  Corvair hubs for 84-87 ??
Corvair hubs for 84-87 ?? by FierOmar
Started on: 05-03-2014 03:33 PM
Replies: 5 (1299 views)
Last post by: FierOmar on 05-04-2014 12:26 PM
FierOmar
Report this Post05-03-2014 03:33 PM Click Here to See the Profile for FierOmarSend a Private Message to FierOmarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by bubbajoexxx:
for those who want to see the corvair hubs installed on the fiero spindles us this link
http://www.fortunecity.com/.../switch/67/id215.htm
this will alow you to use large wheel bearings to teplace the tiny ones on the fiero and to use the 5 X 4 3/4 bolt circle
The quoted material is from about ten years back. The link is dead at this point. Has anyone saved this? If so, can you post it?
FierOmar
Total ratings: 206
Report this Post05-03-2014 03:39 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Forum member jb1 supplied me with a set......
Total ratings: 259
Report this Post05-03-2014 05:06 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The internet archive of that link doesn't show much:
https://web.archive.org/web.../switch/67/id215.htm
However, he reference that mod on page 7 of the newest project build, but showed some more pictures and details about it on page 19:
https://www.fiero.nl/forum/F.../HTML/000007-19.html
hub swap so I can install the wheels
first of all I removed the brake caliper and rotor to get access to the old hub
so it can be removed
with the hub removed I installed the concentric ring for the new seal surface
now that the ring is pressed on I can install the larger corvair hub with the correct bolt circle
with the hub installed the rotor now sits 5/8 of an inch closer to the spindle witch mens my brake adapter must be 1/4
of an inch thick so off to the shed I got to make a new one .
With that done I installed the front wheels and they fit perfect and with the larger front bearing less chance of failure
and the wheel is more centered over the rear bearing so less stress on the front bearing.
The corvair hubs were also the small car GM front hub and were used on some early Novas, so you can expand your search beyond just corvairs.
jb1
Report this Post05-03-2014 05:29 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Camaro nova and several others use the same hub.
Call corvair ranch I bought several sets from him. I think it was around $30-35 per hub
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a---sold
Northstar Rebuild
[This message has been edited by jb1 (edited 05-03-2014).]
FierOmar
Report this Post05-04-2014 12:19 PM Click Here to See the Profile for FierOmarSend a Private Message to FierOmarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks to each of you. That's what I have always liked about this forum... always someone willing to help.
FierOmar
FierOmar
Report this Post05-04-2014 12:26 PM Click Here to See the Profile for FierOmarSend a Private Message to FierOmarEdit/Delete MessageReply w/QuoteDirect Link to This Post
FierOmar
Member since Dec 2001
Digging a little deeper into the link provided by fieroguru, I found the following link:
https://web.archive.org/web.../switch/67/id216.htm
I think that is what I was searching for. Thanks again. Oh yeah... and thanks again to Bubbajoe.
FierOmar
[This message has been edited by FierOmar (edited 05-04-2014).]
