   Stant Fiero Part Numbers
Stant Fiero Part Numbers by theogre
Started on: 07-05-2023 10:20 AM
Replies: 0 (126 views)
Last post by: theogre on 07-05-2023 10:20 AM
Report this Post07-05-2023 10:20 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many now know Stant sold the aftermarket to MotoRaid... So can't find data on Stant site.
Even before that Stant had most 80's and older in a "Vintage Guide" not in current catalogs and worse MotoRaid dropped/change many numbers.
Important because This data can help checking PN for New Old Stock... Plus Stant had another PN system that does equate to these.
Example: An old Gas Cap w/ PN G 817 and BG 817 on "blister pack" card found at a Flea Market is OE Equivalent Fuel Cap PN 10817
Often Last 2 or 3 digits don't change but any "prefix" can/did for type of packaging used, Cards, Boxes, etc, or other reasons.
Below are all Fiero listings as publish in that Guide. (Yes, I know most if not all are repeat numbers.)
code:
Fiero
4-Cyl. 2.5 L
Application Part PSI
Number
1988; Lev-R-Vent Radiator Cap ..................... 410330 16
1988; OE Type Radiator Cap ........................ 10230 16
1988; Thermostat Housing Cap ...................... 10232
1988; OE Equivalent Fuel Cap ...................... 10817
1988; Pre-Vent Non-Locking Fuel Cap ............... 10819
1988; Regular Locking Fuel Cap .................... 10591
1988; Pre-Vent Locking Fuel Cap ................... 10501
1988; Oil Filler Cap; W/Threaded Filler Neck ...... 10104
1988; Oil Filler Cap; W/O Threaded Filler Neck .... 10066
1987-1985; Lev-R-Vent Radiator Cap ................ 410330 16
1987-1985; OE Type Radiator Cap ................... 10230 16
1987-1985; Coolant Recovery Tank Cap .............. 10236
1987-1985; Thermostat Housing Cap ................. 10232
1987-1985; OE Equivalent Fuel Cap ................. 10817
1987-1985; Pre-Vent Non-Locking Fuel Cap .......... 10819
1987-1985; Regular Locking Fuel Cap ............... 10591
1987-1985; Pre-Vent Locking Fuel Cap .............. 10501
1987-1985; Oil Filler Cap; W/Threaded Filler Neck . 10104
1987-1985; Oil Filler Cap; W/O Threaded Filler Neck 10066
1984; Lev-R-Vent Radiator Cap ..................... 410330 16
1984; OE Type Radiator Cap ........................ 10230 16
1984; Thermostat Housing Cap ...................... 10232
1984; OE Equivalent Fuel Cap ...................... 10817
1984; Pre-Vent Non-Locking Fuel Cap ............... 10819
1984; Regular Locking Fuel Cap .................... 10591
1984; Pre-Vent Locking Fuel Cap ................... 10501
1984; Oil Filler Cap; W/Threaded Filler Neck ...... 10104
1984; Oil Filler Cap; W/O Threaded Filler Neck .... 10066
V-6 2.8 L
16 is Radiator Cap PSI Rating. While FSM et al "books" say 15psi, most replacements are 16psi. It doesn't matter as cap can be between ~ 14 to 17 and still be in spec.
The data was corrected by Stant for Fiero part numbers for the non-vented caps.
L4 Oil Cap had 2 types... Old "1/4 turn" and Threaded. The Threaded ones typically only fit Replacement Valve Covers sold thru Dorman and others for many years.
I Found the PDF on an old HD today. Been searching online w/ no hits for several years. And No Archive.org doesn't have it when search old Stant web pages.
