  The Mall
  ****88 Fiero Cradle Brace NOW AVAILABLE!**** (Page 1)
****88 Fiero Cradle Brace NOW AVAILABLE!**** by yamaha94
Started on: 12-09-2019 03:07 PM
Replies: 57 (2048 views)
Last post by: yamaha94 on 04-29-2020 10:46 PM
yamaha94
Report this Post12-09-2019 03:07 PM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
After much work and testing the 84-88 cradle brace has now been reproduced. Confirmed: Fits all years!
Cost - $50 + Shipping (Estimate Currently 15 Canada wide, 20 United States)
*I have some gently used boxes now so shipping is a bit more affordable now - boxes for this bracket size were expensive!*
*going through the list sending DM's if i dont receieve a reply in 48 hours I move to the next person*
Here are a couple pictures of the product. This is for the tranny side of your cradle.
I have fantastic positive feedback and 0 negative feedback.
***UPDATE: We made another batch and are available now!***.
Thanks for your interest!
[img][/img]
[img][/img]
Here is a picture in my 86 GT cradle.
[This message has been edited by yamaha94 (edited 12-22-2019).]
Fiero Vice
Report this Post12-10-2019 03:22 AM Click Here to See the Profile for Fiero ViceSend a Private Message to Fiero ViceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is it to beef up '88 engine crandle?
[This message has been edited by Fiero Vice (edited 05-02-2021).]
yamaha94
Report this Post12-10-2019 06:53 AM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes to strengthen the tranny side of the cradle. Prone to cracking in one spot on swapped cars.
[This message has been edited by yamaha94 (edited 12-11-2019).]
handymanpat
Report this Post12-10-2019 08:16 AM Click Here to See the Profile for handymanpatSend a Private Message to handymanpatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great job, they look super solid!
I will put out the word down here in Texas, I know a couple guys who have done swaps on their 88s.
Pat
pat moody
jjd2296
Report this Post12-10-2019 09:14 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is great! nice job. Question though, are you making these for pre 88 cradles? are they needed for pre 88 cradles or are they stronger in these areas than the 88 cradle?
yamaha94
Report this Post12-10-2019 09:38 AM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
These were technically designed for 88's only. I haven't looked into pre 88's. You can purchase it for pre 88's but there is a possibility it may not fit.
[This message has been edited by yamaha94 (edited 12-10-2019).]
jjd2296
Report this Post12-10-2019 09:47 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok thanks, does anyone know if these can be used on pre 88 cradle?
Fiero Vice
Report this Post12-10-2019 04:35 PM Click Here to See the Profile for Fiero ViceSend a Private Message to Fiero ViceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by yamaha94:
Yes to strengthen the cradle. Prone to cracking in one spot on swapped cars.
What swapped engine would it be good for? 3.4, 3.8 or LS?
No benefit for stock engine? Is there a picture you could show where the cracks tend to occur in one spot?
How much does it weight?
yamaha94
Report this Post12-10-2019 07:17 PM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
I can get a number for you. not much at all.
Here is a similar one sold way back - more info here and pictures. From what I can gather it can work for 84-88 but its more important to 88 cradles. Notorious issue with higher hp engines.
https://www.fiero.nl/forum/Forum4/HTML/064284.html
jjd2296
Report this Post12-10-2019 10:34 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
So how does notorious for higher hp engines equate to 88 cradles only ? I thought pre 88 had the same stock engine and as far as swaps it doesn’t really change between years.
Lilchief
Report this Post12-10-2019 10:43 PM Click Here to See the Profile for LilchiefSend a Private Message to LilchiefEdit/Delete MessageReply w/QuoteDirect Link to This Post
P.M. sent
yamaha94
Report this Post12-11-2019 12:17 AM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
The 88 cradle is very different. Those differences are what causes significant more cases of cracking in combination with a higher HP engine swap is based entirely in the design. I Reproduced this bracket for those members with 88 cradle concerns but the bracket should fit Pre 88 fieros as well per my discussions with some other fiero members on this forum. I havent had a chance to test it on other vehicles and see if there are any changes or issues year by year. One day if I have time I can check. If people are interested in one for a pre-88 fiero i cannot guarantee compatibility or fitment but again I believe it should work. It could be entirely possible that a small modification to the bracket may be necessary to clear any small cradle differences. My concern right now is for people with 88 cradles with higher HP engine swaps. When i mean higher HP engine swaps, im talking 3.8, 3500, 4.9, etc etc. They have a lot of HP and torque and I know many owners with this combination that have cracked their cradle. If you have a smaller engine swapped naturally aspirated, not many changes like a 3.4 for example I can't imagine the HP difference making any significant strain on the cradle. But again, if you want this as an insurance to your car hey go for it stronger is better. Again almost all of the people I know who have these issues have higher HP engines 3.8, 3500, 4.9, etc etc on a 88 cradle hence why I offered this great piece to the group to help them with their issues. You are more than welcome to buy one - just can't guarantee fitment and any improvement for your specific application.
