  Dupont Imron Paint - Is It Good?
Dupont Imron Paint - Is It Good? by johnmac
Started on: 02-07-2000 05:59 PM
Last post by: lowCG on 02-13-2000 08:50 PM
johnmac
Report this Post02-07-2000 05:59 PM Click Here to See the Profile for johnmacSend a Private Message to johnmacDirect Link to This Post
I am planning to paint my 86 GT with a Dupont Imron Paint in a Porsche Bahama Yellow color.
Is Imeon good and is it flexible enough for the Fiero panels? Should a flex agent be used?
What type of primer can I use. Is anything avaiable from a spray can?
Is there a high gloss?
I am used to it on boat applications but not so sure about the flexible Fiero.
Any suggestions and comments are welcome.
John
86 GT
5 weeks to go
lowCG
Report this Post02-07-2000 06:51 PM Click Here to See the Profile for lowCGSend a Private Message to lowCGDirect Link to This Post
Imron would be my first choice,but I'd want to be real sure that the painter knows how to paint to the level of gloss/orange peel that you desire;this paint is no fun to sand.
I have some spray primer for the urethane panels(nose,tail)that I haven't tried yet,but my autobody friends tell me that all this should work out fine.
Cooter
Total ratings: 138
Report this Post02-07-2000 06:58 PM Click Here to See the Profile for CooterSend a Private Message to CooterDirect Link to This Post
Yes Imron is good. It has high gloss and durability and should be flexible enough without any special flex additives. However, I personally do not like to use it. It is tough to spray, runs are really hard to sand and buff out and dry spray is next to impossible to buff out too. I dont know what happened, but my 88 GT was painted with Imron and it looks like crap. It has no gloss, has pin holes all in it and no matter how much I sand and buff, it just won't shine. It looks like he used too much reducer in it because it is covered in runs. When I repaint it, I will use Omni base coat/clear coat. Less expensive, easier to use and really looks good without buffing.
Report this Post02-07-2000 07:03 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreDirect Link to This Post
Imron is one of the toughest paints ever invented. Used with the correct primer it will adhere to anything. It must ONLY be used by an expert. Newbee painters need not apply. You shoot this stuff wrong and you have a major pile of crap.
Imron doesn't like to be built up beyond a certain tickness in a certain amount of time. ((No I don't know what the coat spacing is anymore.))
IF you get a run in Imron you will be dealing with it for about a week. It'll be at least that long before you can sand it without a horrid mess.
If you mix Imron wrong it will either never set, or set in the spray gun. If it sets in the gun throw it away and buy another.
johnmac
Report this Post02-07-2000 09:48 PM Click Here to See the Profile for johnmacSend a Private Message to johnmacDirect Link to This Post
Sounds like Imron is for experts only. What are the recommendations for Base/Clear Coats?
Does Dupont have a product for this. My painter likes to use Dupont products.
Any suggestions?
Thanks,
John
Cooter
Total ratings: 138
Report this Post02-07-2000 10:23 PM Click Here to See the Profile for CooterSend a Private Message to CooterDirect Link to This Post
Yes, DuPont makes an excellant BC/CC system. Their ChromaBase and associated products are easy to use and give great finishes. They are just a little bit expensive compared to other similiar paints. I would make sure to use the "high solids" clear. Different companies have different names for it. Your paint guy will know what I mean. It is a high build clear, requiring only two coats to achieve full film thickness, instead of three for standard clears. You use less materials, and it offsets the costs of using the more expensive clear. BTW- I only used about 1.5 quarts of base coat (before thinning) and 2 quarts of high build clear (when mixed makes about 2.5 quarts) Dont let them charge you for a gallon of base coat or a gallon of clear!
TOM
Report this Post02-07-2000 10:49 PM Click Here to See the Profile for TOMSend a Private Message to TOMDirect Link to This Post
I only spray Imron. But I usually paint airplanes.
lowCG
Report this Post02-08-2000 08:27 PM Click Here to See the Profile for lowCGSend a Private Message to lowCGDirect Link to This Post
Tom,do you know where the green,rubbery primer,that is often used on airplanes can be purchased non-commercially?
Or at least what it's called,so I can try and find it.
