  FAQs & HowTos
  How to remove outer door panel, with pics
How to remove outer door panel, with pics by fierohoho
Started on: 10-31-2002 02:14 PM
Replies: 26 (16731 views)
Last post by: sledcaddie on 09-07-2018 08:11 PM
fierohoho
Total ratings: 221
Report this Post10-31-2002 02:14 PM Click Here to See the Profile for fierohohoSend a Private Message to fierohohoEdit/Delete MessageReply w/QuoteDirect Link to This Post
As I recently replaced my dew wipe I had the door apart so I took a ton of pics.
What I offer here is for the new Fiero owners who want to do the work themselves.
I welcome any comments from others to help cover any mistakes I make or to offer an easier way for the beginer to do this.
The pics are from my '84 with power windows, locks and mirrors.
I have another thread you can find by doing a search for "How to remove inner door panels, with pics."
At this point I will assume you have the inner door panel off.
First remove the rubber end caps from the frame, two philips screws on the back one and three philips screws on the front. They are glued down with a small amount of sealant but peel up easily.
Next remove the inner window seal, it's held in place with six philips head screws.
Next remove the two 10mm nuts that hold the mirror in place, a little liquid wrench or WD-40 on the nuts will help, an open end box wrench works best, don't worry if you drop the nuts inside the door you can retrieve them soon anyway. Note how the power mirror wiring harness (or the manual control cable) is routed behind the window guide, make sure when reinstalling these they are in the same location so as not to interfere with the windows operation .
Now unplug the wiring for the mirror and take the mirror off, if you have a manual mirror you will have to fish the whole control cable out but it's not too hard.
[This message has been edited by fierohoho (edited 11-01-2002).]
fierohoho
Total ratings: 221
Report this Post10-31-2002 02:28 PM Click Here to See the Profile for fierohohoSend a Private Message to fierohohoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now remove the seven plastic looking screws that holds the door skin edges. There are four at the rear and three at the front.
On the '84 they are philips head screws, '85-'88 are torx bit screws. If they strip out it's not the end of the world just a pain. I have found if you use a razor blade (be careful) you can shave the top of the plastic off to expose the actual metal screw holes and use them. Here is a pic of both the philips and torx intact and with the tops shaved off.
Now remove the moulding strip, start at the front and using a small flat blade screwdriver pry at the top corner of the moulding while pushing up on the bottom of the moulding, the top edge should come away from the door, then push down to disengage the bottom from the clip.
Now move down a little and again pushing up pull the top edge of the moulding away from the next clip.
There are a total of four clips five if you count the front one. When all are loose you will find a small christmas tree type push fastener holds the back end under the door handle, pop it loose with a small flatblade screwdriver and the moulding is off.
[This message has been edited by fierohoho (edited 10-31-2002).]
fierohoho
Total ratings: 221
Report this Post10-31-2002 02:41 PM Click Here to See the Profile for fierohohoSend a Private Message to fierohohoEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierohoho
Member since Apr 2001
Now remove the front moulding clip using a 7mm socket or nut driver and then the rear 7mm screw near the key lock.
This is a pic of one of the four moulding clips, to remove them from the door use a small flat blade screwdriver to lightly push down on the little tab in the center that goes into the door while pulling out on the clip, a needle nose pliers helps here. Do not be suprised if the little tab breaks, I usually break half of them when I do it, not a big deal, just buy some new ones. This is also a good pic to show what you are pushing up against to release the moulding from the clip.
Now go to the bottom edge of the door and you will find four plastic rivets, use a small punch to punch the center out, you will then be able to pop the rivet out using a flat blade screwdriver or side cutters. Here's a pic of a removed rivet too.
[This message has been edited by fierohoho (edited 12-04-2002).]
fierohoho
Total ratings: 221
Report this Post10-31-2002 02:58 PM Click Here to See the Profile for fierohohoSend a Private Message to fierohohoEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierohoho
On the '84 door the top edge is held to the door frame with three christmas tree fasteners, '85-'88 have a lip molded in the door skin that hooks over an edge on the frame. Pull the '84 skin away from the door frame at the top and the fasteners will come loose. On '85- '88 door skins pull the bottom of the door away from the frame slightly and lift the skin up to disengage the skin from the frame.
