  The Mall
  1985 Fiero GT 4.9L
1985 Fiero GT 4.9L by DPC
Started on: 04-19-2017 01:47 PM
Replies: 11 (821 views)
Last post by: DPC on 05-10-2017 10:26 AM
DPC
Report this Post04-19-2017 01:47 PM Click Here to See the Profile for DPCSend a Private Message to DPCEdit/Delete MessageReply w/QuoteDirect Link to This Post
1985 Fiero GT 4.9--$3,000
Hello friends on the forum. I have been building this for the past several years, and have become too disabled due to a back injury to finish (or even drive it). I will be retiring soon to California, where I won't be able to register it anyway, so it's time to sell it to someone who can get the most out of it. Below is most of the relevant information. I will be happy to answer any questions as well!
David
4.9L V8--Totally rebuilt with zero time on it
Nice wiring harness installed and plugs labeled.
New injectors
High pressure fuel pump installed in tank
Ceramic coated manifolds
Stainless steel, ceramic coated, and fiberglass wrapped exhaust to keep heat down in engine compartment
4 Speed Standard Transmission
New motor and transmission mounts.
New West suspension with rear coilovers to make room for larger tires
New brakes
Norm's flush mount headlights
Norm's front battery tray
Archie's SBC radiator
Mike's Leather Upholstery
Custom Shifter and center console
LED tail and running lights
New wheels/tires Front--255/40/17, Rear--275/40/18
Still needed:
Minimal engine wiring (all plugs are labeled)
Install distributor
Wire battery and starter
Throttle linkage
Connect/adjust shift linkage cables
Bleed clutch
[This message has been edited by DPC (edited 05-10-2017).]
DPC
Report this Post04-24-2017 05:29 PM Click Here to See the Profile for DPCSend a Private Message to DPCEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
Spadesluck
Report this Post04-25-2017 02:47 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good luck with sale. Do have one question, what rims are those? What offsets did you use?
dratts
Total ratings: 118
Report this Post04-25-2017 10:26 AM Click Here to See the Profile for drattsSend a Private Message to drattsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice!
DPC
Report this Post04-25-2017 11:08 AM Click Here to See the Profile for DPCSend a Private Message to DPCEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm sorry--I can't remember which offset I used. I knew I was going to need offsets that would allow the wider tires to stay tucked inside the fender wells, but I can't recall what I settled on, but they ended up being a perfect fit! I bought the wheels with the tires at Les Schwab (a chain in the Northwest) when I lived in Seattle.
fierobear
Total ratings: 383
Report this Post04-30-2017 04:57 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could we discuss this in an email?
airfiero@gmail.com
stickpony
Report this Post04-30-2017 10:46 PM Click Here to See the Profile for stickponyClick Here to visit stickpony's HomePageSend a Private Message to stickponyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by DPC:
1985 Fiero GT 4.9--$4,000
David
New injectors
who rebuilt it? where did they get new head bolts?
DPC
Report this Post05-01-2017 02:56 PM Click Here to See the Profile for DPCSend a Private Message to DPCEdit/Delete MessageReply w/QuoteDirect Link to This Post
airfiero@gmail.com
Sure! I will send you an email this afternoon.
David
DPC
Report this Post05-01-2017 02:59 PM Click Here to See the Profile for DPCSend a Private Message to DPCEdit/Delete MessageReply w/QuoteDirect Link to This Post
DPC
Member since Aug 2002
There is a shop in Spokane, WA that specializes in Caddy 4.9 rebuilds (recommended by a few shops in Seattle, so I took it over there. Sorry, have no idea who their supplier was.
stickpony
Report this Post05-04-2017 09:55 PM Click Here to See the Profile for stickponyClick Here to visit stickpony's HomePageSend a Private Message to stickponyEdit/Delete MessageReply w/QuoteDirect Link to This Post
any chance you could find out for me? how much did the rebuild cost?
DPC
Report this Post05-10-2017 10:24 AM Click Here to See the Profile for DPCSend a Private Message to DPCEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure, but the rebuild cost $3,100.
DPC
Report this Post05-10-2017 10:26 AM Click Here to See the Profile for DPCSend a Private Message to DPCEdit/Delete MessageReply w/QuoteDirect Link to This Post
DPC
Bump---Price Lowered to $3,000
