3800 Conversion Mounts are back ! by PURPLE REIGN
Started on | : 10-30-2006 02:46 AM |
Replies | : 696 (49201 views) |
Last post by | : Twoolz on 05-07-2017 11:47 AM |
Oct 23rd, 2007
MstangsBware Member Posts: 11509 From: TEXAS Registered: Mar 2002
| quote | Originally posted by PURPLE REIGN:
I'm working on it.
Now that this current swap is done I'll have more time..................I'm also looking for one of those transmissions as a test piece. |
I dont have a transmision I can send you for a test fit but---If you make the part and needs someone to test it out, I need one for my LS4 swap that I am slowly working on. If you get them made soon, let me know being I need one and am holding out from paying what WCF wants for them.
11:14 AM
darkhorizon Member Posts: 12279 From: Flint Michigan Registered: Jan 2006
If I get a hold of one of these trannies, Ill make one up for ya, mstangs.
11:49 AM
Nov 13th, 2007
PURPLE REIGN Member Posts: 4080 From: Minnesnowta ------------------ Land of White Gold Registered: Sep 2002
01:19 AM
Dec 15th, 2007
carbon Member Posts: 4767 From: Eagan, MN Registered: Apr 2004
Well the mounts were originated to fit 88 to 2003 440T4, 4T60, 4T60e, 4T60e HD, 4T65e, & 4T65e HD, transmission with the the 4 stud bosses on the rear. We have only run into an extremely small amount of transmissions with different boss patterns. Your only solution is to modify the mount or find a trans with the 4 boss pattern.
Unless by some miracle I can get one of those trannies and make a mount for it.
Does it at least sit level on the bosses ? |
By my awesom F*$!%& luck I have that very same transmission attached to the 3400 that I bought from Darrell Morse. It is sitting, as we speak, in my garage. This makes me want to hurt myself... I cannot catch a break. F'in Grrrrr.  P.S. It appears that the casting is different due to the fact that the tranny was originally mounted via bosses on the side cover of the transmission. The mount bracket was still bolted to the tranny when I got it. [This message has been edited by carbon (edited 12-15-2007).]
09:34 PM
Dec 19th, 2007
CorvetteFan86 Member Posts: 167 From: Martinsburg, WV US Registered: Mar 2007
Hello Purple Reign, I was wondering if you still sell the poly 3800sc conversion mounts? If you do i would like to buy the 3 piece set intended for replacement of stock rubber mounts for the manual tranny. Just send me the info.
Thank you,
Tommy
09:36 PM
| quote | Originally posted by CorvetteFan86:
Thank you,
Tommy |
Yes sir. The 3 piece poly mount set should be $200 shipped....................I'm finishing some right now.
09:41 PM
Dec 20th, 2007
is this still the correct paypal address ayoraway@yahoo.com? Thanks, Tommy [This message has been edited by CorvetteFan86 (edited 12-20-2007).]
10:13 AM
Thanks, Tommy
Yep
10:46 AM
paypal sent. thanks
11:28 AM
Dec 23rd, 2007
85GT_3800SC Member Posts: 92 From: Thunder Bay , Ontario , Canada Registered: Nov 2007
Hey, Purple Reign. Just wondering what the status of my auto kit, ordered and paypaled on Nov. 25, is.(4t65e-hd). Thanks.......Al.
03:21 PM
Dec 24th, 2007
| quote | Originally posted by 85GT_3800SC:
Hey, Purple Reign. Just wondering what the status of my auto kit, ordered and paypaled on Nov. 25, is.(4t65e-hd). Thanks.......Al. |
They're next to me in a box, just need to get a shipping label on & get off my busy bum and send them
04:46 AM
Dec 28th, 2007
Bump
06:13 PM
Jan 3rd, 2008
85sliverGT Member Posts: 1525 From: Burnsville, MN Registered: Sep 2005
shawn- do you have any low mount alt. brackets made up right now?
04:41 PM
Saxman Member Posts: 5151 From: Melbourne, FL Registered: May 2005
Sorry I haven't read this entire thread, but do you have mounts that work well for an 88? I read in the beginning that the holes were a bit different.
Thanks!
