  FAQs & HowTos
  Installing the aux gauge cluster in an 84
Installing the aux gauge cluster in an 84 by RWDPLZ
Started on: 07-09-2008 11:59 PM
Replies: 19 (7299 views)
Last post by: RWDPLZ on 03-03-2019 07:21 PM
RWDPLZ
Total ratings: 305
Report this Post07-09-2008 11:59 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Before starting this project, I searched the archives and asked people here about it. A few people had claimed to have done it, but never posted how. Other people simply said 'it can be done, but 84 wiring is different' So using information compiled from multiple threads and my trusty 84 service manual, I was able to successfully install the aux cluster into my 84.
Here's the differences between the 84 and later years:
First, the oil pressure switch/sending unit
Shown at left is the 84 switch, right is the 85-87 sending unit. The difference is the 84 one is just a switch, which turns on a light on the dash when the oil pressure drops to 4 psi or below. The 85-87 unit is a variable resistance (0-90 ohms) sending unit, which varies in resistance depending on the oil pressure, causing the gauge needle to move around. The old sending unit must be removed using a special oil pressure switch socket. The new one has the same size 1/4" threaded end, and can be screwed in in place of it. Mine used a 9/16" wrench to screw it in tightly.
I had a bad experience with a Niehoff sending unit purchased from Autozone (probably now reboxed and sold as Duralast) which read 40psi max and read low overall. Replacing it with an AC Delco unit fixed the problem. I purchased it from an AC Delco distributor for just over $50. The dealership wanted $95. The sending unit is AC Delco part # 10045775
Here is the pinout for the earlier units and the 88 sending unit:
Wiring diagrams:
In this diagram you can see how the orange and tan/white wires are connected in the fuel pump circuit.
The tan signal wire:
The tan signal wire carries the signal from the sending unit to the gauge cluster. In the 84, it will turn the light on if the oil pressure drops to or below 4 psi. You can see the way it's wired here, the light will also come on if the car overheats since it's also connected to the coolant temperature switch. In this diagram you can also see that the tan wire for the oil pressure comes through the firewall on the C203 connector, while the coolant temp switch comes through on the C500 connector. Both join at the S214 connection point under the center console.
C203 Connector:
This is where I got the signal for the aux cluster. The tan wire, circled in yellow below, was cut 3" from the end of the connector. I then crimped on a male spade connector, and crimped a female spade connector to the other end, which gets shoved back under the console. This makes the wiring reversible later, and keeps the unused end from grounding against the frame. A tan wire is run from the cluster back to this connection under the center console.
C206 connector differences:
This connector plugs into the gauge cluster at the rear right of the cluster, behind the tachometer.
The main difference here between 84 and later is pin #6: In 84, this is where the oil pressure signal comes in, while on later years this is where the brown charge wire is located, and the tan oil wire is moved to pin # 17 (empty on the 84). Fortunately, it isn't necessary to move the wires around.
I soldered and taped up the harness going to the aux cluster at the points indicated on the connector: pin 9 (pink/black) for the 12V, pin 11 for the ground, and pin 15 for the illumination so the gauges will glow at night, and dim with the dimmer switch. These wires are then run up behid the dash to the aux cluster.
The only thing left is the brown alt lamp wire. In the 84's, instead of a bulb, Pontiac used a 10 ohm resistance wire
I didn't bother hooking up this wire since I'm not sure if the total resistanc evalue matters or not (10 ohm wire + bulb resistance) but it would probably be simple. The volt meter and oil pressure gauge work fine without it, you just don't have an idiot light for the alternator.
Testing the unit:
Once installed, turn the ignition key to START without actually starting the car. The voltmeter should jump to wherever the battery is currently charged (probably 12.4 or so).
The oil pressure gauge can be tested by hooking up a wire to the middle terminal (tan wire). I crimped a spade connector to a long length of wire. Hooking the spade connector to the middle terminal and touching the wire to a ground should cause the gauge to go into the red zone and the oil light to come on (zero resistance). Unplugging the sending unit should cause the gauge to peg far to the right (infinite resistance).
Hopefully this helps anyone who wants to install the cluster in their 84.
1984 Fiero SE
[This message has been edited by RWDPLZ (edited 07-10-2008).]
E.Furgal
Total ratings: 278
Report this Post08-13-2012 06:20 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
nice, is there enough room to tee the fittings, to have both the dum dum light and gauge?
I have no issue running a wire all the way back..
some in family (wife) need to see a red light to think there is a problem.
RWDPLZ
Total ratings: 305
Report this Post08-18-2012 10:31 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
The bright red light on the oil pressure gauge will light up, it's pretty noticeable. I thought about the tee idea, but it would mean more possible places to leak, and running extra wires. Felt like there was plenty of room, not sure, though.
fierosound
Total ratings: 286
Report this Post02-12-2013 09:17 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Done it with my Indy using this website
http://www.frontiernet.net/...tt/AuxGageInstal.htm
RCR
Total ratings: 102
Report this Post02-24-2013 08:13 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Excellant write-up.
Bob
[This message has been edited by RCR (edited 02-24-2013).]
