| | | quote | Originally posted by Patrick: Keep in mind that starter mounting bolts are not the same as a regular bolt. There is a knurled area on the bolts which aligns the starter correctly. Regular bolts will allow the starter to be mounted crooked in relation to the flywheel... which will lead to improper meshing of the starter gear. |
Yup. GM and a few others use them. And using any "normal" bolt can cause starter breakage or worse and often sooner rather than later. But If the starter holes are wrecked, very possible here, then might not help unless you get another starter.
You can get GM starter bolts at most local parts stores. OE are 114mm and 46mm long. Often in Dorman Help! packaging and both lengths in one pack. "Upgrade"/"Update" starter may require different lengths but same type are used.
Also Dukes have a bracket for the other end of the starters. Attach to starter w/ nuts on stud head motor bolts and a bolt to a block hole near by.
Duke's shacks a lot more the other engines and can work even the right bolts loose then fall out.
Many are missing because fools think they know better then GM and don't put in back after starter replacement etc.
Some have upgraded/updated and OE bracket won't fit because starter is shorter. I would try to make/mod a bracket so still have this in use on dukes.
Many have lost a starter shim too. Lost front bolt keep the shim in there because other hole is often slotted. If, more like when, you need them get from same sources as the bolts.
The slot allows you to partly install engine side bolt then install the shim(s) then install the short bolt and tighten both.
Many new/rebuild units from part stores and some others include shims and gauge but not bolts. Some starter say no shim but you should check clearance all the same.
See my Cave,
Starter------------------
