  A List of Indy VIN’s (Page 6)
A List of Indy VIN’s by ohioindy
Started on: 08-11-2005 12:16 PM
Replies: 292 (15281 views)
Last post by: Irocnroll89 on 03-07-2023 07:12 PM
johnyrottin
Total ratings: 85
Report this Post05-23-2011 09:49 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine was on one list but not the other...hence the post.
Page 6...boo-ya!
[This message has been edited by johnyrottin (edited 05-23-2011).]
Ramblerman
Report this Post09-09-2011 06:35 AM Click Here to See the Profile for RamblermanSend a Private Message to RamblermanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello! Please help me figure this out! I just bought what I believe to be Pace Car #1903. There is some speculation, however, that it may be a clone. I have done a lot of searching on this forum, and there is a ton of good info on the Indy Pace Cars...
My question is this: Is the Pace Car serial number that is associated with the VIN of each car (in my case #1903) on an official list where someone can confirm it is actually a Pace Car? I read about a Pontiac fax that sold on eBay, but I presume no one here has that list? I do not believe that there is a serial number plate on each Pace Car, right? So...the only way to look up the number is on a list? PLEASE HELP me confirm that I have one of the 2000 cars, and not someone's made-up entry on a list (if that's possible)!
Thanks, Daniel
ohioindy
Total ratings: 60
Report this Post09-09-2011 05:04 PM Click Here to See the Profile for ohioindyClick Here to visit ohioindy's HomePageSend a Private Message to ohioindyEdit/Delete MessageReply w/QuoteDirect Link to This Post
To tell if your car is a true Indy on the front inner fender well on the drivers side there should be a white tag with a bunch of numbers and letters.
This is the build tag if it says Y82 she is an Indy
Post the VIN and the transmission type so we can record the info
http://www.fieropacecar.com/
Factory Stock
The way God intended it to be.
[This message has been edited by ohioindy (edited 09-09-2011).]
Ramblerman
Report this Post09-09-2011 07:27 PM Click Here to See the Profile for RamblermanSend a Private Message to RamblermanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unfortunately, this is part of my problem! I did the research and found out about the Y82 RPO code (and the other codes that come along with Y82 when you have the pace car). My RPO sheet that is supposed to be on the inner fender near the master cylinder is missing! :-( This was one of the reasons I am not sure about the true status of my car! Unless these RPO sticker sheets fall off easily, I find it hard to believe that someone would deliberately remove it or paint over it.
My VIN is 1G2AF37R2EP272528. It is on one of the lists earlier in this thread, but was it added by someone trying to get away with passing off a pace car clone or does "the list" that this VIN is on confirm 100% that it is a pace car!?!?
Thanks in advance,
Daniel
ohioindy
Total ratings: 60
Report this Post09-09-2011 08:00 PM Click Here to See the Profile for ohioindyClick Here to visit ohioindy's HomePageSend a Private Message to ohioindyEdit/Delete MessageReply w/QuoteDirect Link to This Post
1903- 1G2AF37R2EP272528 Manual 80,778 3.4 swap Tucson, AZ
From the VIN list at http://www.fieropacecar.com/ ..it is real and is #1903
Factory Stock
Ramblerman
Report this Post09-09-2011 10:34 PM Click Here to See the Profile for RamblermanSend a Private Message to RamblermanEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is great news! My car looked sooo suspicious having a different engine, aftermarket wheels, no RPO build sheet, and paint overspray in odd places!
I talked to Rick by email and he is going to check out my login registration for me! Until then, it should be noted that the 3.4 V6 has been removed and a 2.8 Fiero V6 from '85 has been installed. It still has the original 4-speed manual.
Thanks,
Daniel
FieroMaster88
Total ratings: 168
Report this Post09-28-2011 10:12 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
SuperchargedV6, you have a PM.
I now own Indy #64. It's a little rough but I'll get it fixed up in no time.
