  Fool Everybody. Stereo looks stock, sounds great. (Page 1)
Fool Everybody. Stereo looks stock, sounds great. by fierosound
Started on: 04-05-2007 10:52 AM
Replies: 186 (35359 views)
Last post by: FieroJuice on 12-19-2015 09:06 PM
fierosound
Total ratings: 286
Report this Post04-05-2007 10:52 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've installed an updated system in my 84 project car (OK - it's an Indy).
I wanted a stock look and much better sound without building an all-out system like I have in my 87 GT.
One of the first things to do is gut the interior and install soundproofing of some type.
This will quiet the car from road noise and greatly improve the acoustics and efficiency of your stereo system.
There's various products around like Dynamat and it's competitors and some people also use peel 'n stick roofing materials with success.
Don't forget to cover the back of your door panels.
I'm using Infinity component speakers in the front dash and Clearwater Audio Headrest Speaker sets in the seat headrests.
The in-dash 2000+ Pontiac Monsoon CD player will power all the speakers.
For the subwoofer, I'll be using a very small Xtant 1.1i 100 watt mono amp to drive a subwoofer in a stock Fiero sub-housing.
I'm using the TANG BAND W5-1138SM 5-1/4" Neodymium Subwoofer from Parts Express in the housing.
FRONT DASH SPEAKERS
I wanted a high quality component set in the dash and chose the Infinity 50.7CS component set.
The woofers have the compact high efficiency neodymium magnets with heat sinks.
The Infinity set comes with passive crossovers (2 wires in, 4 wires out), 2 to the woofer, 2 to the tweeter.
With the set's very high 94db efficiency rating, it works very well with factory deck power.
http://www.infinitysystems....ountry=US&Region=USA
This is how the Infinity components fit into the 4"x10" dash opening.
5.25" woofer and 1" tweeter on a speaker plate made from 3/16" hardboard.
I've done up a template that can be used to cut out dash plates. The hardboard can be pretty fragile,
especially around the 5.25" cutout, so alternative materials such as 1/4" ABS plastic would be better.
This file is in MS Word format and will print in proper scale on regular letter sized paper.
There's a Bar Scale in the left corner. If it matches up to a ruler, it has printed properly.
DOWNLOAD the file from here: http://www.fierosound.com/speaker%20plate.doc
HEADREST SPEAKERS
Many have replaced their stock headrest speakers with aftermarket 4ohm speakers.
Looking at the Fiero manual wiring diagram, the headrest speakers are clearly wired in parallel.
This will create a very low 2ohm load using 4ohm aftermarket speakers
(stock were 10ohm creating a safe 5ohm load) and could eventually damage your factory deck's amplifier.
I replaced the seat?s headrest speakers in my 84 project car with a set of
Clearwater Audio Miata headrest speakers. http://www.clearwateraudio.com/product.html
Clearwater Audio now has a Fiero headrest speaker set (they can be bought on eBay as well).
They created a new part number CWC-3F (F for Fiero) and added the correct connectors so it's just a plug and play installation (once you get the seat apart).
They are 3-1/2" 2-way speakers with the correct power rating for a stock deck (10-25 watts) and 7-8 ohms each.
These will work with the stock wiring with no changes other than an inline bass cap (optional) and it won't overload the amplifier.
When your order the Clearwater Audio headrest speakers, here's what you can expect.
What you get in the box - 4 high quality speakers, well packed.
The speakers already have a pigtail with the correct connector to plug into the existing harness in the seat.
The connector makes installing the speaker a simple "plug 'n play". I checked, and the polarity is correct.
Here's how the Clearwater Audio speakers compare to the stock Delco headrest speakers.
Here they are pressed into the foam of the headrests. It works, but GM could have found a better way to install these.
For anyone who's never had their seats apart, here's how to do it. http://www.mrmikes.com/fierospeakers.htm
SUBWOOFER SYSTEM https://www.fiero.nl/forum/Forum3/HTML/000079.html
The Fiero Store sub-housing just bolts into the Fiero since it's a factory duplicate.
