  Throttle body without cooling liquid
Throttle body without cooling liquid by Yannsky
Started on: 12-19-2014 07:42 PM
Replies: 12 (857 views)
Last post by: theogre on 12-22-2014 12:08 PM
Yannsky
Report this Post12-19-2014 07:42 PM Click Here to See the Profile for YannskySend a Private Message to YannskyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi all
I was removing a throttle body from fiero gt 86 for my se 87 2.8. I had removed two tube of cooling liquid from this tb. Currently i don't have those tubes connected to my tb.
Is it dangerous for the tb?
Is that cooling liquid have a special fonction on tb?
Thks
Yann
KY87fierogt
Report this Post12-19-2014 07:50 PM Click Here to See the Profile for KY87fierogtSend a Private Message to KY87fierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, it will not hurt your throttle body.
Spoon
Total ratings: 61
Report this Post12-19-2014 08:23 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its there to prevent moisture from freezing of throttle butterfly shut. And if your in Canada I'd leave those coolant lines in place.
Spoon
[This message has been edited by Spoon (edited 12-19-2014).]
Report this Post12-19-2014 09:34 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's actually a 'heating liquid' when it comes to the throttle body.......if you drive the car all year, you will need the tubes connected......If you live in Florida, you don't need them.
Bloozberry
Total ratings: 311
Report this Post12-19-2014 10:25 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Formula88
Total ratings: 554
Report this Post12-19-2014 10:32 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
In Canada, you need them.
Without them to keep the throttle body warm, ice can form on the throttle plate and cause the throttle to stick open.
Yannsky
Report this Post12-19-2014 11:33 PM Click Here to See the Profile for YannskySend a Private Message to YannskyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thks all for that info
Yes I live in Canada but drives it only during summer.
BillS
Report this Post12-21-2014 08:43 PM Click Here to See the Profile for BillSSend a Private Message to BillSEdit/Delete MessageReply w/QuoteDirect Link to This Post
In Western Canada we don't need them at all on the coast. Depends on how much freezing weather you drive in.
Bloozberry
Total ratings: 311
Report this Post12-21-2014 09:48 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's been discussed here before: freezing ambient temps aren't necessary for ice to form in the throttle body. The drop in pressure across the throttle plate decreases the incoming air's temperature and can cause the moisture in it to condense behind the plate, freeze, and lock your throttle partially open even though the outside air is several degrees above freezing. It's happened to me twice before on a non-Fiero. The right conditions don't happen very often as evidenced by the small number of people who've experienced it, but any post-accident investigation by either insurance or police will surely find the problem behind your sticking throttle. IMHO it simply isn't worth not installing them. You gain nothing by leaving them off.
Report this Post12-22-2014 12:51 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not true. You gain access to the distributor!
PatrickTRoof
Report this Post12-22-2014 05:54 AM Click Here to See the Profile for PatrickTRoofSend a Private Message to PatrickTRoofEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bloozberry
Total ratings: 311
Report this Post12-22-2014 06:41 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
LOL... well ya got me there.
Report this Post12-22-2014 12:08 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes... TB TBI and Carburetor icing can and does happen. And often w/o freezing weather.
Icing can cause throttle sticking, idle problem, etc.
If you stop and try to look, the engine heat will often melt frozen water in time to stop and open the hood.
Is why many TBI and Carb's have Thermac heater on air cleaner. W/o heat can freeze them at much higher air temp in high humidity. Many problem in the cool/cold weather because Thermac etc heater problem causing carb to freeze. Fix Thermac issues and the problem is gone. V6 coolant heat on TB is doing same job.
Example: I had old caravan in the Philly area that would freeze the carb in 40-50°F air in high humidity weather if the Thermac pipe is gone. It would die trying to slow down after driving 55 a few miles when thermac pipe is broken. No engine then no PS or PB. Fun. Not.
GM spend money to heat V6 TB should be a big clue... No car maker would spend money w/o very good reasons. Yet many will say is safe to remove the heat plumbing? They know More then GM designers? Not likely. They just parroting same myths on the internet.
Some area might be fine to remove heater pipes and thermac. Other places many will gamble if/when engine dies or throttle stuck open for icing problems. Many icing problems happen at the worse times and often give no warning at all.
