  How to gain 22 rwhp from the Fiero intake @ 6000 rpm...
How to gain 22 rwhp from the Fiero intake @ 6000 rpm... by lou_dias
Started on: 07-05-2019 03:39 PM
Replies: 25 (1686 views)
Last post by: ericjon262 on 05-02-2021 05:43 PM
lou_dias
Total ratings: 67
Report this Post07-05-2019 03:39 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your mileage may vary...
Here is my setup:
Total ratings: 465
Report this Post07-05-2019 11:15 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou, that's an interesting intake mod. Although what you did is much more involved, it reminds me of the old days where we would modify the divided plenum on V8 intakes to enhance top-end power.
lou_dias
Total ratings: 67
Report this Post07-06-2019 12:31 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
It was an experiment. I threw caution to the wind and would never do this on the street but the benefits outweighed the drawbacks in this case. Giving up 10 ft*lbs for a larger area under the curve gain from 4600-6000 rpm seems like a big win here.
Total ratings: 328
Report this Post07-06-2019 12:42 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Impressive results for what you have there. You gained more than 22 HP as a stock 2.8L on a dyno only puts out about 120 RWHP due to drivetrain losses.
lou_dias
Total ratings: 67
Report this Post07-06-2019 02:23 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
@Dennis,
My motor is actually making >200hp but my larger diameter and much heavier wheels+tires and clutch spacer (1" thick aluminun disc) drivetrain are making it *look* much lower. I don't put on "dyno wheels" to tune. The 3.4 can make >200 rwhp in a Fiero pretty easily if you don't just do a low-ball "basic swap" that will only get you 135rwhp...
When I was using wheels near stock weight, this motor put down 187 rwhp and 249 ft*lbs on a Mustang dyno. That was using 99 Camaro 16" alloy wheels and 255 series tires that weighed 45lbs each. My current combo weighs 52 lbs each and most of that weight-gain is a the perimeter since they are 1" larger in diameter than stock and much wider (315/35/17).
If you know anything about torque is that it's based on a radius arm and where the force is coming from. Since the force is coming from the axial point - If you shorten the arm, torque goes up...lengthen the arm and it does down. When you force it from the radius, then it's easier to apply force to a wrench, for instance, to loosen a bolt. I think we are talking about 1/2" but that's about 5% off the top already. So just taking that into account, I'm almost at 181rwhp. Perhaps if I decide to skip next year's racing season, I'll go back to street tires and work on fixing the body and maybe hit a dyno then... That's a big if. I love racing.
[This message has been edited by lou_dias (edited 07-06-2019).]
lou_dias
Total ratings: 67
Report this Post07-08-2019 11:12 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Disappointing results as I lost part of my exhaust in round 2 which pinched a brake line. Caused me to lose my balance in round 4 when I was coming into turn 4 hot and tapped my brakes... Looked like I would have been able to out accelerate John Feilding's Camaro coming out of turn 4 until then...
You can see my exhaust fly out at around the 12:21 mark...
[This message has been edited by lou_dias (edited 07-08-2019).]
Spadesluck
Report this Post07-08-2019 11:23 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
You came pretty darn close to kissing that wall as well!
Total ratings: 465
Report this Post07-08-2019 11:54 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Disappointing results...
Yeah, that was too bad.
I always enjoy watching these videos. Maybe they should limit the number of Camaros though.
So what's the deal with the 2-stroke EVO?
[This message has been edited by Patrick (edited 07-08-2019).]
lou_dias
Total ratings: 67
Report this Post07-09-2019 06:45 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
That car is insane. That motor is almost blowing up but he's been building another one that should do the 1/4 mile in 8 seconds...
BillS
Report this Post07-16-2019 06:01 PM Click Here to See the Profile for BillSSend a Private Message to BillSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice results, Lou.
Great to see some dyno evidence instead of the more common "I swear it had 100 bhp more...' we see so often. What is the intake you started with - 3.1 F body?
lou_dias
Total ratings: 67
Report this Post07-17-2019 10:28 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's a ported Firebird 2.8 upper intake. I had the neck bored to 59mm and all the ports were gasket matched on 3 sides and the inner wall was bored about ~3/16" on the 6 ports to increase flow to the middle manifold. The middle manifold's upper inner wall on the ports were similarly opened up as well. Again I feel I went a bit overboard with how much material was removed at the base of the middle manifold... Perhaps some angled cross-drilled holes would have achieved close to the same results without giving up so much mid-range...
BUT it does show that the main problem with making power > 4500 rpm is the middle and upper manifolds...
BillS
Report this Post07-17-2019 04:06 PM Click Here to See the Profile for BillSSend a Private Message to BillSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very useful information.