At this point the only thing holding the skin to the frame is the lock rod and door handle rod. Remove the clip that holds the rod to the lock cylinder.
The rod that goes from the door handle to the latch mechanism just sits in a hole and will come loose when you slide the skin up and away from the frame, or you can undo the plastic clip that holds the rod to the door handle.
That's it for the door skin removal, the dew wipe is now easy access, you can get to all but two of the screws which sit behind the window glass. These can be removed with a tool that Rodney Dickman sells or you can use a needle nose vise grips like I did to turn the screws in from the outside.
As you can see from the pic I used an old forceps to hold the screw in place when I reinstalled it, I used the vise grips to tighten the screw from the outside, as this is a self tapping screw there is a little bit of the end to grab without trashing the screws threads.
fierohoho
Total ratings: 221
Report this Post10-31-2002 03:17 PM Click Here to See the Profile for fierohohoSend a Private Message to fierohohoEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierohoho
If you are in this far and have power locks that don't work or you have to hit the button several times here's an easy fix I have done on four doors.
Remove the rods from the latch mechanism and the three torx bolts that hold the latch to the frame.
Clean all the old dust and grease off the latch with whatever it takes and then regrease the whole thing using a spray grease that will stay on and not run off.
I used a spray grease that gels up shortly after it's sprayed on.
Reinstall the latch and hook the rods back up.
I have not done anything to the lock solenoid (it's really a lock motor) and have had excellent results.
Good luck and Wrench On Dudes! HoHo
Daniel87GT
Report this Post10-31-2002 04:30 PM Click Here to See the Profile for Daniel87GTSend a Private Message to Daniel87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tech tip: When removing the outer molding you can reach through from the inside of the door and release the clips if the window is up. My clips were pretty stiff from age and would probably have broken if I had tried prying them off from the outside.
On my 87 GT there was a metal piece in the way of me getting to the outside of the screws directly. Basically, it didn't get me anything to pull the outer skin off. It was a lot of work and I didn't have any replacement rivets for the bottom of the door.
Tech tip: once you're commited to changing the dew wipes go ahead and cut away the majority of it. It will make it easier to get at the screws with Rodney's tool. I had the problem where the tool wouldn't fully engage the screw because the dew wipe was too stiff. It worked fine after I cut most of the dew wipe off, right down the crease.
JD86GT350
Report this Post10-31-2002 07:38 PM Click Here to See the Profile for JD86GT350Send a Private Message to JD86GT350Edit/Delete MessageReply w/QuoteDirect Link to This Post
wow, great instructions with good pics!
It might be worthwhile to mention that you don't need to remove the outer door skin to replace the dew wipes though.
Total ratings: 328
Report this Post10-31-2002 08:20 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great information and an excellent post
87GT 3.4 Turbo Best 0-60 5.2 seconds
http://turbofiero.fierojoe.com/turbo.htm
fierohoho
Total ratings: 221
Report this Post10-31-2002 10:20 PM Click Here to See the Profile for fierohohoSend a Private Message to fierohohoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, You are right, it is not necessary to remove the door skin to do the dew wipes, I replaced mine when I had the door apart and threw in the info on how I did it in response to an e-mail I got about this and my other post about removing the inner door panel.
2farnorth
Total ratings: 81
Report this Post11-01-2002 06:31 AM Click Here to See the Profile for 2farnorthSend a Private Message to 2farnorthEdit/Delete MessageReply w/QuoteDirect Link to This Post
Outstanding post. Very well done. Thanks.
Dave
DJWINNI
Report this Post11-01-2002 07:45 AM Click Here to See the Profile for DJWINNISend a Private Message to DJWINNIEdit/Delete MessageReply w/QuoteDirect Link to This Post
This post couldn't have been posted at any better moment than now!!
I have to remove my outer door panels to repaint them (with the rest of the car.... pics coming soon!)!!
thank you for your help!