TOM
Report this Post02-08-2000 08:51 PM Click Here to See the Profile for TOMSend a Private Message to TOMDirect Link to This Post
Its called Zinc Chromate. Most paint supply places have it. It also comes in rattle cans. I use imron Vari-prime. It is awesome
Phil
Total ratings: 154
Report this Post02-08-2000 09:59 PM Click Here to See the Profile for PhilSend a Private Message to PhilDirect Link to This Post
I talked with someone that had imron on his car and he was't happy because he thought that he got more stone chips than with reg paint. Who knows?
jhogans
Report this Post02-08-2000 10:10 PM Click Here to See the Profile for jhogansSend a Private Message to jhogansDirect Link to This Post
I hate to sound stupid or ignorant but what is this Imron paint and the DuPont BC/CC system. What is so special about this stuff? Any pictures of cars that have used the stuff?
pollock
Report this Post02-09-2000 10:34 AM Click Here to See the Profile for pollockSend a Private Message to pollockDirect Link to This Post
jhogans,
No prob. Basic difference: Imron sucks; BC/CC is phenominally better. Imron is a single stage paint, meaning it's like the "gloss" colors that you can buy in rattle cans. shiny color in one pot.
BC/CC stands for base coat/clear coat, and DuPont does not make the only one. With this paint, you spray down a layer of color and then a layer of clear on top of it. It allows for a great deal of "color sanding" (which should be called "clear sanding") for a glasslike finish.
I can't understand why anyone would want to use single stage paint instead of bc/cc. To me, it's like using a telegraph instead of a telephone.
Unless you're painting a lawn mower, or a park bench or something.......
TOM
Report this Post02-09-2000 11:04 AM Click Here to See the Profile for TOMSend a Private Message to TOMDirect Link to This Post
If Imron sucks so badly why is it used on 20 million dollar aiplanes. Yes I said $20 mill.
Cooter
Total ratings: 138
Report this Post02-09-2000 12:14 PM Click Here to See the Profile for CooterSend a Private Message to CooterDirect Link to This Post
Imron is the ultimate in non-maintanence paint. I have seen firetrucks and airplanes painted with it over 10 years ago that have NEVER been waxed or polished and they still look great. Imron is a single stage polyurethane enamal, the clear coat on the BC/CC paints are also polyurethane.
Report this Post02-09-2000 06:52 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreDirect Link to This Post
Imron only "sucks" when it's not put on right. Imron is not tolerant of people who don't really know how to paint. We used to use it on the hull of boats and motor cycle frames with both excelent durability and gloss.
A word about Zinc Chromate..... You may be able to get it over the counter, but you should understand that this primer is extremely toxic. I believe it is also listed as hazardous by the EPA.
TOM
Report this Post02-10-2000 12:00 AM Click Here to See the Profile for TOMSend a Private Message to TOMDirect Link to This Post
Imron is also toxic and hazardous and all that other fun stuff. What ever you paint with wear a quality resperator. I use a fresh air system.
fierodave
Report this Post02-10-2000 07:03 AM Click Here to See the Profile for fierodaveClick Here to visit fierodave's HomePageDirect Link to This Post
Johnmac I am getting my INDY done bc/cc dupont chromabase the ground effects are done,and you can count your nose hairs in the finish! and there not wet sanded or buffed yet
I had to tell my painter to stop doing such a good job with the prep because i don't want it to look better than my 86 GT with 50,000 miles on it! :~)
Do it with the dupont system, your painter told you he likes useing it so there is your answer!
I have painted with it and love the gloss, It is a bit more expensive,
but the finish and durability is awesome.
I had a truck with a custom paint job done to it and it got tagged by a bunch of gang kids, sprayed the whole thing with black red and siver paint, took it to the shop after the insurance payed for a new paint job, and wet sanded and buffed it all off, cost me 12 hours of my time, a few bloody fingers, and $12.00 for materals If you have other question feel free to contact me, I can send you pic's if we ever get it sprayed this week lol
FD
jhogans
Report this Post02-10-2000 02:53 PM Click Here to See the Profile for jhogansDirect Link to This Post
fierodave,
how much is your paint job costing you?
pollock
Report this Post02-10-2000 04:02 PM Click Here to See the Profile for pollockDirect Link to This Post
I knew i'd get some responses, hehe....
Perhaps i should clarify. In painting a car, particularly a special interest car, i believe that BC/CC paint is far superior to imron in pursuit of a high-shine finish, with no trash or orange peel.
Sure you can get a great finish with imron, if you're good enough. But why do it the hard way, just because you can?
Sure, they use Imron on $20million airplanes, boats and even Peterbilt trucks. Why? IT'S PRODUCTION PAINT. Pretend for a minute that you're a manufacturing engineer. Should you choose a paint that you have to basically shoot twice (i.e., base/clear) or just once (i.e., imron). Duh.
Look close at a peterbilt or a 737. Orange peel up the wazoo. I'd rather have a mirrorlike 5 year paint job than a 10 year school bus paint job anyday.
