  how to hook up heater hoses on fiero v8 swap
how to hook up heater hoses on fiero v8 swap by redchevy
Started on: 08-15-2014 05:06 PM
Replies: 4 (841 views)
Last post by: FFIEROFRED on 08-17-2014 09:15 AM
redchevy
Report this Post08-15-2014 05:06 PM Click Here to See the Profile for redchevySend a Private Message to redchevyEdit/Delete MessageReply w/QuoteDirect Link to This Post
does anybody have any pics of how they hooked up heater hoses on their v8 fiero swap? I have a electric water pump on my conversion. any ideas? thanks
NW-Fiero
Report this Post08-15-2014 05:45 PM Click Here to See the Profile for NW-FieroSend a Private Message to NW-FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
The inlet connection is 5/8" ...... the outlet is 3/4" hook it up.......
Mark
' 85 2m6 3.4PR
In the Great Northwest!
Total ratings: 259
Report this Post08-15-2014 08:49 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The supply to the heater core can come off any intake manifold port that is below the thermostat. Here is a picture of the heater supply coming out a port just to the right of the thermostat fill.
The last one it did, I made a tube that went between the passenger side coolant tube and the inlet to the water pump. This tube had a nipple welded to it so the heater core return could merge with the coolant coming from the radiator. This is how the stock 88 Fieros route their heater cores. In this pic, the braided stainless hose is the supply and the rubber hose is the return.
Website: fieroguruperformance.com
Products: 88 13" Brake Kit, 88 12" Brake Kit, 88 Lateral Link Relocation, 84-87 Machined Front Hubs, Custom Machining
Engine Swaps:
LS4/F40, HSR/SBC/F23, Pro-Flo/383/Getrag, 4.3CPI/4T60, Ramjet SBC/Getrag, 4.9/Isuzu, Carb SBC/Isuzu, 4.5/Isuzu
redchevy
Report this Post08-15-2014 11:08 PM Click Here to See the Profile for redchevySend a Private Message to redchevyEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks fieroguru for the great pics....now I just need to plumb like you did. shane
FFIEROFRED
Report this Post08-17-2014 09:15 AM Click Here to See the Profile for FFIEROFREDSend a Private Message to FFIEROFREDEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I did mine I put a restricter in the hose coming off the intake. This forces most of the water to go to the rad, not just run through the heater core. Corvettes with TPI had this stock.
