  Parking brake piston: OK or replace?
Parking brake piston: OK or replace? by pmbrunelle
Started on: 01-03-2021 10:07 PM
Replies: 3 (456 views)
Last post by: pmbrunelle on 01-11-2021 09:25 PM
pmbrunelle
Total ratings: 63
Report this Post01-03-2021 10:07 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
As part of a preventative (I noticed no symptoms from the driver's seat perspective) brake rebuild, I took apart a set of rear brake calipers.
On one of the pistons, the metal cap is slightly caved in on the edge by about 0.030":
Good to go ahead and use the piston as-is, or replace?
Can I take this apart, and flatten this with a hydraulic press?
This piston is from a Cadillac Seville caliper.
[This message has been edited by pmbrunelle (edited 01-03-2021).]
Report this Post01-04-2021 02:37 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Likely someone drop the part. Nothing in the caliper should touch the cap except the large spring you see pulling the piston.
Directly under the "cap" is a BB set w/ two thin "washers" as upper and lower races.
See my Cave, Rear Piston notes
Bend the cap can be problems for P-brake and self-adjust as the BB maybe bad.
Taking apart the piston isn't a great idea either even w/ "internet" saying can rebuild a iffy piston. Worse likely some rebuilder already torn it apart 1 to several times weakening the cap.
pmbrunelle
Total ratings: 63
Report this Post01-04-2021 11:24 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
10-4
I'll get another one.
pmbrunelle
Total ratings: 63
Report this Post01-11-2021 09:25 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I couldn't buy just the piston, so I bought an entire Cardone caliper just to cannibalize its piston.
Its cap was slightly dented as well (but much less pronounced), but I just pried it a bit (from the outside, no disassembly required) with a screwdriver so the bearing race sat flat on the cap.
I removed the vent plug from the piston pictured above, and I found that it was wet with brake fluid inside, so I guess it was needing replacement anyway.