Report this Post02-10-2000 04:40 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreDirect Link to This Post
actually very little production work is done in Imron. Most automotive production paint is waterbase or low VOC. The EPA pushed out high solvent paints in the early 80's in many types of paint operations. In fact many autobody shops using Imron and Zinc Chromate regularly violate EPA regulations by venting the fumes directly into the outside air and/or sweeping spray dust into the trash.
2 step BC/CC is actually used quite often in production. GM, Chrysler and Ford have all used it, and still do. Factory Fiero paint was applied in this mannor. Single stage paints have faded from use because in many cases diferant pannels are painted with diferant paint. Some plastic pannels are not painted at all. The Clear Coat is shot on to give the assembled car a uniform gloss. The vehicle may not even be shot all at one time. In some cases prefinished plastic pannels won't even be installed untill after the metal has been shot and clear coated.
BC/CC products may apply to higher initial gloss, but most brands have problems of their own. They may seam easier to apply but actually they are often quite dificult to get good durability out of. (Coat spacing is important for these systems as it it for Imron. They are easier to shoot for other reasons. Like they are not usually epoxy style paints and are less toxic.)A common problem of BC/CC systems has been a tendancy to delaminate the CC. This is what causes the dandruff effect on Fiero paint. Black and Silver Fieros seem to get it the worst. Once the CC fails the base looks like hell in short order. Newer CC's are better but the jury is still out on how much.
lowCG
Report this Post02-10-2000 07:17 PM Click Here to See the Profile for lowCGSend a Private Message to lowCGDirect Link to This Post
Zinc-Chromate primer dries hard,used on structure,some components,but the stuff I'm wondering about is a translucent,dark green,and is used on the skin of the airplane for chip resistance.
Don't make me call my old job and ask them!lol
Report this Post02-10-2000 07:39 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreDirect Link to This Post
not sure. zinc chromate I've seen is always bright day glow green. could be a dirivative or something else completely what your describing.
johnmac
Report this Post02-10-2000 11:22 PM Click Here to See the Profile for johnmacSend a Private Message to johnmacDirect Link to This Post
This is from the originator of this topic.
It appears the consensus is a trip down to Sears for a gallon of that latex paint and the roller --- Hah Hah!
Thanks for the tremendous response and I will be going with a Dupont BC/CC. Should a flex additive be added also?
Thanks FieroDave Again - do you have any photos of your latest project?
To all you Fiero enthusias - thanks again, you are swell bunch of car nuts!
I am hoping to be on the road with my restored 86GT within 4 weeks.
Thanks,
John MacHaffie
Cooter
Total ratings: 138
Report this Post02-10-2000 11:28 PM Click Here to See the Profile for CooterSend a Private Message to CooterDirect Link to This Post
No flex additive should be needed. The urethane is pretty flexible and should hold up fine as long as you dont hit anything, or anything hit you.
batboy
Report this Post02-10-2000 11:48 PM Click Here to See the Profile for batboySend a Private Message to batboyDirect Link to This Post
I'm looking at and may possibly buy a 1971 GMC truck that was restored seven years ago and was painted with Imron. It still looks GREAT! If done right, it's a fine paint. I've seen plenty of clear coat paint jobs that fail in less time than that. On the other hand, I've seen lots of show winning cars with BC/CC paint jobs too. It's a matter of preference. I'd prefer the low maintenance paint myself, I've got too many other things to do than to wax my car every week.
TOM
Report this Post02-11-2000 12:24 AM Click Here to See the Profile for TOMSend a Private Message to TOMDirect Link to This Post
I guess to POLLOCK nothing is good enough. Im done with this
lowCG
Report this Post02-11-2000 06:29 PM Click Here to See the Profile for lowCGSend a Private Message to lowCGDirect Link to This Post
I hope to find a good painter when the time comes to paint my car,and get that slight orange peel effect that usually comes on expensive cars,and that will gradually get smoother with age/polishing.
Actually I'll probably get my uncle to help me,or do it myself;the last time we painted six cars in a weekend,with some bodywork too,they all turned out great including my Lancia,which was done in Redspot clear over a satin Sherwin Williams(Polane T)black.
The Alfa GTV from that weekend sold for $5K,also black,but with different(cheaper)paint.
[This message has been edited by lowCG (edited 02-11-2000).]
Phaeton
Report this Post02-12-2000 09:34 PM Click Here to See the Profile for PhaetonSend a Private Message to PhaetonDirect Link to This Post
LowCG, Neoprene paint. It cures to a synthetic rubber, thick and cushiony, it keeps a fair gloss and sticks to well prepped surfaces. Don't know about certified for aircraft.
lowCG
Report this Post02-13-2000 08:50 PM Click Here to See the Profile for lowCGSend a Private Message to lowCGDirect Link to This Post
Thanks,was thinking about how to try and keep the chips away,especially on the lower panels,I'll check it out.