88 Coupe: 2.0L Turbo 4 Cylinder
84 Indy #64: Restoration Project!
[This message has been edited by FieroMaster88 (edited 09-28-2011).]
johnyrottin
Total ratings: 85
Report this Post09-29-2011 06:39 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Driving down the road and saw one at a towing company!!! I willl make phone calls and get info this weekend. Looks to be a really good one...clean and drivable.
redraif
Report this Post11-07-2011 10:53 PM Click Here to See the Profile for redraifSend a Private Message to redraifEdit/Delete MessageReply w/QuoteDirect Link to This Post
wow so I thought I posted my indy's info here, but I can't find it in the thread. guess it was another one. Tried to look on the pace car forum mentioned earlier, but I can't get on...
1G2AF37R0EP255792
Manual, sunroof, map pockets, Busted OD= 77,774... Did not work when I got it. Hampton, GA.
I think it was #770... can anyone verify??? How is this # figured out. Does it come off a master list?
Rescued & resuscitated 1984 Indy Fiero Pace Car presently reversibly modified...LOL!
[This message has been edited by redraif (edited 11-07-2011).]
FieroMontreal
Report this Post11-08-2011 10:14 PM Click Here to See the Profile for FieroMontrealSend a Private Message to FieroMontrealEdit/Delete MessageReply w/QuoteDirect Link to This Post
I found one for sale as a parts car in Quebec. it's an automatic with around 200,000km
1G2AF37RXEP252236
Fiero2m8
Report this Post11-08-2011 10:44 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Ohioindy, never knew mine was #1620
Indy Northstar-Stretch
redraif
Report this Post11-08-2011 11:55 PM Click Here to See the Profile for redraifSend a Private Message to redraifEdit/Delete MessageReply w/QuoteDirect Link to This Post
how are you able to see the vin list? I have been trying for months and can't even get on w/o registering (which I thought I had already) but no one will approve my registration.
redraif
Report this Post11-14-2011 08:20 PM Click Here to See the Profile for redraifSend a Private Message to redraifEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump for addition to the list, confirmation on production number and info on Indy forum.
[This message has been edited by redraif (edited 11-14-2011).]
redraif
Report this Post11-19-2011 09:50 PM Click Here to See the Profile for redraifSend a Private Message to redraifEdit/Delete MessageReply w/QuoteDirect Link to This Post
back with access to the pace car forum... Yeah
[This message has been edited by redraif (edited 11-19-2011).]
NeoMike
Report this Post02-27-2012 09:15 PM Click Here to See the Profile for NeoMikeSend a Private Message to NeoMikeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is my Indy's information:
1G2AF37R7EP27116 Manual 030062 Lexington, SC
I was posting this on another thread, strange that it showed up here.
[This message has been edited by NeoMike (edited 02-27-2012).]
NeoMike
Report this Post02-27-2012 09:16 PM Click Here to See the Profile for NeoMikeSend a Private Message to NeoMikeEdit/Delete MessageReply w/QuoteDirect Link to This Post
NeoMike
Member since Feb 2012
memorybike
Report this Post06-08-2012 10:23 PM Click Here to See the Profile for memorybikeSend a Private Message to memorybikeEdit/Delete MessageReply w/QuoteDirect Link to This Post
1G2AF37R4EP272854. NB Canada. Manual.
SuperchargedV6
Total ratings: 175
Report this Post06-09-2012 09:34 AM Click Here to See the Profile for SuperchargedV6Send a Private Message to SuperchargedV6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you and 1G2AF37R4EP272854 is car # 1953. I added it to the official list at www.FieroPaceCar.com. I am seeing by the list that many of the last cars went to Canada and still reside there which is neat. Rick B
convertible06
Report this Post06-13-2012 07:33 PM Click Here to See the Profile for convertible06Send a Private Message to convertible06Edit/Delete MessageReply w/QuoteDirect Link to This Post
This one is on the list but is now owned by me and resides in Woodstock, Georgia - 1G2AF37R8EP247813 list as in St. Pete Fl.
E.Furgal
Total ratings: 278
Report this Post06-13-2012 07:41 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
is there a spred sheet with a list of those already entered..
I mean mine might already be listed from the p/o
I'll have to pull the reg. and type it in here..
SuperchargedV6
Total ratings: 175
Report this Post06-13-2012 10:29 PM Click Here to See the Profile for SuperchargedV6Send a Private Message to SuperchargedV6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes it is here www.FieroPaceCar.com but you have to join. I own the Manufactures list and own the Indy track cars list for all the cars used that month. When I had it open to public I was getting blasted with spam and **** . I really need to set down with my tech guy and have him put in some preventative stuff so I can open back up to public.
