  FAQs & HowTos
  '84 - '87 Manual Transmission Axle Replacement - Step by Step Photo Log
'84 - '87 Manual Transmission Axle Replacement - Step by Step Photo Log by Bloozberry
Started on: 06-27-2010 11:33 AM
Replies: 36 (8942 views)
Last post by: Gall757 on 11-22-2016 05:33 PM
Bloozberry
Total ratings: 311
Report this Post06-27-2010 11:33 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll be honest, I didn't check to see if this had been documented before, but since I had the camera nearby, I decided to create a new thread about how to go about doing this. As some of you know, I did a ground-up resto on an ’86 fastback two years ago. I bought the car, drove it home five minutes away, and that was the extent of my driving experience with this particular car before I dismantled it. There were a lot more pressing safety issues with the car than driving it around to see if the axles were worn!
Anyways, about 5000 kms after the restoration, I could hear slight clunk coming from the passenger rear wheel area every time I started to accelerate from a stand still. I jacked the car up, held the passenger side tripot joint steady, and could twist the axle by hand a couple degrees, so I knew the tripot was shot. I ordered an entire axle from Cardone for $88.00 CDN… hard to go wrong. With axle in hand, I decided to photograph the procedure and share with the Forum. Following these instructions, you won’t have to break into the brake hydraulic system nor undergo an alignment once you’re done.
So on with the show… here’s the patient awaiting knee surgery.
At this point, if you don't have an impact wrench, then the first thing to do is pop the wheel center out and using a 30mm socket on a long handled wrench, remove the axle nut. It's on with 200 lbft of torque so you'll need to put the car in gear and apply the parking brake to hold the car from rolling. If you do have an impact wrench, then this step is done later. Next, jack up the car and use axle stands to support the weight since hydraulic jacks often leak slowly, and occasionally leak fast. The problem is that they're insidious... they creep down slowly enough that you can find yourself trapped just when everyone else who might be around to help you is on lunch break. They'll come back just as your eyes are popping out of your head from the pressure on your chest.
Next remove the wheel lugs using a 19mm socket wrench:
I was surprised how well the underpinnings have stood up over the past two years.
Then remove the brake caliper by unbolting the two slider bolts using a T50 Torx bit. The lower one is a little tougher to get to because the e-brake spring is in the way a bit. But it flexes out of the way enough to get the tool on the bolt.
Then hang the caliper out of the way without disconnecting the hydraulic line. I just use a piece of an old coat hanger.
Remove the brake rotor… it just slips off.
And it should look like this:
In order to have enough room to be able to pull the axle out of the knuckle, you have to be able to swing the knuckle outboard considerably. What prevents you from doing this is the tie rod and the lower ball joint. So next up is to disconnect these two parts.
Starting with the tie rod, there’s two ways to do this. One way is to disconnect it at the outer tie rod end (at the knuckle), but I find that each time you use a pickle fork to separate the rod end you risk tearing the boot. Plus, I find it easier to disconnect it at the cradle instead. With the car jacked up it’s easy to access. The nut is 19mm.
With the nut off the inner tie rod end, it takes a little heave-ho to swivel the knuckle enough to pop the tie rod bolt out of the mounting ear on the cradle, but once it’s out, swing it out of the way like this.
Next unbolt the 15mm pinch bolt on the lower ball joint and pull out the bolt.
Then separate the knuckle from the lower ball joint. Here I’m using a pickle fork for leverage, but it’s not necessary since it’s not a tapered pin. I actually found that I had to jack the knuckle up using the hydraulic floor jack to get it off the ball joint.
Once the knuckle is separated from the ball joint, remove the axle nut if you haven't already done so. It’s a 30mm nut.
At this point, I had expected to be able to push the axle out of the bearing assembly but found that the tripot joint wouldn’t compress enough to let me get the threaded end of the axle out of the knuckle. So to give me more wiggle room, I removed the three bearing assembly bolts (19mm socket wrench)…
… and removed the bearing.
That gave plenty of room to pull the axle out of the knuckle.
The next step is to pop the tripot joint out of the transmission. Some people drain the transmission oil first, but I find that simply putting an oil pan under the transmission results in exactly 1 liter of oil draining out of the axle hole, making it easier to refill later without having to use the little dipstick. To pop the tripot joint, just use a small pry bar or a large screwdriver and lever against the transmission housing like this:
The axle is only held in the transmission by a snap ring so it comes out rather easily.
Lastly, route the axle assembly out though the wheel well.
