87 Coupe project by 30+mpg
Started on : 06-17-2005 06:31 PM
Replies : 388 (28408 views)
Last post by : 30+mpg on 10-30-2024 07:50 PM
Feb 18th, 2015
30+mpg Member Posts: 4061 From: Russellville, AR Registered: Feb 2002
quote Originally posted by jmbishop: What was fix for the brake?
lube
11:36 PM
Left headlight motor not activating for raise. Lowers OK
[This message has been edited by 30+mpg (edited 02-18-2015).]
11:38 PM
Apr 24th, 2015
Had to repair a bad butt splice on the white wire from the headlight switch on the dash to the module.
06:09 PM
Project now in its 10th year.
06:15 PM
Jul 30th, 2015
Stalling only on startup. Regapped plugs back down to .065". Front plugs are a major pain. Spent over an hour on #1 plug
05:56 PM
May 20th, 2017
Project was 12 years old last month and still running strong.
03:51 PM
notwohorns Member Posts: 1175 From: greenville, il. usa Registered: Jul 2009
Sometimes it takes more than a day or two
07:22 PM
Aug 31st, 2017
Feb 11th, 2018
The windshield wiper system has developed a ghost wipe that occurs every 90 to 120 seconds that the engine is running. Rather than try to troubleshoot switch and board gremlins, I took a different approach. I installed a toggle switch in the hot wire circuit coming from the wiper fuse. It kills the power to the wipers and eliminates the ghost wipe.
[This message has been edited by 30+mpg (edited 02-11-2018).]
06:27 PM
Mar 30th, 2018
After a 66 mile trip, for some reason, the battery won't fully charge.
Time to replace the battery that I installed new in Aug, 2009.
Update: May be a bad connection instead.
[This message has been edited by 30+mpg (edited 03-31-2018).]
08:13 PM
Oct 31st, 2018
Over 13 years and still going strong.
03:35 PM
Apr 27th, 2019
Topped up the A/C charge. Started this project 14 years ago, runs great!
12:51 PM
May 2nd, 2019
Maverick_2m6 Junior Member Posts: 7 From: Florence, KY Registered: Jul 2018
That's awesome that its still running strong after 14 years
04:19 AM
Nov 20th, 2019
bump
09:31 PM
Apr 25th, 2020
May 1st, 2021
16 years & running great. A/C is cold.
01:42 PM
Aug 26th, 2021
A/C problem. Orifice valve is clogged with black gunk.
Time to flush the system.
01:39 PM
Nov 26th, 2021
Replaced a weeping front freeze plug in the block.
A/c flush was black with metal particles.
Replaced compressor and accumulator.
Turned front upper ball joints 180 degrees to bring camber back in spec.
Bought & installed rear camber bolts, the ones with eccentric washers and adjusted rear camber.
Did a 4 wheel alignment using the string & digital calipers method.
Buffed & waxed the paint.
08:24 AM
Jun 27th, 2022
17 years! A/C is ice cold!
06:04 PM
Aug 19th, 2022
Restored the CD function of Delco radio P/N 09370232.
05:20 PM
Jun 13th, 2023
18 years, still going strong.
08:51 AM
Jun 26th, 2023
No start due to a faulty neutral safety switch on the transmission. Dissambled the switch, cleaned out old grease, sanded copper contact areas, applied di-electric grease and reassmbled.
Fires right up.
11:58 PM
Aug 1st, 2023
After all these years, I finally replaced the park/lock cable that was cut by a previous owner.
01:12 PM
Aug 25th, 2023
Voltage at the battery with the A/C operating was down to 13.1v.
The 1 year warranty on the Bestest rebuilt alternator I had previously bought expired many years ago.
This time I bought & installed an Ultima rebuilt alternator with a limited lifetime warranty.
14+v with the A/C in operation.
Things are good once more.
08:16 PM
Patrick Member Posts: 38388 From: Vancouver, British Columbia, Canada Registered: Apr 99
08:52 PM
Aug 26th, 2023
richard in nc Member Posts: 396 From: charlotte nc Registered: Jun 2023
this is what i had planned to do.i have a 1989 reatta parts car.did you ever do a speed test on your car?
09:41 PM
May 24th, 2024
Replaced the transmisson gear selector switch.
The contacts would not conduct enough amperage to activate the solenoid.
Runs great!
18 years.
07:41 PM
Oct 22nd, 2024
Starter Bendix drive is beginning to fail.
Fortunately, I have the receipt for a limited lifetime warranty for a drive that I purchased from O'Rielly's on 4/17/05.
07:51 PM
Oct 30th, 2024
Replaced the starter drive. Unfortunately, to remove the starter I had to disconnect the A/C lines to the compressor. Reassembled & the engine starts perfectly on the first twist of the key!
07:50 PM