If you have an 86 or newer, your heater box should already have the correct support bracket that supports the Convenience Center
(chime box, flasher etc) as well as the sub-housing. I had a Dickman sub at first, but saw this thread and decided to try the Parts Express
sub as mentioned by Bigfieroman. https://www.fiero.nl/forum/A...090219-2-076432.html
BIG improvement, especially since I am running 100 watts vs the stock amp's 20-25 watts.
This picture shows how the Fiero subwoofer box is mounted. I was using it without the tube and with a Dickman sub at the time, but later changed that.
Because the tube is tuned for the stock speaker, it needs to be modified to match the new speaker's specs. Cut off 2 inches from the end.
The housing is slightly undersize, so loosely stuff it and the tube with poly fiberfill (cheap at Walmart) to make it work better. This is how the stock subbox sits behind the dash.
I purchased the TANG BAND W5-1138SM 5-1/4" Neodymium Subwoofer from Parts Express
http://www.partsexpress.com...?&Partnumber=264-831
Here's a comparison of the Rodney's replacement sub to the larger Tang Band subwoofer
Don't let the small magent fool you. It's a Neodymium magnet - more efficient, more powerful and can therefore be smaller but producing
the same power as the large regular iron core magnets. Not sure why more manufacturers aren't using the Neodymium magnets.
Probably because the BIG magnets are not only cheaper, but more impressive looking to the unknowing buyer who thinks "bigger is better"???
I made a mounting ring from 3/4" MFD. The edges were coated with silicone (to seal)
before slipping it in and attaching it through the sides with screws. Pre-drill the holes or the MDF will split.
The subwoofer attaches to the front. The stock grill will no longer fit, so I used the mounting ring and grill from the
Infinity speaker (sanded and painted Satin Black) to protect the subwoofer.
Not my car - found this video on YouTube - recorded with a cell phone I think.
Unfortunately, a YouTube video doesn't give you the "in the car" sound and feel.
DECK, ADAPTERS AND SUBWOOFER AMPLIFIER
A 2000+ Pontiac Monsoon CD player replaces the stock radio/cassette unit.
I'll be using an Xtant 1.1i 100 watt mono amp to drive a subwoofer in the stock housing.
The Xtant amp is 6.5" x 5.7" x 1.6" high which will fit under the passenger seat out of the way.
This tiny amp really delivers and is perfect for the job.
Amp specs http://www.xtant.com/archiv...oducts/xtant1.1i.cfm
Comparison of the amp size to the deck.
I purchased a Delco radio adapter harness (simplifies A LOT) to connect the new Delco to the Fiero?s wiring harness.
I made all my new connections in this harness so as not to modify any of the car?s wiring.
The NE-7V adaptor taps the signals from the front speaker wires and provides 2 RCA level outputs (left/right) that will run the subwoofer.
These will connect to the adjustable PFMOD LP-1 Low Pass crossover (set to 133Hz) which sends a mono signal to the Xtant subwoofer amp which then powers the subwoofer.
I also soldered the bass caps for the headrest speakers in the adaptor harness as well.
Amp with Low Pass filter and line output adapter wired to the radio adapter harness
NE-7V adapter http://www.davidnavone.com/adaptor_products.htm
PFMOD LP-1 crossover http://store.hlabs.com/pk4/...e.pl?view_product=26
I have the thing working - the sound quality of the Delco radio tuner could be better.! I was starting to think this whole setup was a waste until I played some CDs and connected my MP3 player. I ripped my MP3s at 256Kbps which is pretty close to original CD quality (320Kbps is better yet, but the files get REALLY big). Awesome sound playing CDs and MP3s through the system. Not as great as the setup in my GT, but still impressive for something that looks all stock. The MP3 is connected with a Peripheral Integrated Electronics (P.I.E.) GM9-AUX auxiliary input interface. This allows connection of any MP3 player through the CD Changer Aux. port on the back of the Delco player. There is also an iPod specific interface available from P.I.E. http://www.peripheralelectronics.com
I was experimenting with the settings on the PFMOD LP-1 Low Pass Crossover for the subwoofer. I tried it at 89Hz but found that 133Hz worked better, allowing the sub to produce more midbass. I had installed Bass Blockers (capacitors) inline to all the speakers to cut the lower frequencies.