Next post, I’ll cover the installation procedure. It’s mostly the reverse of the disassembly, but there are a few things that are different or to watch for. Stay tuned!
jon m
Report this Post06-27-2010 12:04 PM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
good thread
I have one question which is on this topic - I am in the middle of stripping down my 87gt and on the axles i had both of them side by side out of the car, when i took out the wheel bearing assembly there was only one washer/spacer behind the 30mm nut.
now from which side does this washer belong is it the driver's or is it the passenger side axle or is there supposed to be a washer on both axles???
jon
Bloozberry
Total ratings: 311
Report this Post06-27-2010 12:11 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
There should be a heavy washer under the axle nut on both axles.
pmbrunelle
Total ratings: 63
Report this Post06-27-2010 01:23 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
What transmission does this tip apply to?
Bloozberry
Total ratings: 311
Report this Post06-27-2010 01:51 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry... this is an Isuzu, but I would imagine they're all going to be within the same ball park.
Report this Post06-27-2010 01:51 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice write up (and thank you for using PIP)
You do not have to take wheel bearing off.... Main nut for axle yes but not the whole bearing. The Knuckle can turn enough to get the axle off.
Report this Post06-27-2010 02:39 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great write-up! I prefer to keep the wheel bearing in place as well as the brake caliper. Removing the botton pinch bolt and the tie-rod end at the cradle is enough to pull the suspension out to clear the axle.
The only thing missing is the information if they are running an aftermarket rear sway bar - it needs to have the ends disconnected so the a-arms can move independently to allow removing of the upright from the a-arm ball joint.
Bloozberry
Total ratings: 311
Report this Post06-27-2010 03:40 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm sure I've done it your way in the past too, but for whatever reason, this time there was no way the axle was coming out of the bearing. It's like it grew a couple extra inches. It wouldn have been less work for sure to leave the brakes and bearing in place, so anyone reading this should try it that way first. If it doesn't want to cooperate, then at least you can follow along with the instructions above.
Bloozberry
Total ratings: 311
Report this Post06-28-2010 08:01 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
On to Part 2 - Reinstallation! I ordered an axle from Cardone (through a local auto parts shop) for $88 plus $15 core charge. At that price I decided to keep my old axle since it could come in handy when I start needing custom axles fabricated for my F355 N* six speed project. Here’s the part number for the RH axle:
It’s supposed to be a remanufactured axle but based on the condition of the parts including the axle itself, I’d say it’s new.
I primed it and painted it to match my old axle to keep the rust bug from tarnishing an otherwise pristine piece. Here’s the old one on top and the new one below.
In my case, I had replaced the transmission axle seals only 8,000 kms or so, so I didn’t replace it again, but in most cases, you’d want to pop it out with a pry bar and put in a new one. So in reverse order of disassembly, I started by threading the axle through the wheel well, above the e-brake cable and into the transmission. You must take care not to over-extend the tripot joint otherwise the big roller balls and the little needle bearings inside the joint will fall inside the boot and you won’t know it until you try to take it for a spin. To seat the tripot joint I use a large screwdriver in one of the grooves near the boot and give it a couple taps with a hammer.
It’s a little hard to know just how far the tripot joint should seat into the transmission if you’ve never done it before. The journal on the tripot joint that the seal rides on still partly shows once the tripot is fully seated. Here’s what it should look like once it’s driven home.
The next step is to thread the other end through the knuckle, (you'll notice in this photo that I accidentally threaded the axle under the e-brake cable when the picture was taken. I had to correct this by pulling the axle out of the tranny again and start over.)
Then using a floor jack, raise the lower control arm up to meet the knuckle and thread the lower ball joint shaft into it’s hole as you’re raising it. I find things just go better if you raise the lower control arm so that it’s approximately horizontal. The pinch bolt should slide easily through the bottom of the knuckle and the ball joint shaft. If it doesn’t, then raise or lower the ball joint shaft a little to get the notch in the shaft to align with the bolt hole. Once you’ve got it through, tighten the pinch bolt nut to 37 lbft.
Reinstall the tie rod into the cradle mounting ear and torque the nut between 50 – 70 lbft. Next, reinstall the bearing assembly if you’ve removed it.
I found that threading the bearing assembly over the axle splines was a little tight to be able to draw the bearing assembly all the way to the knuckle by hand. So I installed the axle nut at this point and used it to draw the bearing into place.
Then reinstall the three bearing retaining bolts and torque them between 55 – 70 lbft.
