It doesn't specify the taper, but it can be calculated from the detail on the drawings.
Steven Snyder
Total ratings: 106
Report this Post02-11-2014 08:08 PM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have those drawings but I assumed the taper wasn't measured since it isn't indicated in the dimensions. Blooz, could you confirm?
[This message has been edited by Steven Snyder (edited 02-11-2014).]
Total ratings: 237
Report this Post02-11-2014 08:54 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I remembered that I have an upper ball joint cut apart and in a knuckle on the shelf... I can get good measurements from that.
Steven Snyder
Total ratings: 106
Report this Post02-11-2014 10:59 PM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Will!
Bloozberry
Total ratings: 311
Report this Post02-12-2014 06:59 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's correct Steven. I did measure the diameter of the holes top and bottom and the depth of the holes but not accurately enough to use with certainty for what you're doing. That wasn't my goal in producing these, though when you do find the taper angle, if you post it, I'll update my drawings.
Steven Snyder
Total ratings: 106
Report this Post03-11-2014 08:58 PM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
My measurements off of a Rodney Dickman balljoint give a taper angle of ~9.24 degrees. However the angle is very sensitive to even a thousandth of error. Other GM cars have used a 10 degree taper, so it's probably 10 degrees.
