What I offer here is for Fieros owners who want to do the work themselves and try to keep the costs down
I welcome any comments from others to help cover any mistakes I make or to offer an easier or cheaper way for this to be done.
In my pics you will notice I have done the Grand Am brake upgrade so I have no e-brake cables to deal with, you will of course have to detach the cable from the caliper if you still have the stock brake set-up.
My vehicle is a 1984 SE
I will start with the assumption that you have the car safely supported, the rear wheels off and you've purchased the rear bearing hubs.
Start by disconecting the brake line from the strut. As I have done the GA upgrade I have 7/16" nuts and bolts, I'm not sure what the stock bolt size is.
Next remove the caliper bolts, mine needed the T-47 TORX bit.
With the caliper off support it out of the way with a piece of wire.
Remove the cotter pin from the castle nut on the bottom of the toe link rod where it connects to the knuckle assembly.
Using an 18mm socket partly remove the nut.
To get the tapered shaft to pop loose I hit up on the castle nut with a hammer several times, leaving the nut on helps protect the threads. Yes you can get a special tool to do this also.
Now remove the nut and bolt that holds the lower ball joint to the knuckle assembly, this takes a 15mm socket on each side.
[This message has been edited by fierohoho (edited 06-20-2005).]
Using a small pry bar loosen the ball joint from the knuckle assembly but don't pop it out just yet. Leaving it in will help stabilize the strut for the next step.
Using a 30mm socket partly remove the nut on the end of the axel shaft, I used a long pry bar in the studs on the hub to keep the hub from spinning.
Once again hit the nut with a hammer to pop the axel shaft loose from the hub. The new bearing hub has a new 30mm nut, discard the old one but save the washer that was behind the nut as this will be re-used
Now up into the engine compartment and using a 13mm socket remove the nuts from the top of the strut.
Now pry the lower A-arm down to get the ball joint stud out of the knuckle assembly, pull the strut toward you to get the axel shaft out of the hub assembly and lower the strut out of the wheelwell.
Remove the old seal, (note how and where it sits in the hole), and then clean the the inner area where the seal sits.
Install the new seal that comes with the bearing hub, I used a small punch and went around the outside tapping it in with a hammer, I left lots of little dents in the seal case but it didn't seem to distort the seal itself, if you have a seal installer tool use that, my way works but it's not the best.
Now put some axel grease on the back of the bearing hub, inside the seal area and on the seal itself. There is also a round o-ring that goes on the bearing hub, install it now.
Clean the end of the axel shaft and put a little grease on it as well.
Install the bearing hub into the knuckle, replace the dust shield and start the three bolts. Using a torque wrench torque these bolts to 55-70 FT. LB.
Re-install the strut into the vehicle in the reverse order you removed it.
The nuts at the top of the strut should be torqued to 18 FT. LB.
The toe link rod castle nut should be torqued to 30-39 FT. LB. and the cotter pin replaced with a new one.
The nut and bolt that holds the ball joint stud to the knuckle assembly should be torqued to 30-36 FT. LB.
The worst part I had here was getting the ball joint stud to pop back into the knuckle. The grove in the ball joint stud must be aligned with the hole in the knuckle assembly before insertion.
Put the old washer and then the new 30mm nut that came with the bearing hub onto the axel shaft.
Now the hard part, the axel nut has to be torqued to 200 FT. LB. I went to 150 FT. LB. that my tourque wrench maxed out at and later hit the nut with an air impact wrench to give it a little more.
Now re-install the rotor and caliper and re-attach the brake line to the strut.
I replaced both sides on my Fiero as the drivers side had developed a slight howl at highway speed, all's good now.
Wrench on dudes.
HoHo
I don't understand....why did you remove the strut/spindle assembly from the car? I removed my rear bearings to install longer lugs by just removing the rotor, removing the axle nut, and undoing the 3 bolts attaching it to the spindle/upright. Took ~30 minutes per side including stud removal and install time.
BTW, I replaced my axle nuts at the same time. These must be replaced ANY TIME THEY ARE REMOVED!
I'm guessing he did it that way because he likes to do the precision work out on a workbench, where everything is easily accessible for cleaning. Consider it a 2fer1 deal. How to change a hub bearing assy and how to remove the strut.
Or, maybe he's like I am and hate squattin down on my wore out knees for that long.
Replacing the knuckle seal is kinda difficult if you don't remove the knuckle...
I did it this way as I replaced the seals also.
The strut removal made it easier to get to them.
Thanks for the compliments fellas.
[This message has been edited by fierohoho (edited 06-21-2005).]
When putting in new bearing seals I try to find a socket(or other tool) about the same diameter, to hammer it in the hub. That way there are no small dents or other type of damage and it will usually seat smoother. Great write up.
I couldn't find a socket that big so...
My next tool purchase will be a bearing race/seal installer tool.
I wasn't too concerned about this seal as it seems to be set up to keep as much dirt/moisture off the rear of the beariong hub as possible.
