  Throttle cable on 3800
Throttle cable on 3800 by Monkeyman
Started on: 05-07-2015 09:43 PM
Replies: 5 (1023 views)
Last post by: Darth Fiero on 05-11-2015 03:28 PM
Monkeyman
Total ratings: 182
Report this Post05-07-2015 09:43 PM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the end of the throttle cable supposed to look like this or do I need to buy something specific to the swap? Trying to fix all the things sorted the PO didn't.
Mike Gonzalez
Total ratings: 130
Report this Post05-07-2015 10:24 PM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
That could be improved upon :-P If you lose the home made bracket and widen the stock bracket to fit the cable you can do it more like this.
<--from GmTuners.com
Darth Fiero
Total ratings: 361
Report this Post05-07-2015 10:27 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
You don't need to widen the stock 3800 throttle body's cable mounting bracket. You just need to shave down the stock Fiero throttle cable some instead.
OVERKILL IS UNDERRATED
Mike Gonzalez
Total ratings: 130
Report this Post05-07-2015 10:30 PM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
HAHA, i Ninja'd you with your own pic Ryan !!!
I always modify the bracket, as a machinist/gunsmith you learn to modify the cheap/easier to get part first. but thats just me.
[This message has been edited by Mike Gonzalez (edited 05-07-2015).]
Grizz54
Report this Post05-07-2015 11:50 PM Click Here to See the Profile for Grizz54Send a Private Message to Grizz54Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would have never thought of bolting the cable in. Instead I would cut the cable off and us a throttle cable stop. You can find those at most parts stores in different sizes.
"To err is human" Nuff Said!
Darth Fiero
Total ratings: 361
Report this Post05-11-2015 03:28 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had thought about cutting the bracket, but doing that makes the one side (that separates the throttle from the cruise cable) very thin. I looked at the OEM Fiero throttle cable and determined a cutoff wheel on a dremel could quickly make the plastic on the cable thin enough to slide down into the stock 3800 throttle cable bracket.
[This message has been edited by Darth Fiero (edited 05-11-2015).]
