  Rocker panel push-pin clips
Rocker panel push-pin clips by Skybax
Started on: 04-27-2021 09:52 PM
Replies: 11 (226 views)
Last post by: fierosound on 04-29-2021 12:59 AM
Skybax
Total ratings: 78
Report this Post04-27-2021 09:52 PM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can somebody point me in the right direction for the plastic clips that attach the bottom of the plastic rocker panel to the metal body near the coolant tubes, thanks.
Total ratings: 465
Report this Post04-27-2021 10:03 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
An alternative is to use short bolts (and nuts/washers of course). I've done it this way to several Fieros, and it works just fine.
Skybax
Total ratings: 78
Report this Post04-27-2021 10:44 PM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for suggestion... I'm trying to keep it stock / original.
Total ratings: 465
Report this Post04-27-2021 10:47 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
No problem, I understand. To me it isn't as critical, especially in a location that no one will ever notice.
fierosound
Total ratings: 287
Report this Post04-27-2021 11:55 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Molding clip and plastic rivet kits.
https://www.fierostore.com/...rowse.aspx?d=308&p=1
Plastic rivets are across the bottom in what looks like the "pinch weld".
https://www.harborfreight.c...ly-rivets-97757.html
[This message has been edited by fierosound (edited 04-28-2021).]
Total ratings: 465
Report this Post04-28-2021 12:00 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
CLICK FOR FULL SIZE
Tony, just out of curiosity... where in that diagram are the rivets that the OP is referring to?
[EDIT] Ah, that added diagram does the trick!
[This message has been edited by Patrick (edited 04-28-2021).]
Total ratings: 154
Report this Post04-28-2021 08:32 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used Pop Rivets, but the problem I had is that they wouldn't expand enough to grab onto the pinch weld. My solution was to use some aluminum washers on the backside. The center of the washers was just large enough to slip over the rivet so the rivet would expand and grab it. I have also used the nylon pop rivets on one car. Bought them at Fastenal. I've even used the ribbed push-in type fasteners. As long as the panel is properly attached in the sill, they hold very well and are easily removed if needed. The problem with the fasteners going in the sill is that the head is usually too large a diameter and must be trimmed down so they will fit down into the trim plate slot. Slotted push-ins work well for this area, also.
[This message has been edited by fierofool (edited 04-28-2021).]
Total ratings: 154
Report this Post04-28-2021 08:36 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Jan 2002
That added diagram is a little deceptive in its appearance because it's a ghost image, showing the lower flange through the side of the rocker panel. It looks like the rivets (#3) go up in the side of the panel rather than on the extreme lower lip.
Skybax
Total ratings: 78
Report this Post04-28-2021 08:20 PM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the replies, I looked at Fiero Store before posting topic and they didn't have them.
In both diagrams shown above neither one shows the rivets at the bottom of the rocker.
I might have found a few, still waiting to hear back from them...
Total ratings: 465
Report this Post04-28-2021 08:50 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
As has already been pointed out by fierofool, #3 in the second diagram posted by fierosound are the rivets you're referring to.
Skybax
Total ratings: 78
Report this Post04-28-2021 09:12 PM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Agreed, the diagram is an optical illusion, had to stare at it full a full minute to process.
fierosound
Total ratings: 287
Report this Post04-29-2021 12:59 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