Finish up torquing the axle nut to 200 lbft if you have an impact wrench and a torque bar, or if you don’t, then tighten the axle nut as tight as you can at this point and wait until you have the car back on it’s wheels to finish the job with a torque wrench. A note about axle nuts… there are two kinds out there and only one is suitable for the Fiero. One kind has a very thin collar on it that you’re supposed to stake with a punch onto the axle. But these only work if there’s a slot in the axle to peen the collar into. The Fiero axle doesn’t have such a slot and so the only acceptable axle nuts are the ones with heavy duty collar about 3/16” thick. They’re a prevailing torque type nut, meaning that they’ve been distorted to make them tight enough that they won’t back off by themselves.
We’re almost done… just reinstall the rotor on the wheel studs…
…and then the caliper by torquing the two T50 bolts to 30 – 45 lbft.
Reinstall the wheel and torque the lug nuts to 100 lbft. Lower the car onto it’s four wheels and if you didn’t complete the 200 lbft of torque on the axle nut, now’s the time.
The last thing to do is to refill the transmission since a bunch of oil drained out when you removed the axle. Always do this with the car level since you won’t be able to get it all in if it’s at an incline. There’s more than one way to fill the tranny, but the easiest way is to remove the VSS. A 10mm socket wrench on a couple extensions is all you need to remove the one bolt holding it in place.
Just be careful when you pull the VSS out of the transmission as it usually takes a bit of tugging to get the O-ring to unstick itself from the sides of the hole. Mine came out rather suddenly and of course, the speedometer gear on the end of the VSS got hung up on the inside edge of the hole and came off, falling back into the transmission. No biggie though, a pair of needle nosed pliers is all it took to reach in and retrieve it. If this happens to you, the gear can only go back on one way. There’s a small plastic stopper molded into the bottom of the hole in the gear that won’t allow you to put the gear on more than about 1/8” if you’ve got it up side down.
Next, weave a funnel down into the hole in the transmission like so:
Then from up top, pour your favorite transmission oil into the funnel. Even if you have cruise control hardware cluttering the view, you can still pour it in from the top as I did without getting any oil where it isn't supposed to go. Just tip the bottle slowly on it’s side and it’ll pour straight down without burping out and making a mess. 5W30 was the original oil recommended by GM for the manual transmissions, but they have since changed that to Syncromesh oil available at your local dealership for about $15 per liter in Canada or $6 per quart in the US. If you followed my advice earlier, you’ll only need to add one liter (quart), otherwise if you drained the transmission entirely, then here’s what you need to add for the various models: 4 speed Muncie – 2.8L (5.9 pints); 5 speed Isuzu – 2.5L (5.3 pints); 5 speed Getrag – 1.9L (4 pints).
Reinstall the VSS and you’re good to go!
[This message has been edited by Bloozberry (edited 06-28-2010).]
Pyrthian
Total ratings: 342
Report this Post06-28-2010 09:38 AM Click Here to See the Profile for PyrthianSend a Private Message to PyrthianEdit/Delete MessageReply w/QuoteDirect Link to This Post
for those of us without air tools: both loosen & tighten axle nut with the wheels on the ground.
pop out the wheel center cap, and break the nut loose before you jack the car.
and tighten as a last step when car returns to the ground.
and - I like the idea of removing the tierod from the cradle, instead of breaking loose the end at the knuckle. that is a much safer way to go to avoid breaking the tie-rod ends rubber
Blacktree
Total ratings: 350
Report this Post06-28-2010 03:44 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice write-up, and good photos!
However, I'd like to make one comment. The manual transmissions only hold around 2 quarts of oil, whereas the TH125 automatic transmission holds around 9 quarts of oil. So if you pop the axles without draining the TH125, it's going to leak a lot of fluid.
americasfuture2k
Total ratings: 105
Report this Post12-02-2010 02:46 AM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
awesome man!
ptboy55
Report this Post12-02-2010 08:48 AM Click Here to See the Profile for ptboy55Send a Private Message to ptboy55Edit/Delete MessageReply w/QuoteDirect Link to This Post
Great writeup Blooz..!! With great pics..!!
Thanks..!!
I usually tap a screwdriver in the pinch bolt tang slot on the knuckle to facilitate the removal and installation of the ball joint stub.
3084me
Report this Post12-02-2010 10:01 AM Click Here to See the Profile for 3084meSend a Private Message to 3084meEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great write-up.
