  The Mall
  fieroguru 13" Brake Upgrade for 88 Fieros - $100 off until 4/1/2016
fieroguru 13" Brake Upgrade for 88 Fieros - $100 off until 4/1/2016 by fieroguru
Started on: 03-13-2016 07:03 PM
Replies: 13 (894 views)
Last post by: fireboss on 04-03-2016 02:39 AM
Total ratings: 259
Report this Post03-13-2016 07:03 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had previously announced that Fieroguru Performance would reopen on April 1, 2016... but with a lot of effort in the past couple of weeks, I have everything in place to start offering my 13" brake kits for sale as of today.
As a customer appreciation gesture and to apologize for this kit being unavailable for the past year while I relocated, my 13" brake kits will be $100 off full car kits ($50 off front or rear only versions) until 4/1/2016.
My goal in developing this kit was a clean sheet approach to find the best fitting rotor for the 88’s that will maximize braking force by increasing the diameter of the rotor while keeping the rest of the brake system stock to ensure proper brake bias and parking brake function. You can read more about the development of this kit in late 2011 here: https://www.fiero.nl/forum/Forum1/HTML/087368.html
The rotors used in this kit are from the GM Lambda platform (4 rear rotors):
2007-2010 Saturn Outlook
2007-2016 GMC Acadia
2008-2016 Buick Enclave
2009-2016 Chevy Traverse
Some of the key benefits of this kit are:
• Use of stock calipers, brake hoses and parking brake cables keeps cost to a minimum.
• Stock brake bias and parking brake function retained.
• 25% increase in brake rotor diameter for improved visual impact behind 17+” wheels vs. 15% with the 12" C4 setup.
• 33% increase in brake system mechanical advantage due to caliper being further from wheel center vs. 21% with the 12" C4 setup.
• 19% increase in rotor/pad surface area to reduce potential for brake fade vs. 12% with the 12" C4 setup.
• Available in Drilled/Slotted w/Zinc coating to minimize additional weight and improve appearance.
• No interference issues between the rotor/caliper and the front suspension a-arms when used with stock ball joints. NOTE: I do not recommend this kit if you have Rodney's lowering balljoints installed - they cause lower A-arm to rotor interference issues
• Lowest price of any 13” brake kit on the market today.
The downsides of this kit are:
• Weight – this kit will add about 6.5 lbs per wheel over the stock 88 rotor.
• Wheel requirement – this kit requires 17+ wheels
• Cost - this kit is slightly more expensive than the C4 12” rotor upgrade that has been the brake upgrade standard on the 88’s for many years.
The Kit consists of the following parts (shipped in 2 boxes):
• 4 - 13” rotors drilled to the 5x100mm pattern
• 4 – steel caliper brackets to relocate the stock brake calipers, painted semi-gloss black
• 4 – plastic expandable concentric rings
• 8 - grade 10.9 M12 bolts
• 1 – strip of sand paper
• 1 – aluminum brake cable sleeve extension
• 1 – steel brake cable end coupler, painted semi-gloss black
Pricing Summary: All prices shipped for US and Canadian addresses unless noted.
Hardware Kit only – Front:.....................$100 (regular price $150)
Front Only w/ plain rotors:.....................$175 (regular price $225)(+$35 shipping surcharge to Canada) (regularly $225)
Front Only w/ Drilled/Slotted/Zinc Rotors:.$250 (regular price $300)(+$35 to Canada)
Hardware Kit Only – full car:...................$250 (regular price $350)
Full Kit with Plain Rotors:.......................$465 (regular price $565)(+$70 to Canada)
Full Kit with Drilled/Slotted/Zinc Rotors:....$540 (regular price $640)(+$70 to Canada)
*** NOTE: My rotor supplier changes patterns rather frequently, so I can’t guarantee the exact drilled/slotted pattern you will receive unless I have rotors in stock. I will guarantee that all 4 rotors in your kit will be a matched set.
