  87 Coupe project (Page 3)
This topic is 10 pages long:  1   2   3   4   5   6   7   8   9   10
87 Coupe project by 30+mpg
Started on: 06-17-2005 06:31 PM
Replies: 388 (28408 views)
Last post by: 30+mpg on 10-30-2024 07:50 PM
30+mpg
Total ratings: 97
Report this Post02-18-2006 01:06 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Even though is only 10 F above zero, I took the aircleaner can out to the garage and sandblasted off the majority of the rust. The nose for the tube to the manifold looked like thin swiss cheese when I was done. Not good.
Bondo would work, but I wanted something a little stronger.
After it cures, it can be sanded smooth & painted.
[This message has been edited by 30+mpg (edited 02-18-2006).]
americasfuture2k
Total ratings: 105
Report this Post02-19-2006 04:57 AM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
what is that car antenna booster? just an antenna amp? i bet the answer is yes, so where can i pick one up
30+mpg
Total ratings: 97
Report this Post02-19-2006 03:08 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
americasfuture2k:what is that car antenna booster? just an antenna amp? i bet the answer is yes, so where can i pick one up
Yeah, that's right. Boost used to mean "increase", until Gone in 60 seconds redefined the term.
Bought it on E-bay.
[This message has been edited by 30+mpg (edited 06-01-2006).]
30+mpg
Total ratings: 97
Report this Post02-19-2006 05:34 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
30+mpg
Member since Feb 2002
Made a minor air flow improvement in the air cleaner base (plus weight reduction ).
30+mpg
Total ratings: 97
Report this Post02-20-2006 09:13 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
P22 for the L44 Air intake system shows the metal can sitting on the metal support.
I wanted something a little tighter than a metal to metal seal:
so I cut a gasket for the can to sit on.
30+mpg
Total ratings: 97
Report this Post02-23-2006 01:51 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got the air cleaner installed. Used the PA intake hose to connect to the throttle body.
Problem: hose won't let the air cleaner body rotate enough for the sensor to move out of the space where the vapor canister wants to go.
A different hose is needed. Looks like the air cleaner end needs a 3" I.D. and the throttle body end needs a 3-1/4" (83mm?) I.D.
Anybody have any suggestions? Also, the can outlet is way lower than the throttle body inlet.
30+mpg
Total ratings: 97
Report this Post02-23-2006 07:47 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
30+mpg
[This message has been edited by 30+mpg (edited 02-23-2006).]
tcurtin
Report this Post02-24-2006 11:28 PM Click Here to See the Profile for tcurtinSend a Private Message to tcurtinEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 87 Fiero is a 2.5 L but the same color and I can't find a color match. What is this color and can I get a DUPLICOLOR can?? Thanks.
Terry
30+mpg
Total ratings: 97
Report this Post02-25-2006 06:27 AM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
The color is Duplicolor DS GM 223 MEDIUM RED.
My next item
[This message has been edited by 30+mpg (edited 02-25-2006).]
30+mpg
Total ratings: 97
Report this Post02-25-2006 08:16 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
30+mpg
Beefy
30+mpg
Total ratings: 97
Report this Post02-26-2006 02:29 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Using a 3" dia PVC elbow & a strip of adhesive backed foam weather stripping applied to the groove in the outlet nose of the aircleaner, here's the result
Engine sounds quieter, too.
[This message has been edited by 30+mpg (edited 03-11-2006).]
30+mpg
Total ratings: 97
Report this Post03-03-2006 06:17 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Location of a garage door opener.
2.8-4spd
Report this Post03-04-2006 11:47 AM Click Here to See the Profile for 2.8-4spdSend a Private Message to 2.8-4spdEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think its amazing what you have done to your car! Its shows you can have a nice car without spending tons of money.
Forrest
30+mpg
Total ratings: 97
Report this Post03-05-2006 02:21 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
The biggest single expense, other than the coupe, has been the GT wheels & tires, which I bought about 9 months before I bought the coupe.
88White3.4GT
Report this Post03-05-2006 10:29 PM Click Here to See the Profile for 88White3.4GTSend a Private Message to 88White3.4GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amazing, nice attention to the little details. Keep up the good work, nice pictures too!
30+mpg
Total ratings: 97
Report this Post03-11-2006 07:45 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
A spotted mirror finish
Puttied
Wet sanded and freshly painted
30+mpg
Total ratings: 97
Report this Post03-14-2006 08:01 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Adjusted rear suspension to 1/2 degree negative camber with 1/16" toe in per side.
Cured dartiness.
30+mpg
Total ratings: 97
Report this Post03-18-2006 03:39 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Removed, cleaned and hammered the dents out of the transmission pan. Missing the magnet.
New filter, gasket & 4 quarts of ATF.
30+mpg
Total ratings: 97
Report this Post03-20-2006 09:46 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Opened up the hex on a stock lug wrench from a hex for 19mm lug nuts to 13/16" to fit the Wal-Mart "tuner" nuts.
[This message has been edited by 30+mpg (edited 03-20-2006).]
30+mpg
Total ratings: 97
Report this Post03-27-2006 10:56 AM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lubed driver's seatback pivots & spring to permit the back to move forward under spring power instead of having to pull it forward by hand.
Repaired and installed a broken seat belt guide that covers the spring.
30+mpg
Total ratings: 97
Report this Post03-28-2006 07:16 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stopped by Wholesale Automotive Paints in Joplin yesterday. Picked up a few items:
Got a quart of viper red & a quart of maroon.
Plus a quart of clear, some reducer, a water trap, 2 rolls of masking tape and a couple to tack cloths.