When you have a subwoofer in your system, you usually want to decrease the amount of bass going to your mid-range speakers (tweeter will already be crossed-over). This will give your speakers better mid-range and high end sound and increase their power handling while reducing distortion by rolling off the bass before it gets to your mid-range speakers.
To do this, you use a "bass blocker" (high pass filter), a capacitor placed in series with the speaker input. It blocks the lower frequencies, and allows the higher frequencies to pass through. Bass blockers are installed in series, one end connected with the positive lead from your amplifier and the other end connected to the positive lead of each of your speakers. Bass blocker capacitors are available at any Radio Shack, eBay, Crutchfield etc. or parts supply house. You could also use an electronic crossover to filter the signal, but using capacitors keeps it simple.
I used capacitors inline before the 2-way crossovers to the front speakers which block frequencies below 50Hz. At present this seems to be a good crossover point for the Infinity component set with the subwoofer. For the headrest speakers, I used caps which block frequencies below 100Hz. I installed these inline behind the radio in the adapter harness rather than at the harness connecting to the seats.
Use 50-100 Volt Capacitors - Values for 2/4/8 ohm speakers.
Polarized or non-polarized will work, but be sure to install polarized capacitors in right direction.
HOW DOES ALL THIS SOUND?
Since my subwoofer setup gets its signal off the front channels, switching the fader completely to REAR headrest speakers only, eliminates the front speakers and all subwoofer output, so there is no mid-bass or bass at all. Playing the headrest speakers only, with a cutoff at 120Hz (with the bass blockers) you are only playing midrange and higher. The speakers reproduce this very clearly and can produce quite a bit of volume without distortion. BUT, you?d never be listening to the system with this setting except for testing purposes.
By nudging the fader toward the front very slightly, I got the subwoofer to come in and a very low volume from the front speakers. In fact I had to lean up to the dash to hear them at all. At this setting I was basically listening to the headrest speakers and bass/mid-bass from the subwoofer. This immediately "fills out" the sound immeasurably - and oddly enough, it "sounds" like the mid-bass is coming from the headrest speakers!
With the fader set "dead center" I found that the front/rear balance is exactly correct when sitting normally. I listened to all kinds of music for almost an hour, including Big Band, drum solos, country, heavy metal, and rock and roll. The front sound stage is full, wide and complete without the ?center hole? of the stock system. At first you think the headrest speakers aren't working at all, but as soon as your turn your head slightly, you'll hear that headrest speaker right away. While looking straight ahead (as you normally would), the overall ?concert hall? effect is excellent.
I would recommend both the Infinity component set and the Clearwater Audio headrest speakers. The Parts Express subwoofer is a big improvement over a stock subwoofer, and I would recommend this easy upgrade for people wanting more bass without building trunk or firewall subs. The newer Delco CD decks fit and look great and will connect and play MP3s with the appropriate adapters, which makes large bulky CD Changers pretty much obsolete.
Bottom line ? I'm VERY happy with the results, and that's saying a lot, because I'm comparing it to my "other system" in my 87 GT. Total cost for everything was about $1100 - but it sounds like MUCH more.
[This message has been edited by fierosound (edited 08-09-2020).]
Pyrthian
Total ratings: 342
Report this Post04-05-2007 11:13 AM Click Here to See the Profile for PyrthianSend a Private Message to PyrthianEdit/Delete MessageReply w/QuoteDirect Link to This Post
awesome job! looks natural - and I bet it sounds great!
F-I-E-R-O
Total ratings: 294
Report this Post04-05-2007 12:29 PM Click Here to See the Profile for F-I-E-R-OSend a Private Message to F-I-E-R-OEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can't tell you how much I appreciate your posting this! A + for you and a stick in the eye of who ever gave you a neg- I see a sliver of red... on the other hand, without it you'd probably just be a robot.
fierosound
Total ratings: 286
Report this Post04-05-2007 12:51 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. I've posted all this information in different threads before. I just pulled everything together into one place so it's easier to get a sense of the whole system.