Updated Convertible06 at my site. I haven't updated this list in years and it would defeat my purpose of having a web page just for the Indy. Two list can get hard to keep up with. Rick B
[This message has been edited by SuperchargedV6 (edited 06-13-2012).]
85red2m6
Report this Post07-25-2012 09:41 AM Click Here to See the Profile for 85red2m6Send a Private Message to 85red2m6Edit/Delete MessageReply w/QuoteDirect Link to This Post
SuperchargedV6...
are you still doing VIN verifications?
and do you have a list (or co-ordinated with a list) as to where these cars are?
I'm looking at a car here in Alberta (Canada) that claims to be #1612, but it's a good hour's drive from me, and he's asking a fair bit for it considering the mileage (209,000km) and the fact that it needs a clutch...
I've emailed him requesting the VIN for verification, waiting on a reply...
1986 Fiero SE 2.8 Auto - Blackie
1985 Fiero GT 2.8 4-spd - Goldie II - To be driveable this season
1985 Fiero SE Targa - 3.8SC - long term project
1987 Cavalier Z24 2.8 5-spd - daily beaten driver
1993 Bonneville SSEi - 3800SC donor for 85 Targa
[This message has been edited by 85red2m6 (edited 07-25-2012).]
SCCA FIERO
Total ratings: 93
Report this Post09-11-2012 08:20 PM Click Here to See the Profile for SCCA FIEROSend a Private Message to SCCA FIEROEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found one in Tremonton, Utah in a junkyard (the owner of the yard owns the car). It's not being parted, but it probably should be. He wants $2,000 for it, it might be worth $500.
I think it had 130,000 miles on it. 4 speed.
1G2AF37R4EP269753
fierosound
Total ratings: 287
Report this Post09-11-2012 09:12 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Canadian INDY for sale - Vancouver Island B.C.
The VIN# 1G2AF37R2EP272142
Has 117,289 kilometers on it. (73,305 miles)
http://www.fivestarautosale...2dc9f678357222e54726
Bdawwg
Report this Post09-26-2012 08:59 PM Click Here to See the Profile for BdawwgSend a Private Message to BdawwgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can anybody help me with the VIN for my Indy? The admin at the pacecar site still hasn't accepted me after 5 days. My Indy's VIN is: 1G2AF37R6EP264660. Thanks! I'm trying to figure out which one mine is for a potential custom license plate.
[This message has been edited by Bdawwg (edited 09-26-2012).]
RWDPLZ
Total ratings: 306
Report this Post09-26-2012 09:17 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just made a post over there asking about it, hopefully you'll hear back soon. The admin over there, rborecky, hasn't posted since the 22nd, so he might just be busy.
Bdawwg
Report this Post09-26-2012 10:03 PM Click Here to See the Profile for BdawwgSend a Private Message to BdawwgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks a bunch man!
SuperchargedV6
Total ratings: 175
Report this Post09-27-2012 11:26 AM Click Here to See the Profile for SuperchargedV6Send a Private Message to SuperchargedV6Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm at work now but will dig it up and put it through when I get home. The issue most don't see is that I receive about 30 requests daily from phishing sights that have spammed some pretty bad stuff on my sight. I try to look them over and look at the email addy's to see if I think they are legit. Names like GGhhajdutn or 45ghty67dju6 for example got tossed as they are just like phishers names. Emails from known spam areas like Russia are tossed. It is getting tougher for me now with so many oddball email address coming out but I try to send a request asking if it is a real person.
I am sorry for the delay and hope you understand. I will go in right now and if you used the same name it will come up. I will put it through if so. Rick B
SuperchargedV6
Total ratings: 175
Report this Post09-27-2012 11:31 AM Click Here to See the Profile for SuperchargedV6Send a Private Message to SuperchargedV6Edit/Delete MessageReply w/QuoteDirect Link to This Post
SuperchargedV6
Member since Jan 2006
If you get a moment email me the name you registered under. I can pull it up through the program and put you through. This way I make sure I have the correct name. Thanks,Rick B
Rborecky@Roadrunner.com
E.Furgal
Total ratings: 278
Report this Post09-27-2012 04:23 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
my INDY
bought 3/21/2012
vin# 1G2AF37R9EP271442
SuperchargedV6
Total ratings: 175
Report this Post09-27-2012 04:42 PM Click Here to See the Profile for SuperchargedV6Send a Private Message to SuperchargedV6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by E.Furgal:
my INDY
bought 3/21/2012
Shows on my known alive list as 1722- 1G2AF37R9EP271442 Auto 90,000 Can I get the location to finish it on the list? Thanks,,Rick
E.Furgal
Total ratings: 278
Report this Post09-27-2012 05:21 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
location is under my avatar..