Ram426
Report this Post04-21-2013 10:01 AM Click Here to See the Profile for Ram426Send a Private Message to Ram426Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is I correct to assume if adding the 120speedo to an 86 is just a direct replacement , and plug in?
RWDPLZ
Total ratings: 305
Report this Post06-08-2013 04:57 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
A little late, but if the 86 is a V6, then yes, plug and play. If it's a 4 cylinder, you'll need to swap the tach circuit board.
longjonsilver
Report this Post07-04-2018 08:37 AM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the excellent writeup. Now i think that i can wire in the gages. Can i assume that instead of running a wire from the C203 connector, that i can just tap into the tan wire on the C206 at pin #6 ?? Since i am installing the 120mph speedo, i will also need to tee off to the #17 position? Or can i move the #6 wire to the #17 position instead?
jon
reason for edit: clarify
I'm the original owner of a white ' 84 2M4 purchased Dec 10, 1983 from Pontiac. Always garaged, no rust, 4-wheel drifts are fun! 3800 SC swap to come!
[This message has been edited by longjonsilver (edited 07-16-2018).]
longjonsilver
Report this Post07-04-2018 01:48 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
longjonsilver
Member since Nov 2001
Well, that is exactly what i have done and it seems to work correctly. Pulled an oil sender off the same car that gave me the rally gages and the main gages. Hopefully it will work, as now the oil pressure is pegged max max max. The RPM of my Duke reads 1 and a 1/2 times the real RPM. i plan on installing a 3800SC into my 84 so i will live with the incorrect tach reading. In the meantime, it will make me do the math!
jon
longjonsilver
Report this Post07-04-2018 04:57 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
longjonsilver
Well, on a second thot, after a drive i find that my dash lights don't work, except for the right turn signal. The left turn signal works outside, but the dash light doesn't. i forgot to remove the handbrake on the test drive, because the light didn't come on. Any ideas?
jon
longjonsilver
Report this Post07-04-2018 10:00 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
longjonsilver
Well, another drive revealed other things not kosher with my gages. i was really low on gas and the gas gage was pegged on max, and i filled up and its still pegged on max. hmmmmm no signal at all? My son opened his door and the water temperature idiot light went on. i distinctly remember the brake light going on at first and then now it doesn't illuminate at all. The left turn signal indicator light doesn't light up. The speedo has no light at all at night.
The good things? i really love the look of the GT 120mph gages and the lighting at night (except for the speedo) is really cool. The idiot light for the oil pressure works, altho the gauge is pegged max as i need to change the sensors.
i suspect that some of these things are bad bulbs or bad contacts. i left off the back of the instrument pod so i can access the bulbs, and clean the contacts, but i think i will need to move or resolder some wires on the C206 (?) cluster as well. More research is in order. As i was putting in the C206 cluster i wondered if i was putting it in upside down. i guess i didn't put it in upside down because then the speedo, tach, and coolant temperature wouldn't work.
RWDPLZ
Total ratings: 305
Report this Post07-04-2018 11:34 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you swap the 84 cluster back in and everything on that cluster works, that would rule out the wiring.
Lately it seems like more and more of the flimsy plastic circuit boards on the back of clusters are going bad. I've seen several more popular cars now have aftermarket replacements, hopefully something will be available for the Fiero in the future. The fuel gauge in my 120MPH cluster stopped working a few years ago, and I think this is the culprit.
longjonsilver
Report this Post07-05-2018 06:43 AM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, i could do that, but the family needs my car running, so for now, i am going to first check all the bulbs and clean the contacts with some 2000 wetndry sandpaper. if that doesn't fix things i am going to make two diagrams for the C206 terminal, one for the 84 and one for the part i pulled from the 86(?) in the junkyard and see where else there are differences between the 84 and the others.
i didn't touch the C203 terminal under the console, i bot another C206 terminal and removed the white wire from #18(?), cut the tan wire and wired it into #17 and then wired the brown wire to terminal #6 where the tan wire was cut, on the perchance that there was a signal and power. No, but oh well. Idiot lights are optional, however if it isn't too hard to wire them in, then i will wire them.
i remember that when i first fired up the car, i got a movement of the gas gage to 3/4 and then it moved back to max, so i believe that there might be a bad contact. Same thing with the brake light, it worked at first then stopped. Could be that the bulb burned out immediately. Also with the passenger door open it sends a signal to the thermometer idiot light, which tells me that the wires on the 84 are in different spots than the other years, not just the two for the rally gages.
thanks again for the write up
jon
ps. i built a tester for the bulbs and cleaned the contacts and tested them. 11 out of 44 tested bad. 3 bulbs tested bad at first, but on retesting them before throwing away proved to be good. Moral: clean the contacts - its important. Now my odometer light, brake light, service engine soon light and left turn signal light work. Something is fishy with the gas gage and no tachometer light. i will try cleaning the contacts on the printed circuit board for the tachometer light. Door ajar signal lights up the temperature idiot light - that must be a different wire on the C206 terminal. i've got to verify all the wires in the C206. i will post my results here
edit: more information for clarity
edit 2: additional information
edit 3: update
longjonsilver
Report this Post07-06-2018 10:34 AM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero Wiring Diagrams
https://drive.google.com/dr...CaHpOcEk3WU1CRkFMZDA
Since my fuel gage worked fine in the old instrument cluster, i assume that the fuel gauge in the new cluster doesn't work or only is designed to work with the V6 not the Duke (i know that the fuel pumps have different output pressures, dunno about the fuel level senders output voltages). Maybe i can swap in another fuel gage into my new instrument cluster?