[This message has been edited by fierosound (edited 04-05-2007).]
fierosound
Total ratings: 286
Report this Post04-05-2007 03:06 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierosound
Member since Nov 1999
[This message has been edited by fierosound (edited 04-11-2007).]
tjm4fun
Total ratings: 141
Report this Post04-05-2007 06:18 PM Click Here to See the Profile for tjm4funSend a Private Message to tjm4funEdit/Delete MessageReply w/QuoteDirect Link to This Post
good post. nice tying together of all you;ve done. one thing you did really well was making that total end seal mount for the subwoofer, without that, I doubt you would have had as much success. I am now making an additional post ot big fieroman;s thread now on my fix this morning.
rogergarrison
Total ratings: 551
Report this Post04-05-2007 06:37 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just keep it turned down when driving or someone else might like the sound and borrow it from you some night.
Quickster
Report this Post04-06-2007 06:52 AM Click Here to See the Profile for QuicksterSend a Private Message to QuicksterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting post! I'm curious about the "Clearwater" Speakers. "Made in Folsom"? (By Convicts?) Hmmmmmmm?
Mister
Total ratings: 56
Report this Post04-06-2007 08:09 AM Click Here to See the Profile for MisterSend a Private Message to MisterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great right-up Soundman, good info
Pyrthian
Total ratings: 342
Report this Post04-06-2007 10:15 AM Click Here to See the Profile for PyrthianSend a Private Message to PyrthianEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am wondering about why you closed the subwoofer port?
I would think that with a larger speaker, requireing MORE cabinet space, closing the port would be going backwards, and if anything, making a larger port would be the right way to go?
Mickey_Moose
Total ratings: 144
Report this Post04-06-2007 10:47 AM Click Here to See the Profile for Mickey_MooseClick Here to visit Mickey_Moose's HomePageSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tony, thanks for the post all in one spot.
fierosound
Total ratings: 286
Report this Post04-06-2007 10:49 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's more complicated than that. The speakers' specs determine what you can do. Some 10" subs will work very well in a .5 cu/ft sealed enclosure. Others require a 3-5 cu/ft (think bar fridge) ported enclosure for maximum bass extension. None are perfect because all have their pros and cons.
To use a speaker in a ported box requires more things. Generally the enclosure is bigger and harder to build properly. The port has to be tuned for the speaker and enclosure (diamater and length).
More here: http://www.diysubwoofers.org/prt/ http://www.the12volt.com/caraudio/boxcalcs.asp
Here we're working with an existing enclosure. This Tang Band subwoofer speaker's specs call for a SEALED enclosure volume of .19 cu/ft. The Fiero sub-housing is just under at about .16 cu/ft which is why we stuff polyfill into the enclosure. It works very well. The bass is tight and crisp, but obviously not a low as it would be possible with a 10" or 12" speaker. There's compromises to be sure, but this exercise is to get more with what you have. For MORE bass, you'd need to build behind-the-seat or trunk-mounted subs.
Parts Express has a good charts of the woofers and subwoofers they have:
http://www.partsexpress.com...indexes/sb_guide.cfm
[This message has been edited by fierosound (edited 04-06-2007).]
Mickey_Moose
Total ratings: 144
Report this Post04-06-2007 10:49 AM Click Here to See the Profile for Mickey_MooseClick Here to visit Mickey_Moose's HomePageSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
double post
[This message has been edited by Mickey_Moose (edited 04-07-2007).]
Pyrthian
Total ratings: 342
Report this Post04-06-2007 11:02 AM Click Here to See the Profile for PyrthianSend a Private Message to PyrthianEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks - I was thinking more in overall general term - but, since you actualy knew what the speaker wants - that is absoloutely the way to go.
fierosound
Total ratings: 286
Report this Post04-11-2007 12:20 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I see a pair of Xtant 1.1i 100 watt amps on are eBay. If you want good subwoofer power, I recommend these high quality amps.
http://cgi.ebay.com/Xtant-1...QQrdZ1QQcmdZViewItem
[This message has been edited by fierosound (edited 03-26-2010).]
