building fiero for my wife by mrbones
Started on | : 12-09-2014 10:19 AM |
Replies | : 32 (675 views) |
Last post by | : mrbones on 01-17-2015 11:57 PM |
Dec 9th, 2014
mrbones Member Posts: 16 From: lawrenceburg tn Registered: Dec 2014
Hi my names david, an recently became an addict. I sold my trans am an bought 2 fieros, one was suppose to be a parts car an the other a daily driver. Now before I go on both cars are gts, an my parts car is complete an running doesnt have a title an has a head leak( looks to me someone filled it full of water an let it freeze up).so after a thousand miles on my daily driver an a cradle swap I found a titled carcus to swap everytbing from my parts car. Well dont you know my wife decides she wants to build it with me for her. here goes my question I plan on doing an engine swap in both cars been debating on which motor to put in hers. Been thinking between the 4.9 cady or the 3800. Either way im gonna do both swaps. Hers is gonna be a 4 speed an mine an automatic
10:19 AM
tebailey Member Posts: 2622 From: Bay City MI Registered: Jan 2013
Hard to beat the 3800. I've had 4 cars with that engine still own one with 318,000 mis. and the engine still runs like new. However the MI winters are starting to get the best of the rest of the car. Never had engine troubles with any of them, however one did have a coil pack go bad once.
10:38 AM
Gall757 Member Posts: 10938 From: Holland, MI Registered: Jun 2010
Welcome to the Forum! Has your wife driven a stick-shift Fiero? My wife can't drive mine....can't reach the clutch pedal.......
11:00 AM
Yea she can reach Ive been reading different forums on both motors seem pretty close as far as dependability an horsepower stock. Im also wondering if were both cruising around that she cant just run off an leave me.
04:36 PM
Neils88 Member Posts: 4057 From: Jeddore,Nova Scotia Registered: Aug 2013
I think that's a great idea to have her help build up the Fiero with you. I love my 4.9. It's a great bullet proof swap. Obviously the 3800sc is always going to be a fantastic car to have in the garage too. Driving style will probably dictate who gets what. The 4.9 has better front end acceleration, while the 3800sc will have the higher top speed. The 3800sc also has lots more possibilities down the line if you want to keep the build going. 4.9 turbos and superchargers have been done, but much less info and you are probably going to be limited to around 7-8 psi boost safely. The lack of info means you could be trailblazing by yourself at some points. Having said that, I think the 4.9 is also better suited for the automatic of the two. If you want to run it standard then add a custom flywheel to the parts list ($275 shipped from LSC Performance). 3800sc's came with standards so it's an easier place to start.
How mechanically inclined is your wife? ..."willing to learn" is the main criteria. Having her help will make the swap much more fun, and she'll appreciate it more. I'm planning on eventually doing one up for my wife, but other than picking the colour I won't be expecting too much help from her, lol.
05:47 PM
Yea shes willing to learn. at times its flustrating usually I go off into my own little world, im kinda militant minded when it comes to working on my cars. Ive had her help me ounce before pull a motor on a monte carlo. Then pull a motor on an el camino an put it in the monte. The newest car kind of inspired the colors for both cars. Its yellow with black trim an the interior is black with yellow trim( not original paint). So im gonna paint it black with yellow trim to match interior. An mines gonna be black with grabber green trim.
08:31 PM
Dec 10th, 2014
thismanyfieros Member Posts: 3468 From: Red Deer, alberta,canada Registered: Dec 2002
If you want to win and side by side put the 3.8sc in yours and the 4.9 in hers.... Put the standard on the 3.8sc and do the auto with the 4.9... Both will be blast for different reasons... Enjoy..
02:45 PM
2.5 Member Posts: 43235 From: Southern MN Registered: May 2007
Congrats on such a great wife who wants to build cars with you
05:10 PM
IROCTAFIERO Member Posts: 791 From: Montgomery, Al USA Registered: May 2005
no 3800 stick cars factory
07:24 PM
| quote | Originally posted by mrbones:
The newest car kind of inspired the colors for both cars. Its yellow with black trim an the interior is black with yellow trim( not original paint). So im gonna paint it black with yellow trim to match interior. .... |
I liked the Black/Yellow combination as well...I think they look pretty sharp together...
07:58 PM
Dec 11th, 2014
Sry about that I meant to write with that. Great looking motor
07:34 PM
I think im leaning toward the 4.9 in hers with a 4 speed. What clutch would be best suited?