there is another one one town over,, sadly he's making a back to the future silver p.o.s. out of it..
I'm try'n to get ahold of the guy to see if I can get the indy call out that are on hood/fenders that he removed and hopefully didn't deep 6
my car was in N.H. thats where I got it
[This message has been edited by E.Furgal (edited 09-27-2012).]
SuperchargedV6
Total ratings: 175
Report this Post09-27-2012 08:53 PM Click Here to See the Profile for SuperchargedV6Send a Private Message to SuperchargedV6Edit/Delete MessageReply w/QuoteDirect Link to This Post
1G2AF37R4EP269753
This vin is incorrect. Would it be 58 not 53 at the end??? Rick B
SCCA FIERO
Total ratings: 93
Report this Post09-27-2012 09:54 PM Click Here to See the Profile for SCCA FIEROSend a Private Message to SCCA FIEROEdit/Delete MessageReply w/QuoteDirect Link to This Post
Checked my cell phone pics, and you're right, it is an 8.
Also the mileage is 120,338.
SuperchargedV6
Total ratings: 175
Report this Post10-28-2012 08:36 AM Click Here to See the Profile for SuperchargedV6Send a Private Message to SuperchargedV6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks and that car is #1497. Rick B
WWW.FieroPaceCar.com
animal
Report this Post10-29-2012 07:55 AM Click Here to See the Profile for animalSend a Private Message to animalEdit/Delete MessageReply w/QuoteDirect Link to This Post
I purchased an Indy last week and registered on fieropacecar.com, but haven't yet been approved to access the site to check or enter my VIN# and update the location of the car. It says I'll get an email, but nothing yet. Is there something else I need to do to be able to log on?
SuperchargedV6
Total ratings: 175
Report this Post10-29-2012 10:34 AM Click Here to See the Profile for SuperchargedV6Send a Private Message to SuperchargedV6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Something had to be strange looking and I ignored it. I usually try to go through the multiple request and search out the real from the Phishers I get daily. I toss 100 for every real request I get sometimes more so it gets hard at times. I send out a confirmation email to try and make sure and passed yours by. Rborecky@roadrunner.com is my email for others with this problem. Hit me up with your name if you do not hear from me in a few days.
Animal I dug in and found your request. I think I mistaked your request for the Russian Phishers I get not realizing it was Roadrunner.. Sorry for the delay. Rick B
[This message has been edited by SuperchargedV6 (edited 10-29-2012).]
Dburger
Report this Post12-12-2012 06:05 PM Click Here to See the Profile for DburgerSend a Private Message to DburgerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's one for you. Don't know if it's on the list yet.
1G2AF37ROEP271832
SuperchargedV6
Total ratings: 175
Report this Post12-12-2012 09:26 PM Click Here to See the Profile for SuperchargedV6Send a Private Message to SuperchargedV6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yep that one is on the list. Here was the info when listed. Thanks,,Rick B
1787- 1G2AF37ROEP271832 Manual 64,381 miles Dorchester, NE
Dburger
Report this Post02-28-2013 07:03 PM Click Here to See the Profile for DburgerSend a Private Message to DburgerEdit/Delete MessageReply w/QuoteDirect Link to This Post
1G2AF37R1EP251590
4 speed, 108,810 miles
On ebay at $698.00 reserve met
http://cgi.ebay.com/ebaymotors/pace-car-/221193054130?ViewItem=&item=221193054130&lgeo=1&vectorid=229466&forcev4exp= true#ht_500wt_1182
Edit: I registered under the name of Dburger on Fieropacecar.com but my account hasn't been activated yet.
[This message has been edited by Dburger (edited 02-28-2013).]