LZeitgeist
Total ratings: 126
Report this Post04-11-2007 03:40 PM Click Here to See the Profile for LZeitgeistSend a Private Message to LZeitgeistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, this is a TERRIFIC thread! Thank you for posting it, taking pics, giving directions, etc. - great job!
Patrick W. Heinske -- LZeitgeist@aol.com
1988 Red Fiero Formula Convertible
*Desktop Photo Here* (click either link for pics)
musicman_L7
Report this Post04-11-2007 07:13 PM Click Here to See the Profile for musicman_L7Send a Private Message to musicman_L7Edit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice write up!
Nic
Beware the toes you step on today, for they may be attached to the ass you must kiss tomorrow.
Proud member of MIDWEST FIEROS!
Xanth
Total ratings: 174
Report this Post04-11-2007 07:49 PM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you very much for this post, I hope you don't mind If I copy you
www.FieroDomain.com
Over 120 Fiero Links, Articles, Images, Diagnostics
"If any car is both the parade and the rain, it is the Fiero"
timgray
Total ratings: 59
Report this Post04-11-2007 08:57 PM Click Here to See the Profile for timgrayClick Here to visit timgray's HomePageSend a Private Message to timgrayEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would add one more suggestion, stuff the subwoofer box with a loose poly fill it will round out the sound better. if you had the right software you could have figured out what changes to do to the port to correct it for that woofer, I am betting that extending it another 3 inches would have done the trick just by guessing at the woofer. best thing would have been to get a piece of pvc that slipped over the origional port and then "tune" it to the car by sliding it out and finding the sweet spot for your car and woofer.
Also another improvement would have been to fiberglass a band around the stock box to stiffen it. that stock box flexes all over the place and that is actually bad for bass response. stiffen the box, polyfill and a tuned port can make it rock even better.
Dirty Harry
Report this Post04-11-2007 09:28 PM Click Here to See the Profile for Dirty HarrySend a Private Message to Dirty HarryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great timing! Have the radio installed & will be installing factory sub & speakers soon when I get my car back from Loyde. I don't have speaker seats so would really appreciate a recommendation for suitable 4x6 speakers. Thanks & a + for you.
87 GT Maroon, Red Formula & White Formula
alex de jorge
Report this Post04-12-2007 08:02 AM Click Here to See the Profile for alex de jorgeSend a Private Message to alex de jorgeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Harry,
I have some speaker seat that we can talk about. Let me know.
Alex (CFF)
fierosound
Total ratings: 286
Report this Post04-12-2007 09:00 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not at all. That's why we post all this stuff...
Don't get a co-axial. Get a high quality 4"x6" plate from Infinity, Polk Audio etc.
fierosound
Total ratings: 286
Report this Post04-12-2007 09:27 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierosound
Almost forgot, a great diagram for new/old radio wiring here:
http://www.installdr.com/Harnesses/GM-Wiring.pdf
[This message has been edited by fierosound (edited 04-12-2007).]
clok1966
Report this Post04-25-2007 12:37 PM Click Here to See the Profile for clok1966Send a Private Message to clok1966Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dont by the 4X6 plates form Infinity, they do not fit. The magnets ont eh back are to large to fit without cutting or some major spaceing. I put a set in and they do go behind the panels, but its a huge PAIN unless you are good at fabricationg stuff. I would say you need a 3/4 to 1" spacer to make them fit correctly. Or am I just not doing it right?
Clok
fierosound
Total ratings: 286
Report this Post04-25-2007 02:54 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe they have more than one model of 4x6 plate. Which model of did you use? "helmet1978" has Infinity installed here.
This is his picture from here https://www.fiero.nl/forum/Forum2/HTML/080031.html
[This message has been edited by fierosound (edited 04-25-2007).]
