The pic below is not my dash, I'm posting it to show the temp gauge only (mine is Metric)
My GT's Temp Gauge was showing a normal engine temp as the gauge in the pic below.
It looked wrong to me - too low, and would go even lower (almost to the 100F) when the fan kicked in.
It sure looked like I had a stuck open thermostat - but it's a brand new Stant (and has NOT collapsed).
Scanning with TunerPro showed the engine to be fairly steady at 185F (85C).
That's exactly where I'd expect it to be as I have a 180F thermostat and Dickman's 210on/185off fan switch.
I used a 55 ohms resister to check the gauge and it peaked at the top of the gauge as it should.
So I replaced the sender with a new Standard Motor Products PN TS168T sending unit.
Once I did that, "normal" operating temp on the gauge was at the 220F mark (and sometimes higher)!!
What I'd expect is the needle around the 2/3rds mark between mid-point (160F?) and the 220F mark.
I figured I got a bum sending unit, so I replaced it again with a new Borg Warner (BWD) PN WT414
With this sending unit, I'm back to what the original sender was showing - in the bottom 3rd of the gauge. WTF??
What are you guys seeing on your temp gauge?? (and what thermostat do you have)
Calgary time/temp