A couple of measuring containers, a few mixing sticks & filters free.
Not bad.
[This message has been edited by 30+mpg (edited 04-04-2008).]
30+mpg
Total ratings: 97
Report this Post03-28-2006 08:41 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Before I can prep for paint, there's a small crack on the lower driver's door that needs fixed.
Upon closer inspection, the door skin had to be removed to fix the crack.
Seems somebody had attempted a fix prior using massive amounts of Bondo. No flex hard Bondo on flexible plastic panels that are subjected to below freezing temps, a big NO - NO in my book.
Here's the back view.
Now to grind away the Bondo.
I used a heavy ridge of flexible epoxy body putty on the backside of those cracks.
Here's my progress on the outside.
30+mpg
Total ratings: 97
Report this Post04-03-2006 08:59 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
250.1 miles on 8.004 gallons for this coupe = 30+mpg
Bought a DA sander to help with the spider cracks on the bumpers and front fenders.
Glad I got it. The front cover was a replacement part. Originally red with a clearcoat , it was repainted medium red & given a clearcoat. 4 layers to grind thru.
Also the left turn signal opening is not flat on the bottom. Time for the hot melt a straight section of coat hanger to the bottom side of the wave to straighten it out trick.
[This message has been edited by 30+mpg (edited 04-04-2006).]
30+mpg
Total ratings: 97
Report this Post04-03-2006 10:10 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
30+mpg
Made a long thin U w/ coat hanger wire. Hot glued it to the underside. No more wave.
darkhorizon
Total ratings: 451
Report this Post04-04-2006 06:14 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
that fiero looks pretty familiar, my friend is painting his 86GT right now. Shoulda looked around for a new door panel insted of trying to refiber it, I have a few red ones on parts cars right now, I am sure alot of people have some laying around also.
30+mpg
Total ratings: 97
Report this Post04-04-2006 07:48 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
darkhorizon:that fiero looks pretty familiar, my friend is painting his 86GT right now. Shoulda looked around for a new door panel insted of trying to refiber it, I have a few red ones on parts cars right now, I am sure alot of people have some laying around also.
Did, couldn't find any. How much do you want? No PM's, please. E-mail me.
30+mpg
Total ratings: 97
Report this Post04-04-2006 07:51 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
30+mpg
Here's a shot of the front facia w/ high build primer:
Oh goody, another crack to work on.
30+mpg
Total ratings: 97
Report this Post04-05-2006 09:33 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
More joy!
To remove the front fender, the rocker panel must be removed. However, someone decided to attach the rocker & fender using metal rivets instead of plastic ones. I'll replace them with plastic after the paint is on.
30+mpg
Total ratings: 97
Report this Post04-06-2006 08:18 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's a sure clue of previous front end damage
a weld seam across both front fender support rails
[This message has been edited by 30+mpg (edited 04-06-2006).]
30+mpg
Total ratings: 97
Report this Post04-06-2006 08:23 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
30+mpg
Now on to the passenger door skin
Can you spot all 3 cracks in the photo?
Plus another at the bottom rear corner (what corner?) That flexible expoy sure comes in handy.
[This message has been edited by 30+mpg (edited 04-10-2008).]
30+mpg
Total ratings: 97
Report this Post04-06-2006 08:31 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
30+mpg
With the door skin off, time to take care of that gap between the front quarter of the dew wipe & the door glass.
A few well placed blows fore and aft of the mirror support
stressing the metal beyond the yield point, resulting in permanent deformation
which is a good thing. Gap is gone.
30+mpg
Total ratings: 97
Report this Post04-07-2006 07:01 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking better
30+mpg
Total ratings: 97
Report this Post04-08-2006 02:49 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now to the rear we find
another crack. (The last one, too. )
30+mpg
Total ratings: 97
Report this Post04-13-2006 09:57 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
This was delivered today.
Finally, the correct one.
30+mpg
Total ratings: 97
Report this Post04-13-2006 10:25 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
30+mpg
Project, presently = pieces for paint prep.
30+mpg
Total ratings: 97
Report this Post04-18-2006 06:39 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Had the car for a year now, check the progress
[This message has been edited by 30+mpg (edited 04-18-2006).]
Mr.Chipps
Report this Post04-18-2006 07:12 PM Click Here to See the Profile for Mr.ChippsSend a Private Message to Mr.ChippsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 30+mpg:
Bought a 120mph Inst. panel from maxthechainsaw. Installed an Air/fuel kit in it before swapping it in.
Check
https://www.fiero.nl/forum/Forum2/HTML/068263.html
for details.
Seems the link on this posting isn't working. Is the new instrument panel a pretty straight forward change or lots of creative wireing?
Really nice Thread, lots of information.
Hager
30+mpg
Total ratings: 97
Report this Post04-18-2006 07:19 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mr.Chipps:Seems the link on this posting isn't working. Is the new instrument panel a pretty straight forward change or lots of creative wireing?
Hager
Fixed the link, it went from active to archived.
Except for the O2 wire for the A/F gauge, everything else is plug and go.
[This message has been edited by 30+mpg (edited 06-12-2006).]
30+mpg
Total ratings: 97
Report this Post04-19-2006 07:04 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
A good use for the Kansas City Star newspaper.
30+mpg
Total ratings: 97
Report this Post04-21-2006 08:51 AM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mixing sticks notched at
8/11's-paint,
2/11's-reducer,
1/11-catalyst
Viper red and Maroon mixed yields a blood red or barn red. Lighter than the car's current stock medium red.