You can drill the rotors for the 5x100 pattern with a 1/2" drill bit and an old wheel bearing with the instructions in this thread:
https://www.fiero.nl/forum/Forum2/HTML/120346.html
Inventory:
I purchase my brackets/ring is quantities of 100 and order the next batch when I get down to 5 full car sets, so I will always have the Hardware and Hardware kits ready to ship.
Rotors will not normally be stocked and ordered as payment is received for the brake kit. It normally takes 2-4 days for the rotors to arrive and 1 day turn around for the drilling and packaging.
Payment:
Payment in full is due at time of order. Your rotors will be ordered the same day and your kit should ship about 5-7 business days from time of order. Payment can be via paypal, postal money order, check (shipment delayed for clearance), or cash. If interested in ordering, please PM me for details.
Paypal email: fieroguruperformancellc@gmail.com
[This message has been edited by fieroguru (edited 03-13-2016).]
FieroMaster88
Total ratings: 168
Report this Post03-13-2016 07:16 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good deal! I still love my 13" brake kit. Huge improvement over stock.
88 Coupe: 2.0L Turbo 4 Cylinder, W2A, T25 Turbo, water/meth injection
84 Indy #64: Restoration Project
01 BMW 525i: daily driver
Total ratings: 461
Report this Post03-13-2016 08:15 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Love mine!
Rock on!
Edit - The guy who did my alignment after I installed guru's Lateral Link kit even noticed them.
"Those brakes are bigger than the ones I have on my truck!"
I was amused.
[This message has been edited by Raydar (edited 03-13-2016).]
Fierofreak00
Total ratings: 170
Report this Post03-15-2016 06:39 AM Click Here to See the Profile for Fierofreak00Send a Private Message to Fierofreak00Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm in for a set, check your PM's -Jason
oldrock2401
Report this Post03-17-2016 06:42 AM Click Here to See the Profile for oldrock2401Send a Private Message to oldrock2401Edit/Delete MessageReply w/QuoteDirect Link to This Post
Now what about us 84-87 guys . Wish I had an 88 simply for the easy brake upgrades.
sluppy123
Report this Post03-20-2016 04:58 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Send me a PM I can hook you up!
Same thing as above but on my 87GT
Danyel
Total ratings: 171
Report this Post03-20-2016 05:11 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
You should do a sale thread ....... that kit would be a HOT seller !! GLWS
Danyel
Black Widow Build Thread 2007 - 2014 Tylers Toy
My Low Profile Buckets for sale My LED Sidemarkers for sale
[This message has been edited by Danyel (edited 03-20-2016).]
Total ratings: 259
Report this Post03-20-2016 05:21 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am not doing anything with 84-87 brake upgrades...
Total ratings: 259
Report this Post03-21-2016 07:11 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Congrats on fitting the GM Lambda platform rotor to the 84-87! I started working on that setup a few years back: https://www.fiero.nl/forum/Forum1/HTML/091924.html
My hope was to have a single set of rotors that worked for both the 84-87 and 88's, but I wasn't able to find a simple/elegant/low cost solution for the 84-87 that I was happy with and eventually abandoned the project. At this point, I have no intentions of doing any further brake development or supplying supplemental brake parts for the 84-87.
88's are my primary focus and will support and encourage you in marketing this 13" 84-87 brake kit.
Paul
fireboss
Total ratings: 58
Report this Post03-23-2016 01:32 AM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
Paul
Now that just shows CLASS..
fireboss
Total ratings: 58
Report this Post03-24-2016 10:30 AM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
just sent payment to your P/PAL....
p.s. --how much more to paint them rotors black ..?
[This message has been edited by fireboss (edited 03-24-2016).]
fireboss
Total ratings: 58
Report this Post03-25-2016 02:07 AM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
just hit your P/PAL for those black zinc ones...
Total ratings: 259
Report this Post03-28-2016 08:17 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump!
fireboss
Total ratings: 58
Report this Post04-03-2016 02:39 AM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
got mine early sat mourning!!