The right door switch turns on the door ajar idiot light when the ignition is on. Perhaps this is why, here is the 84 C206 (?) terminal.
https://s15.postimg.cc/u3lm...6_at_10.26.48_AM.png
Unlike the 87 wiring diagram that i found online referenced above, the 84 diagram doesn't specify the number on the terminal just the color. Notice that the 84 specifies two dark green wires (35 and 146) right next each other. One is for the Coolant temp switch, the other for the trunk ajar light. Hmmmmm . Here is what i have so far:
jon
longjonsilver
Report this Post07-11-2018 04:17 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
When i pulled the oil pressure sender from the bone yard, i got one from an 86 GT 2.8. Apparently it has different threads than the 84 duke. The guy at the hardware store said that they didnt have anything to adapt the threads. Bee Ess. i bot a 1/4" male IP to a 1/8" female IP brass bushing. Teflon tape on the threads and it appears to work fine. i assume if i had bot one from an 85-87 duke that it would have had the right threads. Anyway, it worked. Now i have a pressure signal to my gages. Yeah! i was told on another thread that you need a special tool to remove the 84 duke oil pressure sender. Bee Ess again. A 1 1/16" deep socket worked just fine. Of course if you want to spend $10bucks for a tool you will only use once, go right ahead. Now on to installing a new radio, and trouble shooting my 120mph speedo cluster (open door still sends a signal to the temp warning light). Hey, what an idea, close the door and no more overheating. A champion 3 core radiator has been ordered that will fix that problem the right way!
jon
longjonsilver
Report this Post07-13-2018 05:26 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
i have been checking the wiring diagrams for the 84 - my copy is a little confusing because the connectors are not clearly labeled. The 85-88 clearly has two grey wires in the C206 connector, but the 84 only has one. Perhaps this is why my speedo and R turn signal don't light up. In addition the door sets off the temp idiot light. But this has me wondering - perhaps i would be better off by using my 84 circuit board and housing and swapping in the GT gages. Hmmmm
jon
edit for update: and that is exactly what i did. It seems to work well now, as i knew that my circuit board was the proper one for my car wiring. HOWEVER the position of the idiot lights, the function of the idiot lights, and the wording of the idiot lights is different on different years. i have an 84 instrument cluster, an 86GT instrument cluster and an 85-87 2m4 instrument cluster and had to reuse my 84 faceplate with the 84 idiot light positions, or else move the 84 idiot light cellulose to that of the 86 GT. i chose to reuse my 84 faceplate with the 86GT gages. That fixed the door's setting off the temperature idiot light and now it sets off the door ajar.
i recommend that anyone that swaps in the GT gages in an 84 reuse the cluster housing including the circuit board, and reuse the 84 cellulose for the idiot lights.
[This message has been edited by longjonsilver (edited 07-15-2018).]
Donster
Report this Post10-16-2018 05:56 AM Click Here to See the Profile for DonsterSend a Private Message to DonsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can somebody supply instructions or a link for the installation of aux gauges on an 88 coupe (4 cylinder)?
Much obliged.
Greetz from Germany
\D
Life is good!
Former President of the Georgia Fiero Club
Now living in Europe and finally own a Fiero again!
Donster
Report this Post10-18-2018 04:17 AM Click Here to See the Profile for DonsterSend a Private Message to DonsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing? Nobody?
Do the same instructions apply as with an 84? I would find that hard to believe.
Any help would be appreciated.
fierovandermey87
Report this Post02-19-2019 10:28 AM Click Here to See the Profile for fierovandermey87Send a Private Message to fierovandermey87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi there,I have an 87 SE 4cyl, just got the aux cluster and dont have the pigtail for it. Is there a way i can just solder the wires right to the aux cluster? and do i need to modify the surround around the stereo?
RWDPLZ
Total ratings: 305
Report this Post03-03-2019 07:21 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
You could, but the pigtail makes it much easier. There's one on eBay right now for $20 with the pigtail
https://www.ebay.com/itm/Fi...1:g:rCIAAOSwjR5cddu~
The radio surround for the aux cluster has the large hole cut out on top, it has a raised rib section that hides the gap between the console and the aux cluster. You can see wat it looks like here:
https://www.ebay.com/itm/19...0AAOSwT-pb4goU:rk:21 f:0
Alternatively, there's the Mall section on the forum here, OR if you are in Traverse City, Gene's Auto Parts and East Bay Auto parts, between the two they frequently have at least one Fiero.
https://genesautoparts.com/
http://www.eastbayautoparts.com/