If you ever do one you'll see there is a drain indent at the bottom of the knuckle assembly to allow some air movement to the back of the bearing hub, I suppose to keep it dry and give any water that gets in there a way out.
You can see it at the right of the bearing seal in this pic:
As you look at this pic the bottom of the knuckle assembly is at the right.
A 2 1/8" Craftsman socket fits the backside perfectly, and allows driving in from the back, or inside.
Before removing the old, I use a piece of pvc pipe which fits thru the front side perfectly. I cut it off to kie flush whith the three bearing bolt landings. Now you have a perfect depth guage.
From the backside, a 2 1/8" socket for driving in the seal. Also, the pvc pipe section is shown. You can put the pipe in the hub, set it on a table top, and drive the seal down to the pipe.
From the outside, the pvc pipe in place, against the seal. Check for depth by using a straitedge across the bolt landings.
It is a good writeup. You're doing a bunch of things you don't really need to.
Guys....
You don't have to take off the knuckle. It's best if you don't and far faster...
You need a section of 1.5 inch PVC pipe with a straight coupler. If you have a small sledge, use the side of that to drive the seal. (You want the area of the mini sledge, don't need to pound it hard.) If you only have small hammer you'll need a wood block to keep from breaking the pipe.
To make it a bit easier... have someone hold the axle for you. Push in on the axle as well to clear the seal while you drive it in.
There is nothing you need to measure on the seal. The edge of the seal should be flush with the back of the knuckle as hoho shows it and as shown earlier above... the seal is driven from the front of the axle.
there are more notes in my cave.
------------------ Dr. Ian Malcolm: Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should. (Jurasic Park)
On using PVC pipe to drive the seal, get an end cap for the pipe, glue it in place, and you have a great surface to whack with the hammer. Use Sch.40 pipe and cap, it's the strongest you'll find in a regular home store.
Does the Axl nut and seal come with the hub? I just placed the order from Rock Auto this morning.
Will I need an alignment after this job?
The hubs sometimes come with the seal and other times they don't. Hubs should include the axle nut. You need not go for an alignment unless you remove the strut assembly. While this is a good write-up, I always replace hubs with the strut attached to both the spindle and upper wheel well. I can change them in under an hours time this way but we use a lift, impact wrenches and a hub puller. .
------------------ " THE BLACK PARALYZER" -87GT 3800SC Series III engine, custom ZZP /Frozen Boost Intercooler setup, 3.4" Pulley, Powerlog manifold, Northstar TB, LS1 MAF, 3" Flotech Afterburner Exhaust, Autolite 104's, MSD wires, Custom CAI, 4T65eHD w. custom axles, HP Tuners VCM Suite. "THE COLUSSUS" 87GT - ALL OUT 3.4L Turbocharged engine, Garrett Hybrid Turbo, MSD ign., modified TH125H " ON THE LOOSE WITHOUT THE JUICE "
I replaced both of the bearing on my car today. One thing I did was to pull the center caps off of the wheel, set the park brake and chocked the wheels, put my deep well socket through where the center cap was, and then brake the axle nut on both sides free before doing anything else.
Not sure if the socket fits with stock wheels. I have a set of Subaru wheels on my car.
Putting the new axle nuts on was the reverse. Got the axle nut snug, bolt wheels on, and torque to 200 and hope I don't blow a hernia.
I also have gotten away from hammering on the tie-rod-end castle nut. I have noticed that most knuckles have a flat spot on the side of where the tie rod bolts in. A few good hits with a hammer normally frees the tie rod up.
Notes. Stock cars should have 30mm axle nuts I believe, but I am not sure. My car had the bearings replaced at some point, and had 29mm nuts on the car (1 1/8in socket fit snug but it fit) and the new bearings came with 29mm nuts.
Good how-to. Well explained and understandable even though I can't see the pictures any more.
I do have a question about installing the axle nut. Everything I've read says to pre-torque the axle nut to 75 lb/ft with the suspension unloaded. Then lower the vehicle onto the wheel and finish the torque to 200 lb/ft.
Which is the correct procedure. Torque in two steps or in one? Suspension loaded or unloaded?
Edit: Now, as I back out of the thread, the pictures show up. Working on replacing my brother's hub, so I will leave this online all night for reference tomorrow.
[This message has been edited by fierofool (edited 10-20-2015).]
Yes it does, and it's far easier to do it that way. And when you put it back together, put the breaker bar and socket on the nut (wheel back on), with the breaker bar horizontal, and stand on it. If you weigh 200 pounds, stand one foot out on the breaker bar, and you will exert 200 foot pounds of torque. Stand closer or farther depending on your weight (for example, 1.5 feet out if you weigh 150 pounds). Easy as pie.
I slip a long pipe over the breaker bar as a “torque multiplier”. I also use the donut spare...put it on with a couple of lug nuts, drop the car on the ground and use its weight to help. Do the same for tightening the new nut.