I always break the axle nut loose a turn or so before initially jacking up the car to make things easier.
doublec4
Total ratings: 150
Report this Post12-02-2010 04:51 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wish I had these kinds of write ups to go by when I was first learning to do this stuff!
Great contribution to the forum
Check out my build!
https://www.fiero.nl/forum/Forum3/HTML/000100.html
fyrebird68
Report this Post12-02-2010 08:41 PM Click Here to See the Profile for fyrebird68Send a Private Message to fyrebird68Edit/Delete MessageReply w/QuoteDirect Link to This Post
You're car is so clean the photos look retouched.
a '+' for another excellent write-up from the bloozberry.
Bloozberry
Total ratings: 311
Report this Post12-02-2010 10:21 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow... thanks guys. This thread has actually been out there since early this summer. I had even forgotten about it! Good to see that a few people found it useful.
lurtz
Report this Post12-03-2010 11:07 AM Click Here to See the Profile for lurtzSend a Private Message to lurtzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Solid write up. Didn't see this one in the summer but I am glad that some one bumped it back to today's board. Blooze your undercarriage looks awesome and nicely detailedl. (and just to make it clear I'm talking about your fiero) I'd give you a + but I already have for all of your earlier contributions that have saved my butt.
WKDFIRO
Report this Post12-04-2010 03:10 PM Click Here to See the Profile for WKDFIROSend a Private Message to WKDFIROEdit/Delete MessageReply w/QuoteDirect Link to This Post
Excelllent write up and I'm sure that someone in the future will be thanking all things mechanical that you put it up. Interesting choice of color for the axles, engine block, pulley, coil springs etc. What made you go for that particular color on a black car? It does come out very nicely from all the black background parts.
Kudos on keeping it all VERY clean!
+ for you as well! Bravo!
Bloozberry
Total ratings: 311
Report this Post12-04-2010 04:48 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks WKDFIRO. When it comes to color accents, I find that there seems to be only four colors that most people use: red, black, silver or Ford blue. I wanted to avoid the same-old, same-old, and the only primary or secondary color that looks right in my mind is yellow. It's a color that looks clean, and brightens up the lower parts that are often hard to see because they're in a dark area. Yellow isn't in everybody's book of favorite colors for sure, but I started using it in almost all of my engine rebuilds and it's sort of become a trademark for me.
FirstDrCar
Report this Post12-04-2010 08:54 PM Click Here to See the Profile for FirstDrCarSend a Private Message to FirstDrCarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice write-up. I appreciate the detail and pictures. I am placing this into my Favorites
Twilight Fenrir
Report this Post10-02-2011 11:39 PM Click Here to See the Profile for Twilight FenrirSend a Private Message to Twilight FenrirEdit/Delete MessageReply w/QuoteDirect Link to This Post
Free bump, as it's something I'm going to have to do pretty quick here... Thanks!
my '84 SE's loosing transmission oil around the drivers-side axle of my Muncie 4spd... I thought for sure pulling the axle would be really involved, and require me to get an alignment... I'm just thrilled that it looks like it can be easily done in one afternoon! Never had an axle out before, so I was a little worried about the process... you make it look easy.
Thanks again!
[This message has been edited by Twilight Fenrir (edited 10-02-2011).]
deezil
Report this Post03-15-2012 09:46 AM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
How much different would this step by step be on a 1988 GT?
Or is there a write up on the 88s only someone could point me to?
Bloozberry
Total ratings: 311
Report this Post03-15-2012 12:08 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
It would be the same procedure except that there is no rear tie rod on the '88's to remove, nor is there any lower ball joint so just ignore those steps. On the earlier models some people have found that there is enough room to pull the axle out of the transmission without disconnecting the lower ball joint, so on the '88 you may be able to get by without disconnecting the two lower links, which replace the lower ball joint. Many people have found that removing the two lower links can be very difficult since the single bolt that holds them in place often seizes to the knuckle. If this is the case, you will almost certainly have to remove the bearing assembly from the knuckle as shown above to give you the room to pull the axle far enough outboard to get it out of the transmission. The rest is pretty much the same.
If you're not sure what I'm talking about, once you get the wheel off and have a look, it should become a lot clearer. If not, then just start a new thread and I (or others) will be able to help you out if and when you get stuck.
mcguiver3
Report this Post03-15-2012 01:05 PM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
I hope I didn't miss this in your thread but definitely drain the trany fluid in the manual units.
It saves a lot of clean up.
