Each Fiero has a different number of bulbs. So there are a variety of kits, so make sure you choose the correct one. These are all plug and play, besides a couple of exceptions that will be noted. Bulbs also just come in white, unless it is an added option. This list can be updated to include more options.
Possible color options: white, orange, red, blue, green, purple.
For placing orders. Contact me at one of the options below with what you are interested in. After I verify I have it in stock and ready to ship, you can send a payment. I typically use Paypal.
Contact me through email preferably at gt1987fiero@gmail. Could use Pennocks PM(I may not see right away).
Ships in 2-3 days depending on availability.
Fiero Interior Light Kits:Gauge Cluster(does not include warning lights):
$15 includes bulbs for voltage and oil pressure. Some clusters have one less bulb, so some of you may end up with an extra bulb. Change color to orange or red +$10
Foam Backing for Gauge Cluster:
Most Fieros have flaking foam in the back of the gauge cluster, and some don't have in completely. Without it, you can experience light bleed with the LEDs(or even stock bulbs). This foam is cut out for the Fieros with an adhesive on that back that makes installation easy.
$15
Flood Lights:
$4 Change to orange or red +$3
Dome Lights:
$20
Ash Trays:
$6 Change to orange or red +$2
Automatic Gear Indicator:
$3 Change to orange or red +$1
Cigarette Lighter:
Heater Control:
Trunk Light:
$4
Front Trunk Light:
$2
Trunk Popper:
$3
**** Not plug and play! Bulb is soldered into the switch and you will have to play around to get it out, as well as putting it back in.
Rear Defrost:
$3
Exterior Kits:PONTIAC on GT models:
$8
Side Markers:
$8
![](https://images.fiero.nl/2017/33367596_1458964640874244_2786406509121110016_o.jpg)
![](https://images.fiero.nl/2017/33159142_1458964590874249_9055729129600581632_o.jpg)
![](https://images.fiero.nl/2017/33159132_1458964467540928_6716783192528912384_o.jpg)
![](https://images.fiero.nl/2017/33163227_1458964677540907_4266801506063220736_o.jpg)
![](https://images.fiero.nl/2017/33161850_1458965750874133_6616031677900652544_o.jpg)
![](https://images.fiero.nl/2017/IMG_1678.jpg)
Orange:
![](https://images.fiero.nl/2017/IMG_1756_1.jpg)
![](https://images.fiero.nl/2017/IMG_1757.jpg)
[This message has been edited by copperhens (edited 01-28-2020).]
