I have never heard of a weak armature. In my opinion the reason for most all of the problems in the early systems is:
Most that have headlight motor problems want to blame the headlight motors. They replace them with rebuilt headlight motors but many times still experience the same problems. Some replace the relays but again still have the same problems. Why? The problem in most all cases is a diminished path for the voltage and amperage from the battery reaching the armature of the headlight. The armature is spring loaded and if it does not spin with enough strength and momentum it will not operate the contacts in the headlight motors correctly.
The path for the voltage from the battery and back (all the grounds) is a long one. As on any older vehicle, time takes it's toll on the wiring connections, grounds etc. There is never any one place to look. It starts at the battery terminal and little by little the voltage and amperage diminishes along the way. Slightly corroded connections in all the various connectors. Corroded grounds. Every marginal connection diminishes the voltage and amperage to the headlight armature. By the time the voltage gets to the armature in the headlight motor it can be seriously diminished.
The kit I am making eliminates many of these marginal connections. You remove the isolation relay and the relays on each headlight bucket. My unit splices in to the wires from the wiring harness. I include butt splices and adhesive lined shrink tube to make water tight connections. My unit is in a plastic box and potted thus making it waterproof. My unit also has two ground wires coming out of it to insure an excellent ground. You splice on new connectors to each headlight motor, again using butt splices and adhesive lined shrink tube. Once installed the largest part of the headlight control system is now all new and waterproof. Incorporated into this new relay unit are snubbers for each headlight motor. What does a snubber do? It absorbs the arc you get every time the relay opens thus reducing the degradation on the contacts in each headlight motor and the relays in my new unit.
I'm very close to having some test units finished for a few to test. I'll be posting that in the Fiero Facebook group. Someone here thinks I am using people here to do my R&D and will probably jab me more if I offer some here free for R&D. If you would like to try a relay unit free for N/C PM me so it is not shown on the forum to try and keep the peace here.
http://rodneydickman.com/ca....php?products_id=412In my opinion my new relay units should fix most all the problems like this in the early headlight systems.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
