  Orifice filter install orientation
Orifice filter install orientation by sricka01
Started on: 08-16-2019 03:49 PM
Replies: 4 (329 views)
Last post by: sricka01 on 08-16-2019 09:43 PM
sricka01
Report this Post08-16-2019 03:49 PM Click Here to See the Profile for sricka01Send a Private Message to sricka01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can someone confirm if this is correct way to install?
Fat side of rubber pipe connecting to evap line on passenger side.
Skinny metal pipe with orifice with metal valve and oring inserted first.
I have replaced dryer, orifice, orings. Compressor is 6 years old and worked fine before a shop clutch replacement when they disconnected the lines
Will pull vacuum on low/high side and maintain.
I can get 2/3rd can sucked in with lot of effort, and thats it. It short cycles.
If i jumper the cycling switch, the bottom half of evap line is frozen. Icing at the evap/orifce junction and nowhere else. Dryer is hot. I can blow air through the evap with no issue.
Where is my restriction? Is the suction side of the compressor failing?
RWDPLZ
Total ratings: 305
Report this Post08-16-2019 04:53 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
1985-1988 Fiero, tube is in front compartment below the accumulator, in this orientation:
Orifice tube is inserted holding the long end, short end (outlet) is inserted into the tube (blue arrow)
sricka01
Report this Post08-16-2019 05:44 PM Click Here to See the Profile for sricka01Send a Private Message to sricka01Edit/Delete MessageReply w/QuoteDirect Link to This Post
This what's confusing everyone I've asked on fb.
Which side of that orifice filter goes into the tube first?
RWDPLZ
Total ratings: 305
Report this Post08-16-2019 07:40 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
The end in the picture that says OUTLET
sricka01
Report this Post08-16-2019 09:43 PM Click Here to See the Profile for sricka01Send a Private Message to sricka01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Okay yep that's how I had them installed. It gets frozen right after the orifice filter connects to the evap line and nowhere else. I can barely get one can to suction in. When running the low pressure climbs high and the high pressure doesn't seem to budge. Seems like an obstruction or compressor suction isn't working anymore.
Any ideas? Cuz I thought this was the smoking gun.
