  Molding in Fastback Sail Panels?
Molding in Fastback Sail Panels? by Spadesluck
Started on: 02-11-2020 09:46 PM
Replies: 11 (311 views)
Last post by: Spadesluck on 02-17-2020 09:01 PM
Spadesluck
Report this Post02-11-2020 09:46 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am giving some serious thought of molding my scoop sail panels in the car. Currently I have mine riveted into place and painted over. I did not trust any tape to hold these in place. I believe it would look better this way. I can not seem to find any discussions this. Does anyone have any experience or thoughts about doing this or not?
Here are the scoops:
Total ratings: 463
Report this Post02-11-2020 09:55 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
No real experience, but no... I wouldn't.
But that's just me. YMMV.
Spadesluck
Report this Post02-11-2020 10:58 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
There a particular reason why you wouldn't?
Report this Post02-16-2020 10:11 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero quarter windows are held in place with 3M tape so why would they not work in your application? After a recent install, a month later I drove my Fiero over 100 mph and they held firmly in place. The key is to use the correct 3M tape. If you are interested in doing it this way I'll look up the part number for you.
[This message has been edited by Dennis LaGrua (edited 02-17-2020).]
fierogt28
Report this Post02-16-2020 10:15 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
I too would like the 3M part number...
Thanks,
Spadesluck
Report this Post02-17-2020 02:03 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I understand that 3M tape is used, however I did not want to mess with it or take the risk of it not working like many others have had happen. Additionally the fiberglass panels I am using are not as flexible as the stock windows and I do not think the 3M would hold them in place.
I am simply looking at a more permanent solution that also gets rid of the lines to bring it all together.
[This message has been edited by Spadesluck (edited 02-17-2020).]
Report this Post02-17-2020 08:49 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Georgia Fieros had a fastback with similar quarter windows. Made of fiberglass. They were bonded or taped on and have been on the car since the early 90's. I just looked at a very closeup picture and there were no screws or fasteners of any type, so I don't know which method was used. When we had the car, there was no bonding agent visible around the mating areas.
But, like Raydar, I just wouldn't do it. If they were ever damaged for any reason, it would probably be difficult to remove or repair.
Report this Post02-17-2020 09:45 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
You will be faced with the challenge of bonding together different materials; Fiberglass and Urethane. Both the fiberglass and urethane fillers are different chemically and I don't have enough info to provide on using them to bond dissimilar materials.
As for the 3M tape if applied correctly and cured at the right temperatures it provides an extremely strong bond. Once it sets the only way to break the bond is to cut it with a piano wire with two end handles.
Of course it's your car and the decision is yours alone, so do what you feel is best.
For the curious on this thread the quarter window application tape is 3M part number 06450 1/8" thick by 1/2" Wide. Its a Urethane double coated tape.
Report this Post02-17-2020 10:42 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
It has been done a few times, but for me is just doesn't look right without the transition between surfaces.
You could bond/fiberglass in some attachment studs to the backside of the quarter window and use those for a more positive attachment and keep the smooth look on the face.
Habanera Hal
Report this Post02-17-2020 06:12 PM Click Here to See the Profile for Habanera HalSend a Private Message to Habanera HalEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like those wheels. What are they?
And, like Raydar said about the scoops, I wouldn't mold them in. You would lose the graceful line from the top of the window down to the rear deck.
Spadesluck
Report this Post02-17-2020 08:59 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the input guys, greatly appreciated.
Habanera Hal, the wheels are XXR 555's. I am running a 17/18 combo.
Spadesluck
Report this Post02-17-2020 09:01 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spadesluck
Member since Jul 2016
I will look into doing that. Glassing in a decklid hood scoop right now. So I am at least getting my fill with fiberglass work.
