87 Coupe project by 30+mpg
Started on : 06-17-2005 06:31 PM
Replies : 388 (28408 views)
Last post by : 30+mpg on 10-30-2024 07:50 PM
Apr 11th, 2012
30+mpg Member Posts: 4061 From: Russellville, AR Registered: Feb 2002
Project will be 7 years old on Sunday. Most people who bought new cars 7 years ago have traded them in by now.
11:08 PM
Apr 14th, 2012
Apr 24th, 2012
From this;
to this:
to this:
[This message has been edited by 30+mpg (edited 04-24-2012).]
11:56 AM
May 4th, 2012
A/C charge is down. I suspect a leaking clutch shaft seal in the compressor.
No prob, I'll swap it out for my spare HR6.
But first, a check of the spare reveals a seal leak also.
So, I replaced the seal.
Here's a shot of some of the tools I used, plus a spare seal.
Note the port block-off plate which allows one to pressure test the compressor after the clutch plate has been removed.
One tool not pictured is an electronic sniffer with an adjustable beep/sensitivity rate.
Now to jack up the car & swap compressors. A fun job.
04:30 PM
josef644 Member Posts: 6939 From: Dickinson, Texas USA Registered: Nov 2006
Can ya come over this weekend and fix my AC? Texas isn't to far is it? Keep up the good work and with the pictures and posts. -Joe
07:51 PM
May 12th, 2012
Changed oil, 4 qts Mobil 10W-30 + AC PF47 filter.
12:59 PM
FieroMaster88 Member Posts: 7680 From: Mattawan, MI Registered: Nov 2000
Engine is looking good!
01:22 PM
el_roy1985 Member Posts: 295 From: Bismarck, ND, USA Registered: Jun 2004
You do some great work. Got yourself a good lookin Fiero there too.
01:43 PM
May 19th, 2012
Before I swapped compressors, I used some fluorescent dye & a UV led flashlight to see if I could fine the leak.
Note the green band of liquid where the body & end casting mate.
The green is the dye.
Using the UV light w/o the camera flash, the liquid appears as bright yellow.
Also, there is a similar, but smaller, leak on the opposite end of the compressor body.
The compressor doesn't have a Harrison sticker.
Instead it has a sticker with the name of the compressor rebuilder. They did a poor job of sealing.
[This message has been edited by 30+mpg (edited 05-19-2012).]
05:21 PM
May 22nd, 2012
Right rear brake is dragging. Time to relube the sliders.
08:58 PM
May 23rd, 2012
Relubed the sliders on both rear wheels. Check your wheels after a short drive. If one feels hotter than the rest, dragging brakes. Time to lube the sliders. Meanwhile, the spare HR6 compressor has bigger leaks in exactly the same place as the previous compressor, bummer. Those large ring seals must be a longevity problem. Sooooo, I bought a freshly re-manufactured compressor for an 88 Buick Park Ave off e-bay for $64 which includes shipping.
05:04 PM
Jun 18th, 2012
Went for a 20 minute drive in 90F+ degree weather. Vent thermometer read in the low 30's when controls were set to MAX.
09:59 AM
Jul 1st, 2012
My Username Is Member Posts: 41 From: US Registered: Jun 2012
I'm impressed that someone- anyone, has been able to keep a thread like this alive for so long.
Thanks for sharing this all these years.
09:48 PM
Jul 2nd, 2012
quote Originally posted by 30+mpg: Looks like the hot temps have fried the battery. 3 years on a WalMart Everstart 75-5S
Good news, sanded the terminal connections to the battery.
3 year old battery cranks great now.
03:40 PM
Sep 1st, 2012
Ignition lock cylinder made a loud click when the engine was switched off. Then it would turn to IGN but not go to Start. Looks like time to replace the lock cylinder
10:29 PM
Sep 2nd, 2012
I put a new one in mine when I first brought it home to Texas. Not to bad of a job. -Joe
09:57 AM
Sep 17th, 2012
New lock cylinder works perfectly.
11:06 PM
Feb 19th, 2013
Running strong.
05:29 PM
Quad Raider Member Posts: 865 From: Oologah, Oklahoma Registered: Dec 2010
Are you being overrun by all the bass fishermen practicing for the Bassmaster Classic?
05:31 PM
Feb 20th, 2013
Back in R'ville.
06:47 PM
Mar 26th, 2013
No problems.
07:39 PM
Apr 15th, 2013
I've had this car for 8 years now & the project has progressed to a use and maintain stage.
11:38 PM
Jul 3rd, 2013
Burnt aroma. Using infared temp gun, l r brake disc: 105F Right rear disc: 305F Sliders stuck, time to relube,
03:27 PM
A few squirts of this applied to the sliders O-rings fixed the problem,
If they would only truly Sta-Lubed.
05:18 PM
Jul 11th, 2013
86138 ODO new Altimax HP's on the front to replace the old touring TA's 205-60/15
03:16 PM
Jul 18th, 2013
Non-start due to no fuel pressure.
No relay click when ign is switched on.
Massaged wiring (a spaghetti pile) and restored relay function.
Starts normally now.
01:38 PM
92wastheyear Member Posts: 418 From: Aloha, Oregon Registered: Jun 2013
quote Originally posted by 30+mpg: Non-start due to no fuel pressure. No relay click when ign is switched on. Massaged wiring (a spaghetti pile) and restored relay function. Starts normally now.
Quit massaging your spaghetti in public...jus' sayin'
03:24 PM
Jul 24th, 2013
quote Originally posted by 92wastheyear: Quit massaging your spaghetti in public...jus' sayin'
Actually I did it in the dark privacy of my garage.
You want I should post a video on Youtube or something?
06:04 PM
Start problem returned.
Inspection of the wiring showed the wire T-spliced by wrapping one wire around a bared section and soldering the first wire to...... itself. Check it out:
Whoever done the wiring coulda done a better job.
Re-soldered wire using flux and enough solder to flow onto both wires.
Problem solved!
P.S. How's that for spaghetti?
[This message has been edited by 30+mpg (edited 07-24-2013).]
06:09 PM
Aug 5th, 2013
zkhennings Member Posts: 1931 From: Massachusetts, USA Registered: Oct 2010
quote Originally posted by 30+mpg: A few squirts of this applied to the sliders O-rings fixed the problem, If they would only truly Sta-Lubed.
If only... try a different lubricant, maybe a thicker lubricant will hang around longer
12:33 PM
Feb 9th, 2014
dematrix86gt Member Posts: 490 From: havana arkansas Registered: Jul 2013
still running strong?
02:20 PM
Mar 11th, 2014
L rear brake disc 250F R rear Brake disc 96F Time for more slider lube.
06:46 PM
Apr 17th, 2014
Relubed sliders. 9 years and stable.
11:33 PM
May 27th, 2014
Cool!
80 degrees F outside
[This message has been edited by 30+mpg (edited 05-27-2014).]
01:27 PM
notwohorns Member Posts: 1175 From: greenville, il. usa Registered: Jul 2009
reading through the different pages, you said you disassembled and repaired the power window switch. How did you get it apart?. I tried taking one apart but the little stud that holds the spring broke.
01:50 PM
You can try to JB Weld the stud in place.
02:25 PM
Oct 4th, 2014
3 discs 105 F RR 349F anyone have a better slider lube?
05:01 PM
Dec 23rd, 2014
Brakes fixed long ago. Left headlight won't rise.
06:48 PM
jmbishop Member Posts: 4484 From: Probably Texas Registered: Jul 2006
What was fix for the brake?
08:09 PM
