  87 with two Brake Switch Mysterious Yellow wires ?
87 with two Brake Switch Mysterious Yellow wires ? by Simple Man
Started on: 09-18-2018 10:42 PM
Replies: 7 (399 views)
Last post by: olejoedad on 09-19-2018 02:45 PM
Simple Man
Report this Post09-18-2018 10:42 PM Click Here to See the Profile for Simple ManSend a Private Message to Simple ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 87 Fiero with a 3800 series II SC has two brake switches.
I have eliminated all but one connector by reading various threads here, (see below)
Switch #2
Connector - with Yellow and Yellow and black stripe - I haven't been able to figure out what this controls???
Connector - with Purple and Pink/Blk Stripe - TCC
Switch #1
Connector - with Lt Blue, Orange and White wires - Brake Lights
Blue Connector - Cruise control
Anyone have any ideas?
Thanks
SM
AsaBergman
Report this Post09-18-2018 11:00 PM Click Here to See the Profile for AsaBergmanSend a Private Message to AsaBergmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
The unknown wire may go to the ECM. 3800 series engines have a DFCO(deceleration fuel cut-off) function wired through a brake switch.
Simple Man
Report this Post09-19-2018 12:03 PM Click Here to See the Profile for Simple ManSend a Private Message to Simple ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Asa, I'm not sure either, but I will fix the mounting and keep it in place.
Total ratings: 206
Report this Post09-19-2018 01:19 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The yellow and yellow/black wires are part of the cruise control circuit.
When the pedal is depressed, the circuit opens and removes power from the coil in the Vacuum Release Solenoid.
There is no DFCO circuit used in a 3800 swap in a Fiero.
Simple Man
Report this Post09-19-2018 01:42 PM Click Here to See the Profile for Simple ManSend a Private Message to Simple ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the input olejoedad!
I thought the Blue plug (with the two wires grey and Brown/White) was the cruise control?
what is that connector for?
Cajun
Report this Post09-19-2018 02:10 PM Click Here to See the Profile for CajunSend a Private Message to CajunEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is actually more than one switch associated with the cruise control operation. The switch with the gray and gray/white wires is the "brake switch". The output goes to the cruise control module.
The other switch with the yellow and yellow/black wires is the "cruise brake switch". It's output controls the "cruise release solenoid".
I assumed you have an automatic as you commented about the TCC.
If you have a manual the are 3 switches.
[This message has been edited by Cajun (edited 09-19-2018).]
Simple Man
Report this Post09-19-2018 02:43 PM Click Here to See the Profile for Simple ManSend a Private Message to Simple ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you Cajun!! Good info, much appreciated!
Yes an Auto trans
Car currently does not have cruise. Will do a little research to see what I need to run the digital system with the 98 3800 Series II SC
Total ratings: 206
Report this Post09-19-2018 02:45 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Digital cruise is not hard to install, check gmtuners.com for instructions.
