  The Mall
  Munson Headlight brighter lights
Munson Headlight brighter lights by thelinsells
Started on: 05-16-2018 12:12 AM
Replies: 4 (311 views)
Last post by: thelinsells on 05-20-2018 08:09 PM
thelinsells
Report this Post05-16-2018 12:12 AM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
High output bulbs to go into the sealbeams. Well the news is the seal beams arn't .The filaments are replaceable.R.T.
Carl Calderone
Report this Post05-17-2018 10:24 PM Click Here to See the Profile for Carl CalderoneSend a Private Message to Carl CalderoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
whats this about????
thelinsells
Report this Post05-17-2018 11:45 PM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
the seal beams in the Munson headlight kit are composit type.That is they can be taken apart.The filament is glued into the glass part with a kind of gasket cement.Judicious use of a pliers with firm even pressure will break the bond.Take your time.Completely clean the glass lens/reflecter.Glue in new filament with a good grade of rtv and your in business.The standard filament high beam is 55 watts.Get one that puts out 65 watts or more.Make sure the base is bent and fits the weatherpack plug .R.T.
IMSA GT
Total ratings: 250
Report this Post05-18-2018 12:36 AM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stan....is that you?
thelinsells
Report this Post05-20-2018 08:09 PM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
No I am not Stan.You mean Stan the motorcycle guy?
