  Where there any V8 chevy FWD
Where there any V8 chevy FWD by Lou6t4gto
Started on: 09-26-2015 08:42 PM
Replies: 22 (1399 views)
Last post by: fieroguru on 09-28-2015 06:39 PM
Lou6t4gto
Report this Post09-26-2015 08:42 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
where there any 8 cylinder Chevy Front Wheel Drive cars made ? or where the only ones made by GM Caddy ?? thanks
dobey
Total ratings: 371
Report this Post09-26-2015 08:47 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes.
The LS4 Impala SS and Monte Carlo SS were the ones from Chevy.
For Pontiac, there was a Bonneville GXP that had a Northstar, as well as the Grand Prix GXP with the LS4. The Olds Aurora had the smaller 4.0 Northstar series engine too. And the Buick Lucerne came with a Northstar or an LS4, for a few different years. Then of course all the Cadillacs.
Formula88
Total ratings: 554
Report this Post09-26-2015 09:03 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Impala SS, Monte Carlo SS and Grand Prix GXP = Chevy FWD
Bonneville GXP, Aurora, Lucerne, etc. are not Chevy drivetrains.
Lou6t4gto
Report this Post09-26-2015 11:31 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
did these "CHEVY" drivetrains, actually Have a Chevy Bell Housing pattern on the trans axles ?? Code ?
dobey
Total ratings: 371
Report this Post09-27-2015 09:22 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The LS4 has the Metric bell pattern. But you can't use it with just any Metric pattern transaxle, due to the starter positioning.
dobey
Total ratings: 371
Report this Post09-27-2015 09:29 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
dobey
Member since Sep 2001
The Northstar is a Cadillac drivetrain, but the LS4, like all the Gen III/IV LSx V8 engines, is a GM corporate engine, not a "Chevy" drivetrain.
Sorry, yes, the Lucerne did only have the Northstar. The LaCrosse Super had the LS4. Got those confused again.
Report this Post09-27-2015 10:20 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 60's to early 80's TH425 and TH325-4 have the BOP pattern, but it shares the dowel pin locations and the two lower bolt holes with the SBC pattern and thin adapter plates are available to mount a SBC to them for less than $50.
http://www.speedwaymotors.c...-6gbXYPGBRq5mbql-8Xt 9re_PW0qq2Y2VzFqSktxRoCG1Tw_wcB
These are longitudinal transaxles and here is an example swap with one of them:
You can also flip the diff and put the back of the transmission facing forward to move more weight forward in the chassis, but those transmission are still pretty heavy.
Lou6t4gto
Report this Post09-27-2015 01:33 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I saw an adapter on ebay for $39. those Trans are like "Hensteeth" and I believe required a special oil pan to get over the Axle.
Back to the Orig. Question. So, I "gather", there were NO late model Front Wheel Drive Cars with a Real CHEVY (350 OR lt1), or 4.3.
After that point I don't consider the rest as Chevy, just Corporate. They have nothing to do with the original design Chevy V8 engine. Thanks
dobey
Total ratings: 371
Report this Post09-27-2015 01:45 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, there is nothing with a Gen I small block in FWD configuration. The Gen II LT1 and LT4 were corporate too, but closer to the original SBC than any LSx engines are.
jaybug56
Report this Post09-27-2015 08:03 PM Click Here to See the Profile for jaybug56Send a Private Message to jaybug56Edit/Delete MessageReply w/QuoteDirect Link to This Post
What you thinkin' of doin' ??
Lou6t4gto
Report this Post09-27-2015 10:52 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
just wondering. IF there was a V8 chevy front wheel drive factory made, the engine/trans could be tossed right into a fiero without engine to trans Adapters. just a thought. I'm making a FULL Custom using a Fiero chassis, chopped roof, fully hand made custom 1/4s, rear panel, doors, front end, interior... "Everything" will be 1 off. haven't decided on a "drivetrain" yet.
Monkeyman
Total ratings: 180
Report this Post09-28-2015 03:15 AM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by dobey:
The Northstar is a Cadillac drivetrain...