I used a late Camaro intake on the 3.4 I use and did a bunch of port work and manifold modification including boring and fitting a 62 mm throttle body.Worked very well. The engine runs cleanly through 6,000 plus with no falling off (Crane 272 cam).
It is sad that the GM engineers couldn't be bothered to eliminate bottlenecks that cost horsepower but could have been improved for a small amount of money. Relieving the stock Fiero exhaust manifolds is the worst example.
The more modern example is the Solstice. They had a tune that they made an option. It was approved for warranty, yet they didn't offer it as anything but an add on option. It added 30 bhp and 50 Tq and actually resulted in slightly better fuel consumption. If they had standardized it before submitting the cars to the magazines for the road tests, the car would have been better than the other candidates in terms of performance which would have sold a lot of cars.
Wonder which bean counter botched that one....
[This message has been edited by BillS (edited 07-17-2019).]
lordfiero
Report this Post07-17-2019 05:03 PM Click Here to See the Profile for lordfieroSend a Private Message to lordfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice Im not suprised you gained HP, Its in line with my flow measurements of these intakes.
It is intresting that no major loss of TQ in the mid RPM range occurs, you kind of moved the plenum down all the way to the LIM..
lou_dias
Total ratings: 67
Report this Post07-17-2019 06:54 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's about building the type of engine you want without breaking the bank. It amazes me how a little grinding here and there can make such changes to a motor. Ideally if somehow intake ports could expand and contract in a controlled manner, you could make an engine very efficient for it's entire RPM range.
My next engine will have much higher compression since E85 can handle it quite nicely. ;-)
jdv
Report this Post12-21-2019 10:11 PM Click Here to See the Profile for jdvSend a Private Message to jdvEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou nice set up . What type of brakes are you running on that thing in race trim?
lou_dias
Total ratings: 67
Report this Post12-22-2019 03:23 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm using the original HELD/Rayne 12" kit.
https://www.fiero.nl/forum/A...070315-2-072050.html
But I've since switched to scallop'd versions of the rotors to save some weight in rotating mass.
https://www.wilwood.com/rot...%20Scalloped%20Rotor
[This message has been edited by lou_dias (edited 12-22-2019).]
lou_dias
Total ratings: 67
Report this Post02-18-2020 11:09 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I just did this mod on my daily 3.4 Formula this week as well. Using stock 3100 roller cam and Sprint F1 Headers...and Camaro stock 9.0:1 3.4L pistons. (Yes I bored a 3100 to 3.4L...)
This time I grinded out less material. No dyno yet, however it feels like I didn't lose any torque but now the engine revs faster (as in more HP). Idle has gone up.
This is on 87 octane fuel. I am probably running lean until the computer adjusts however the power gain is quite noticable.
Does anyone have an 88 V6 5 speed BIN file with the EGR disabled programming in place? I'd like to tune it using that as a base.
[This message has been edited by lou_dias (edited 02-18-2020).]
lou_dias
Total ratings: 67
Report this Post02-21-2020 10:12 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update:
Seems my high idle is a vacuum leak as I realized my cruise control no longer works...
jjd2296
Report this Post05-02-2021 10:26 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
So I did this mod to my 3.4 last year and there was a noticeable difference in the upper rpm. Yes have now installed a vortech supercharger V1 S trim with a 2.8 pulley. My boost is only around 5-6 at 4500 rpm. I can’t push it as it needs another tune being lean and all. with the factory crank pulley and the small sc pulley I should be higher in the boost then showing on the gage right now. Im no engineer but im wondering if the boost is registering lower than it should due to the runners in the middle intake being eliminated?
jjd2296
Report this Post05-02-2021 11:33 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
jjd2296
Member since Jan 2016
pmbrunelle
Total ratings: 63
Report this Post05-02-2021 12:29 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Often what helps is to imagine some parameter is taken to the extreme, such as zero or infinity.
Imagine if the supercharger outlet was out in the open (air pipe not connected to the engine, but belt still belt-driven).
What would the boost pressure be at the supercharger outlet?
jjd2296
Report this Post05-02-2021 12:35 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was thinking Thst because the runners were eliminated between the middle intake and lower intake that pressure cannot be built up due to the disbursement of the air between lower and middle intakes.
pmbrunelle
Total ratings: 63
Report this Post05-02-2021 01:18 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pretty much, your reasoning makes sense.
If you see the boost pressure go down on a setup with a belt-driven supercharger, it means you've done something to make the engine breath better.
jjd2296
Report this Post05-02-2021 01:22 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
So then the question is do I just leave it or swap back in a tick I modified middle intake? Will it result in any difference in power?
jjd2296
Report this Post05-02-2021 01:31 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
jjd2296
ericjon262
Total ratings: 67
Report this Post05-02-2021 05:43 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
the lower boost pressure means(in this case) each cylinder is getting more air in, this is typically a good thing. I would leave it.
cognita semper