Christophe from FRANCE
***86 SE V6/2.8L***
cjgable
Report this Post11-01-2002 09:43 AM Click Here to See the Profile for cjgableSend a Private Message to cjgableEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great Post! Just in time too. I am needing to replace my right door skin. Thanks!!
'87 2.8v6 5spd
1986GTV8
Report this Post11-01-2002 10:06 AM Click Here to See the Profile for 1986GTV8Send a Private Message to 1986GTV8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wish that I had seen this last week. Did mine for the first time and the instructions & pics would have made it much easier.
Your info is dead on.
On my next project I will take the time (we all should)to shoot some photos also so we can all have a reference to view.
THANKS
1986 GT 355 Chevy 420hp
fierogt88
Total ratings: 100
Report this Post11-01-2002 10:19 AM Click Here to See the Profile for fierogt88Send a Private Message to fierogt88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Great info!
I gave positive ratings to fierohoho and JD86GT350. Normally I would keep my ratings to myself (since I am politically against rating systems) but I just thought that I would point out that I *TRIED* to give Daniel87GT positive feedback but only get an error. Go figure. I wonder how many other positive ratings Daniel has missed because his ratings file is corrupt....
<sarcasm>Oh well, I didn't really like that Daniel guy anyway. Who cares if he knows what he's talking about. I'm offended by the way he uses uppercase and lowercase letters in the same username, so I want to boot him anyway.</sarcasm>
l8ter!!
p.s. even though I'm ranting, lets not hijack this ABSOLUTELY WONDERFUL POST!! If you want to correct my political position on rating systems, pleas PM me. It's been months since I had a PM anyway!
StansGT
Report this Post11-01-2002 11:05 AM Click Here to See the Profile for StansGTSend a Private Message to StansGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice job!
I think you should have made the Haynes manual!
02' 3800SC Poly, Koni, Enkei
andguent
Report this Post11-01-2002 01:35 PM Click Here to See the Profile for andguentClick Here to visit andguent's HomePageSend a Private Message to andguentEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by StansGT:
Nice job!
Hey whats that wink for. Thats a very serious statement. HoHo you seriously should have. Just the color pics alone makes a big difference.
Yes I agree you picked a very good time to do it as well. My power locks were (past tense! ) sticky, and I have a side mirror to replace. You posted your 'how to remove inner door panel' thread the day after I had my mirror ripped off. And now, thanks to this thread I don't have to ask the question of "wheres the mirror mount bolts?"
Yeay.
Most comments are opinion of the author and are fair targets for corrections/critisim. :P
Andrew
White86SEV6Auto
killerb15
Report this Post11-01-2002 03:18 PM Click Here to See the Profile for killerb15Send a Private Message to killerb15Edit/Delete MessageReply w/QuoteDirect Link to This Post
Great info! as I'm going to be adding PDL, PM and keyless to my doors soon (the doors are off the car)
Great timing as I probably would have pulled the skins off fron the top and broken the lips (86GT) on the top of the skins.
Thanks!
fierohoho
Total ratings: 221
Report this Post11-01-2002 03:52 PM Click Here to See the Profile for fierohohoSend a Private Message to fierohohoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jeez guys, my head is swelling up, thanks for the positive response.
I did this thread as I had time and a camera, I see new guys and a few old members posting questions that need this type of response, this is my way of paying the forum back for all the good info I have found and the great people I have met because of it.
I have several pics to add to help show the differences between the 84 year and 85-88 years door skins.
This first set of pics show the inside edge of the 84 door skin and then the 85-88 door skin.
1984
1985-1988
The next set shows the difference between the actual door frames of the 84 and 85-88.
1984
1985-1988
You can see the metal "rail" they added to hold the lip of the door skin, sure beats the three christmas tree fasteners on the 84's
Butter
Total ratings: 91
Report this Post11-01-2002 04:17 PM Click Here to See the Profile for ButterSend a Private Message to ButterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
Smoooooth GT
Total ratings: 310
Report this Post11-01-2002 04:29 PM Click Here to See the Profile for Smoooooth GTSend a Private Message to Smoooooth GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
OUTSTANDING THREAD!!! This IS what the forum is meant to be!! You just got a **+** from me too..