Bloozberry
Total ratings: 311
Report this Post03-15-2012 01:10 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did post something about it... you only lose about a liter (quart) of oil if you pull the axles out without draining it, so as long as you have a pan under the seal area it's not absolutely necessary to drain the transmission. Automatic trannies will drain a lot more as mentioned elsewhere.
Arns85GT
Total ratings: 202
Report this Post07-10-2012 03:12 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for a detailed and well presented lesson +
Arn
CheshireGrin
Report this Post11-01-2012 10:58 AM Click Here to See the Profile for CheshireGrinSend a Private Message to CheshireGrinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cant give you another + but can thank you again.
Very informative and clearly written.
Thanks for taking the time
Ryan
hypo327
Report this Post11-16-2012 06:16 PM Click Here to See the Profile for hypo327Send a Private Message to hypo327Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bloozberry, When you finally kick the bucket, they need to place a gold wrench in your hand, inscribed, "King of the Fiero Forum," or something like that...lol! You the man! I just got through successfully doing a 3.4 swap on my '86 Fiero, and, thanks to all the help, from guys like you, it started right up and purred like a kitten (video on you tube.) Sadly when I took her to town for a maiden run, my Getrag selector locked between 4th and 5th, and I couldn't get it out no matter what I did. It happened once before on me, about a year ago, but it cleared after I towed it home, and didn't give me any more problems until now. I happen to have another low mileage '88 Getrag that I'm going to replace the locked-up one with.
Well, I dropped the cradle again and have it sitting on my garage floor dolly, but I've never pulled a Fiero axle before, so this thread is FANTASTIC for me! Thanks so much! And the yellow components make it perfect! I did install new bearings and hubs about 6-months ago, so I was somewhat familiar with the process, but good instructions and pictures (especially when they are so well done and concise...right down to torque specs and everything...well, that's just excellent! What more can I say...?! :-)
hypo327
Report this Post11-24-2012 09:42 PM Click Here to See the Profile for hypo327Send a Private Message to hypo327Edit/Delete MessageReply w/QuoteDirect Link to This Post
I finished swapping the '88 Getrage, I had as a back-up, with my '86 Getrag with the stuck selector. Following this guide thread, made it an easy job, but I have one problem. I put two quarts of Pennzoil Synchromesh oil in while sitting on my cradle dolly, but when I checked the dip-stick ( the '88 Getrag has one) the oil level barely hits the end of the dip-stick...well below the add line! Two quarts is all I ever put in my '86, so does the '88 hold more oil for some reason, or does it just measure different when in the car?
hobbywrench
Report this Post06-02-2013 02:11 PM Click Here to See the Profile for hobbywrenchSend a Private Message to hobbywrenchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good job, but I personally don't like prying on aluminum. Suggest a slide hammer. Also upon removing the axle I always try to use a support of some sort for the DROP of the heavy axle out of the diff I believe this can ruin the seal and require replacement. My experience on my 85 GT: The gyrations to just clear the bearing seal with the threaded axle tip is disconcerting, but I have never torn the rubber lip removing or installing the axle. Again, great pics and obvious TLC!
Sourmug
Total ratings: 144
Report this Post06-02-2013 03:24 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice write up!
Now we need one for the 88's
zzzhuh
Report this Post05-25-2014 03:55 AM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
This by itself was GREAT information. I couldn't find legit photo's of this any where. Thanks for this mate
The wetter the better
Lunatic
Report this Post06-01-2014 07:50 AM Click Here to See the Profile for LunaticSend a Private Message to LunaticEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another great write-up Dave, kudos to you for assisting the community again and again. I like the idea of putting grease in behind the bearing, I guess that's to keep contaminant's out? Since you have time on your side, I think you should start a Pennock's TV series for Fiero enthusiasts! Full Fiero tear down and reassembly.
Shayne
Bloozberry
Total ratings: 311
Report this Post06-19-2014 04:00 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys for the comments... I enjoy being able to help wherever I can.
007 fieroman
Report this Post11-19-2016 10:36 AM Click Here to See the Profile for 007 fieromanSend a Private Message to 007 fieromanEdit/Delete MessageReply w/QuoteDirect Link to This Post
This kind of information with pic's thru out the whole process is another good reason I joined the Pennock's forum. I have received a lot of help from many members and thank Glen Pennock for starting and maintaining this site . I also thank all the other members that have helped me out with information and great deals on parts . I would like to ask everyone to remember to buy Glen a beer to help keep this site going and keeps Fiero enthusiast informed and together , allowing us to keep these cars from being forgotten and just scraped when broken .
Report this Post11-22-2016 05:33 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff?