Enjoy
Fiero Vice
Report this Post12-11-2019 12:49 AM Click Here to See the Profile for Fiero ViceSend a Private Message to Fiero ViceEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll take one. PM sent.
jjd2296
Report this Post12-11-2019 06:19 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the clarification much appreciated. I was thinking of these for insurance once I put my supercharger on my 3.4 which will put me in the higher hp range similar to a 3800. Thanks for making these. If you can put me on the list that would be great. At 50 bucks Canadian it’s a no brainer
yamaha94
Report this Post12-11-2019 06:42 AM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
50 U.S.D. Thanks! No problem.
jjd2296
Report this Post12-11-2019 07:00 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Oh ok I see you changed the currency to USD from the original post. Makes sense. I thought 50 Canadian was way too cheap for the time and effort put into doing this. Thanks for doing the fiero community a favour. We need more guys like you! Are you planning on making any other parts?
yamaha94
Report this Post12-11-2019 07:27 AM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. But i am not divulging that information right now. Im working on something right now that has not been made in years.
jjd2296
Report this Post12-11-2019 07:41 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
That’s great can’t wait to hear. Put me down as first in line! If it hasn’t been made in year I probably don’t have it.
yamaha94
Report this Post12-11-2019 09:29 AM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
It has not been made other than OEM.
Fiero Vice
Report this Post12-11-2019 07:17 PM Click Here to See the Profile for Fiero ViceSend a Private Message to Fiero ViceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pmt sent.
yamaha94
Report this Post12-11-2019 09:19 PM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
Shipped 3 orders out...have a 4th one pending...Thanks for the support guys!
jjd2296
Report this Post12-11-2019 09:25 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
I thought you had the orders spoken for? When will I get my email? Or an update when
You ship the next order?
rwholliday
Report this Post12-11-2019 11:44 PM Click Here to See the Profile for rwhollidaySend a Private Message to rwhollidayEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
RobsMuse
yamaha94
Report this Post12-12-2019 04:29 AM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had a list of 17 people, that is now down to 12. I give everyone 48 hours for full payment then if no reply; I move on to the next person. To get on the list, send me a PM. For you its 50 + 15 shipping = 65.00
[This message has been edited by yamaha94 (edited 12-12-2019).]
yamaha94
Report this Post12-12-2019 04:30 AM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
yamaha94
Member since May 2017
Originally posted by rwholliday:
PM sent
never received a PM - please send again
jjd2296
Report this Post12-12-2019 06:09 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
yamaha94
Report this Post12-12-2019 04:48 PM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wow! thanks for the support guys! I am almost sold out in 48 hours.
mrfiero
Total ratings: 150
Report this Post12-12-2019 05:55 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice! Thanks for bringing back a much needed product.
jjd2296
Report this Post12-12-2019 09:19 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Picked mine up today. Great product thanks so much!
yamaha94
Report this Post12-13-2019 05:57 AM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the support! I have ONE left until the next batch is re-made
Total ratings: 460
Report this Post12-14-2019 08:50 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent.
yamaha94
Report this Post12-14-2019 12:27 PM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
Tentatively SOLD OUT!
Don't worry we are making more of them - ETA 2 weeks maximum. Send me a DM if you want to be on the wait list. Thank you for the support!
8t6fierogt
Report this Post12-14-2019 02:02 PM Click Here to See the Profile for 8t6fierogtSend a Private Message to 8t6fierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amazing work Marcus!!!!!!!
Send me a text when you got some I want one for a future swap.
420ponies
Report this Post12-16-2019 05:01 AM Click Here to See the Profile for 420poniesSend a Private Message to 420poniesEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd Like to place an order also for 1 on the next batch of these. I will PM you. Thanks
[This message has been edited by 420ponies (edited 12-16-2019).]
yamaha94
Report this Post12-17-2019 07:23 AM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
added to new list. we are temporarily sold out. we started making the new batch yesterday. Shouldnt be long.
yamaha94
Report this Post12-19-2019 07:58 AM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
New batch almost done...should be by next week.
yamaha94
Report this Post12-19-2019 08:40 PM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
yamaha94
New batch ready for shipping. Send a DM and I can start shipping them out.
fierogt28
Report this Post12-20-2019 10:39 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Received brace today...excellent, thanks.
yamaha94
Report this Post12-21-2019 12:26 PM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
Happy you like it. If you have any issues let me know!
yamaha94
Report this Post12-21-2019 12:28 PM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
yamaha94
Hello, i have three orders to ship Monday. If anyone wants one let me know by Sunday night and I can have it shipped Monday Dec 23 morning.