The Oldsmobile Aurora had the N*, too. I think the last of the Pontiac Bonnevilles and the Buick Lucerne also used it.
dobey
Total ratings: 371
Report this Post09-28-2015 09:18 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. I said that.
dobey
Total ratings: 371
Report this Post09-28-2015 09:21 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
dobey
If you want a carbed 350 or TPI, it's not happening. If you want an LSx, then the LS4 with the 4t65e-HD is not a too difficult swap.
Formula88
Total ratings: 554
Report this Post09-28-2015 12:57 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Closest to that is the LS4 and it's transmission. Custom mounts and lots of custom wiring. Really it doesn't save you much other than not needing an adapter plate since everything else is still custom. However, it is a matched engine/tranny and it's a good drivetrain.
The LS4 is the only FWD transverse Chevy engine I'm aware of.
The Caddy Northstar 4.6L and the 4.0L used in the Aurora could also be used with their own transmissions. (Caddy engine, though, not Chevy)
There aren't many V8/FWD combos from GM to choose from.
Lou6t4gto
Report this Post09-28-2015 01:40 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
what I'd Really "Like" is a gen 1 327 Chevy, inj or carbed, with a Dist, but still a gen 1 CHEVY V8. Just don't want to drop $1000 on a Adapter !
(I don't have that much in my 3800SC swap and it's all rebuilt). Want More "Low End" TORQUE than a 3.8. . I considered a 4.9 caddy, but have not heard a lot of Good about how well they "Hold Up". I Already Have a 4t65e-HD waiting. Won't consider a Northstar, too large. Looking for "reasonably priced" Options". Thanks
Silvertown
Report this Post09-28-2015 02:01 PM Click Here to See the Profile for SilvertownSend a Private Message to SilvertownEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know who's car this is but the guys in Cali do it right.
http://www.youtube.com/watch?v=ktlGu5CrVLg
dobey
Total ratings: 371
Report this Post09-28-2015 02:06 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The only "reasonably" priced option for an old 327 in a Fiero, is to buy one already done, or to wait around and hope someone selling Archie's kit for dead cheap, shows up.
Or you can design your own adapter plate, starter mount, oil filter adapter, etc… and fab everything up yourself. You're not going to get a Gen 1 SBC swap done cheap otherwise.
Silvertown
Report this Post09-28-2015 02:14 PM Click Here to See the Profile for SilvertownSend a Private Message to SilvertownEdit/Delete MessageReply w/QuoteDirect Link to This Post
[URL=http://www.speedwaymotors.com/Chevy-to-BOP-Transmission-Adapter-Plate,3281.html?sku=91628908&utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE&catargetid=530009170000093761&cadevice=c&gclid=CjwKEAjwp56wBRDThOSZ3vqGzmESJABjNaj9--6gbXYPGBRq5mbq l-8Xt]http://www.speedwaymotors.c...-6gbXYPGBRq5mbql-8Xt[/URL] 9re_PW0qq2Y2VzFqSktxRoCG1Tw_wcB
If that's your build you truly are a guru.
Silvertown
Report this Post09-28-2015 02:29 PM Click Here to See the Profile for SilvertownSend a Private Message to SilvertownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Silvertown
Member since Sep 2015
If you want a 327 all you need is a 327 crank. I got one from 196? Its in great shape. All you need is any sbc and the crank, just make sure it's a large journal post 1967 or 8. I can't remember the year they changed. A small journal will rotate faster though. If you want a 327 go to the chevelle and camaro boards.
Lou6t4gto
Report this Post09-28-2015 03:09 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
yea, a 327 is a 350 with 327 Pistons and crank, that's easy enough to build. Adapting it to the 4t65e is another matter. Has anyone ever tried to convert a "Adapter" for a "Chevy to BOP" ? It seems like the hardest part of an adapter is getting the "centerline" of the engines Crank Exactly the Same as the Centerline of the Torque Converter . Anyone with experience on this ?
Silvertown
Report this Post09-28-2015 03:52 PM Click Here to See the Profile for SilvertownSend a Private Message to SilvertownEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had thought of this as a option. But no, I've never seen it done. Just the pic above. You can make it work its gonna have to be fabed by a builder.
Report this Post09-28-2015 06:39 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not mine, but it is for sale in the mall
