  4T65E-HD Drive Sprocket / Stator Support bearing
4T65E-HD Drive Sprocket / Stator Support bearing by CC Rider
Started on: 03-31-2014 10:44 AM
Replies: 6 (523 views)
Last post by: CC Rider on 04-04-2014 11:07 AM
CC Rider
Total ratings: 61
Report this Post03-31-2014 10:44 AM Click Here to See the Profile for CC RiderSend a Private Message to CC RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Was changing the axel seals on the tranny and my seal puller caught the edge of the bearing and damaged it.
Is this an easy fix and where do I get the bearing.
Does it need a special puller?
Does it need a special installation tool?
Thanks for any help provided.
Red 1988 GT 5 speed LQ1 Powered
Poly all around, Koni's and Lowered
Items for sale - cradle support - 3800 tranny mounts
http://s733.photobucket.com/albums/ww339/CC_Rider/
Lou6t4gto
Report this Post03-31-2014 12:37 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
On the passenger side you can just unbolt the 4 bolts and remove the entire extension to replace it, which side are you working on ?
CC Rider
Total ratings: 61
Report this Post03-31-2014 12:41 PM Click Here to See the Profile for CC RiderSend a Private Message to CC RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Driver side-the side the axel sticks out.
CC Rider
Total ratings: 61
Report this Post04-02-2014 11:35 AM Click Here to See the Profile for CC RiderSend a Private Message to CC RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
how hard is it to remove the side cover to make it easier to replace the bearing?
Lou6t4gto
Report this Post04-02-2014 12:35 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had 2 of them OPEN for rebuild. I can't remember IF the cover has to come off to change the" bushing", seems like it should not "Have to". . But, It IS, just "what it "Looks Like". you drain the trans, the side cover comes right off. * But, the seal and bearing are NOT "In The Cover"*, they are in a Plate "AFTER" the cover is removed. still Not something that's "a lot of fun" with the trans IN the car. Be Care full with the side cover "Gasket", don't bend it.
CC Rider
Total ratings: 61
Report this Post04-02-2014 01:02 PM Click Here to See the Profile for CC RiderSend a Private Message to CC RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
Engine is on a cradle stand so it will be somewhat easier.
CC Rider
Total ratings: 61
Report this Post04-04-2014 11:07 AM Click Here to See the Profile for CC RiderSend a Private Message to CC RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I found out the cover does have to come off.
Purchased the Miller tool J-41991 that is needed to align and drive it out and in correctly.
Will be my first time and I found a online manual (4t65e.pdf)
Thanks