Smooth!!
SmoothFieroGT@Yahoo.com
Have you RATED me today??
MaddRatt
Report this Post11-01-2002 05:22 PM Click Here to See the Profile for MaddRattSend a Private Message to MaddRattEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierohoho,
Since I don't have 30 posts to vote a "+" for you I am thanking you here. There will be one from me for you and several others that REALLY deserve it!
I am getting ready to replace my driver side door due to a very big hole in it. This will really help me get the old one off, hopefully with relative ease, on my 87 coupe. Also, thanks for showing the differences between door frames and skins between the model years. I have learned alot already from this forum, and members like you REALLY HELP! As do many of the others that have posted and helped others and myself out!
So............
THANK YOU!
Jimmie
[This message has been edited by MaddRatt (edited 11-01-2002).]
FieroRumor
Total ratings: 348
Report this Post01-21-2003 10:28 AM Click Here to See the Profile for FieroRumorClick Here to visit FieroRumor's HomePageSend a Private Message to FieroRumorEdit/Delete MessageReply w/QuoteDirect Link to This Post
(bump)
GREAT POST!
Carrolles
Report this Post01-21-2003 01:45 PM Click Here to See the Profile for CarrollesSend a Private Message to CarrollesEdit/Delete MessageReply w/QuoteDirect Link to This Post
While I had the doors apart installing the pw/pdl in my 85SE I also replaced the outer dew wipes. I couldn't get a bite on the two hard to get to screws with the tool I got from Rodney. I researched my archive of printed forum posts and found one that had instructions that worked for me. I don't have the info with me here at work so I can't post a link.
In this procedure I removed the upper window stops from the door and loosened the bolts holding the vertical track near the rear side of the door. I could then raise the window enough to get the roller out of the vertical track which allowed me to slide the glass forward and backward enough to get to the screws with a regular screwdriver. It sounds complicated but turned out to be very easy. Be sure and mark the position of the bolts before you remove them so you can restore their position when complete. (you will need to remove the rubber molding from the front and rear edge of the glass and the mirror as in the procedure above).
While I had the door apart I sprayed lithium grease on all the moving parts of the lock mechanism and the window tracks. One of the places that causes the most friction in the lock mechanism that I see is the plastic guide that the lock rod snaps into between the lock mechanism and the inner door handle. You can see it when the inner door panel is off. I just unsnapped the rod and squirted a small amount of the white grease on it and re-snapped the rod in place.
lorennerol
Report this Post04-01-2015 12:35 PM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
When we did the dew wipes on my Fiero my father in law came up with a very nifty trick for holding the little screws when reinstalling.
He cut some small plastic tabs using the clear plastic from those blister packs (you know, the stuff that is impossible to open). The tabs were about 3" long and 1/2" wide. He screwed the dew wipe screws through the ends of the tabs, and then used to tab to hold the screw in place while we got them started. Once they were snugged down, a firm tug on the tab broke it free of the screw and we were able to tighten them down using Rodney's tool.
handymanpat
Report this Post01-21-2016 10:53 AM Click Here to See the Profile for handymanpatSend a Private Message to handymanpatEdit/Delete MessageReply w/QuoteDirect Link to This Post
I sure am happy that you did all of this for us! Now I can finish pulling off my door skin without wrecking something.
Thanks again!
90turbo1
Report this Post05-20-2016 01:54 PM Click Here to See the Profile for 90turbo1Send a Private Message to 90turbo1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have seen several fieros with the outer skin cracked at the mirror. is there something that I should look for as my 1986 is cracked in that same location also. not sure if its a cold weather stress point or something else.
I was gonna try to fix mine soon.
thanks for this write up.
sledcaddie
Report this Post09-07-2018 08:11 PM Click Here to See the Profile for sledcaddieSend a Private Message to sledcaddieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for a great write up and pictures! I need to pull the door skin off to access the window regulator. It makes a noise about half way up. I think it's the spring. With the door skin off, I should be able to diagnose it correctly.