88formulaman
Report this Post04-25-2007 03:28 PM Click Here to See the Profile for 88formulamanSend a Private Message to 88formulamanEdit/Delete MessageReply w/QuoteDirect Link to This Post
the infinity 4x6 plates fit mine almost perfectly
only slight trimming with a die grinder to allow the magnet to fit in the hole.
Glenn Lintemuth
A&P Mechanic
Colorado Springs, CO
88' Convertible "BeyondGT"
88' GT, white 5speed
89' K-5 Blazer on 44's
04' Silverado Ext Z71 on 33's
[This message has been edited by 88formulaman (edited 04-25-2007).]
fierosound
Total ratings: 286
Report this Post04-30-2007 01:12 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Xanth
Total ratings: 174
Report this Post04-30-2007 05:55 PM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've got a quick question for you, what Is a reasonable price for one of those headunits? I've seen them around on eBay, but for nearly $300. Is that normal or am I just looking wrong?
www.FieroDomain.com
Sourmug
Total ratings: 144
Report this Post04-30-2007 08:14 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK, you can help me with my sterio install
Nice thread!
Nolan
RWDPLZ
Total ratings: 305
Report this Post04-30-2007 08:56 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kru sells them on here for $150-200. I got mine at a junkyard for $45 becuase the display didn't work (burnt out display bulb).
1984 Fiero SE
fierosound
Total ratings: 286
Report this Post05-01-2007 09:09 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got mine from KRU as well. Not all Delco units have a functional Aux port that will allow use of an adapter for connection of an MP3 player. Those run in the $150-200 range.
I got the Monsoon unit so I could connect my MP3 player. It was $249 http://replacementradios.co...h=23&products_id=227
[This message has been edited by fierosound (edited 05-01-2007).]
ohio86se
Total ratings: 52
Report this Post05-01-2007 10:13 AM Click Here to See the Profile for ohio86seClick Here to visit ohio86se's HomePageSend a Private Message to ohio86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fierosound,
How did you inerface the stock Fiero sub slider with the subamp? or did you?
" DRIVE IT LIKE YOU LOVE IT"
ambfiero
Total ratings: 103
Report this Post05-01-2007 03:57 PM Click Here to See the Profile for ambfieroSend a Private Message to ambfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, what ohio86se said.....
In loving memory of Harold Hummel (PFF 4WHEEL)
1936-2004
fierosound
Total ratings: 286
Report this Post05-01-2007 05:05 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
My car never had one. That's also why I have an aftermarket amp.
BobadooFunk
Total ratings: 128
Report this Post05-01-2007 09:32 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
seeing as i know nothing about audio, do round speakers sound better?
fierosound
Total ratings: 286
Report this Post05-18-2007 10:11 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup. You won't notice it at low and "normal" volumes, but as you push the volume to higher levels, oval speakers tend to distort because the cones don't move evenly. This in turn distorts the sound quality. Often people think the distortion is because they don't have enough power, when in fact their speaker is the problem.
FieroWannaBe
Report this Post05-18-2007 10:44 AM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
how would one go about wiring the pillar speakers and headrest speakers?
fierosound
Total ratings: 286
Report this Post05-18-2007 04:38 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wouldn't do it myself because you're going to get strange staging and some weird impedance loads unless you're running external amps or something https://www.fiero.nl/forum/Forum2/HTML/079932.html
Maybe someone who's done this can chime in.
FieroWannaBe
Report this Post05-19-2007 10:49 AM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since I really know extremely little about circuits, and audio systems, (I'm pretty much failing my circuits class FYI) It would be possible to wire ti up 6 channel wouldn't it, Anybody know of any 6 channel decks? I know my roommates Firebird has 6 channel sound, how are those wired, do they use special decks or amps?
PROJECT 1986 GT Stormbringer
carbon
Total ratings: 132
Report this Post05-20-2007 05:58 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you do something to increase the impedance of the components? The info I saw said they were 2 ohm... isn't that a little rough on the head unit?