07:39 PM
Dec 31st, 2014
Would it be easier to swap interior harness from my manual to my automatic? I know there's a difference in the steering column but will the automatic wire with lil modification?
04:57 PM
nosrac Member Posts: 3520 From: Euless, TX, US Registered: Jan 2005
| quote | Originally posted by IROCTAFIERO:
1998 Camaro ! 😜
05:24 PM
My vote is to use the Auto Trans that came with the 4.9 or the Auto that came with the 3800.
A modded 3800 is a beast. However, if you slap the M90 on the 4.9 it will wake that sumabeech up.
If you do go Manual then use the F23 as these torque monsters will tear up a Fiero manual trans as soon as you hammer it off the line.
06:32 PM
Arns85GT Member Posts: 11159 From: London, Ontario, Canada Registered: Jul 2003
I think im leaning toward the 4.9 in hers with a 4 speed. What clutch would be best suited? |
First let me say that most women have (2) priorities. (1) the color (2) automatic with A/C That said I have the 4.9 with the 4 speed 3.65 Muncie. Mine has the HEI dizzy with a 500 cfm Holley carb. However, for a lady driver it may not be the best choice. The 4 speed 4.9 is a torque monster. It goes like blazes but it is buzzy on the highway. It is definitely not quiet. It is a big rumbly sound. Kind of macho. If I was doing a lady's ride, I'd find out what her favorite color is, and then throw in the 3800 with an auto tranny. Of course if your lady likes macho, the 4.9 with Spintech mufflers will give her goose bumps. Arn Edit, on the clutch, try the Spec II +. It is soft to the touch and holds well due to the ceramic/kevlar combination ------------------  [This message has been edited by Arns85GT (edited 12-31-2014).]
09:44 PM
Sorry, double post [This message has been edited by Arns85GT (edited 12-31-2014).]
09:45 PM
Jan 1st, 2015
She defiantly wants a manual, I couldn't talk her out of it. She grew up around loud cars. I think that's why she got with me lol.
01:30 AM
We gutted the doner manual fiero today, an I was wondering am I gonna need to use the wiring harness for the interior of the manual shift in the automatic?
01:34 AM
I don't follow your question exactly but I'll give it a shot. The Manual shifter for a 4 speed has only one electrical switch and that is for the backup lights.
01:09 PM
Yea that's what I was wanting to know. But I thought there was something about the steering an igniting to the starter so you can't start it in gear? An I've also read something about a parking brake switch
08:24 PM
There is an ignition interrupter switch on the clutch pedal lever. I bypassed mine.
08:53 PM
Jan 12th, 2015
After a lot of searching I've found my 4.9 doner hopefully get to pick it up this Friday an tear it down. What flywheel do I need to find? Or where can I find one?
05:02 PM
Patrick Member Posts: 38339 From: Vancouver, British Columbia, Canada Registered: Apr 99
...bought 2 fieros... my wife decides she wants to build it with me for her... Hers is gonna be a 4 speed
Has she got a sister?
05:27 PM
Lol sry no she's an only child.
06:13 PM
Uh oh, you're going to be having your hands full. She's used to getting her own way.  Good luck!
08:58 PM
Lol your right that's how I got stuck with the automatic
11:28 PM
Jan 17th, 2015
Picked up my cadillac today runs good, it's a shame I'm gonna tear it apart. Ordered my flywheel so hopefully soon I can get started on putting my car together. I just wanted to say tnx for all the help so far. What else can I reuse on the 1993 cadillac sedan deville?
06:56 PM
PaulJK Member Posts: 6638 From: Los Angeles Registered: Oct 2001
... she wants to build it with me for her.
the good news | quote | Originally posted by mrbones:
the bad news  | quote | Originally posted by mrbones:
... between the 4.9 cady or the 3800 ....
If she's like any woman i've ever known, i'd do whichever one i could do the quickest. Anything longer than a day or 2 and i would be nagged to death about when it would be done and how slow i was ... ;( If anything goes wrong or she doesn't like it, blame the parts or GM ..... ("honey, that's why they don't make these cars anymore")  [This message has been edited by PaulJK (edited 01-17-2015).]
08:56 PM
PS. Whatever you do, DO NOT let her see the thread about Troyboy's build for Lady Lisa ......
09:15 PM
That's funny right there.. tnx for the advice
09:21 PM
If I run into problems I'm gonna be like what you do women!!! If you only listened lol ..... we were watching tv the other night an she seen a commercial for i.tt tech an she ass like I'm gonna go there that way I can tell you what to do lol....
11:57 PM
