  EGR Vacuum Regulator Valve
EGR Vacuum Regulator Valve by Notorio
Started on: 01-25-2020 04:13 PM
Replies: 4 (286 views)
Last post by: Notorio on 01-25-2020 06:22 PM
Notorio
Report this Post01-25-2020 04:13 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
On my 88 v6 I can't figure out how the EGR Vacuum Regulator Valve mounts up. The service manual doesn't show that and I've looked for pictures on the forum, nothing quite shows where it is supposed to bolt up.
Here's what the manual shows:
Here's me holding it directly above this location. The red arrow points down to where I think the EGR VRV should go, however, there is nothing there to mount it to. The two vacuum lines would connect correctly in this vicinity:
Now I'm wondering if either of these mystery brackets are required. It's been 18 months since I took this apart and the lame pictures I took don't have a useful level of detail. Any help would as always be much appreciated.
fierobear
Total ratings: 383
Report this Post01-25-2020 04:58 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just happen to have an engine sitting around with this area exposed. The EGR solenoid is removed. Hopefully this helps.
[This message has been edited by fierobear (edited 01-25-2020).]
Report this Post01-25-2020 05:29 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is a stock Formula. Bolt head is barely visible.
Notorio
Report this Post01-25-2020 05:30 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you Fierobear! That picture is perfect! I had this labeled 'above water pump' which was too nebulous to be of any use, but after you've clued me in now it makes sense. Many thanks!
Notorio
Report this Post01-25-2020 06:22 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Notorio
Member since Oct 2003
Thanks Gall. That actually clears up the mystery of where the short vacuum hose goes as well.