04:47 PM
| quote | Originally posted by Saxman:
Thanks! |
You're right, and they still are. It's just the one front lower engine mount that you'll need to mark on the "pad" of the cradle & redrill. Rather simple, and nobody has really had and issue with it. | quote | Originally posted by 85sliverGT:
shawn- do you have any low mount alt. brackets made up right now? |
Yes I have 5 currently made. I was going to get ahold of your dad cause I'm almost out of poly. | quote | Originally posted by CorvetteFan86:
Bump |
Update: I checked the outgoing boxed and found the Canadian shipment was complete, and yours was missing the front half of the lower engine mount. I'll have it made up & out ASAP.
10:49 PM
Jan 4th, 2008
wow that was alot of poly. give him a call, im sure he'll work something out with you
10:04 AM
Cant find the #
12:09 PM
952-237-3210 (jon)
12:34 PM
chrisgtp Member Posts: 411 From: st.louis mo Registered: Nov 2006
have you ever mocked up a bracket to put the alt where the ac goes?
12:35 PM
| quote | Originally posted by chrisgtp:
have you ever mocked up a bracket to put the alt where the ac goes? |
Cant say I have.........................this is only the second request for such an item. Most everyone wants thier A/C or at least have the option.
07:30 PM
Jan 8th, 2008
88formulaman Member Posts: 83 From: Colorado Springs Registered: Apr 2000
i need to get an alt bracket, i sent ya a pm but no response. thanks ------------------ Glenn Lintemuth A&P Mechanic Colorado Springs, CO 88' Convertible "BeyondGT" 88' GT, white 5speed 89' K-5 Blazer on 44's 04' Silverado Ext Z71 on 33's
02:55 PM
| quote | Originally posted by 88formulaman:
Sorry...................my time on the computer is rather infrequent. I try to check in at least 2 times a week. P.M. back
04:09 PM
Jan 9th, 2008
Hello Purple Reign, I was just checking on the status of my poly mounts its the 3 piece set intended for replacement of stock rubber mounts for the manual tranny.
Thanks, Tommy
11:40 AM
Fierosmith Member Posts: 568 From: East Texas, USA Registered: Jun 2007
PM sent
Tks Jim
10:59 PM
Jan 16th, 2008
Dracor Member Posts: 466 From: Houston, TX Registered: Jan 2008
Hey Purple, do you have a full set for the Manual Conversion made up?
10:22 AM
Sorry for the delay in response to P.M.'s I had a really bad accident at the shop last week with a utility knife. I wound up with 2 deep lacerations in the left arm, lots of damage to muscle tissue, nerves, 1 artery, and 1 tendon. The blood was flowing so fast I thought I'd pass-out. Normally I'm alone at the shop at night ( which means I would have bleed to death ) but my mom stopped by to drop of parts when it happened. Got re-constructive surgery on Thursday, and they wont let me use it at all. Makes for really hard & slow typing. And of coarse no work | quote | Originally posted by CorvetteFan86: Hello Purple Reign, I was just checking on the status of my poly mounts its the 3 piece set intended for replacement of stock rubber mounts for the manual tranny. Thanks, Tommy |
You should definatly have these. Either wise let me know. | quote | Originally posted by Fierosmith:
PM sent
Tks Jim |
P.M. back | quote | Originally posted by Dracor:
Hey Purple, do you have a full set for the Manual Conversion made up? |
Working on them now. Should have more sets by the end of the week.
02:14 PM
justa6 Member Posts: 1968 From: twin cites, mn Registered: Jul 2004
good thing you're right handed  jk hope you heal up quick.
06:01 PM
Jan 17th, 2008
MulletproofMonk Member Posts: 3092 From: Dayton, OH (Bellbrook, OH 45305) Registered: Oct 2005
PR, Sorry to hear about your accident. Do you still have some the low-alt bracket made up? I bought some motor mounts from you in September, I still haven't gotten around to using them, and I figure I better kick this winter project off or it won't be ready in the Spring. Let me know if you can still ship with the other hand...  Brian ------------------
~~~~~~~~~~~~~~~~~~~~~~~ Business up front, party in the back... ~~~~~~~~~~~~~~~~~~~~~~~
05:40 PM
| quote | Originally posted by MulletproofMonk:
Brian
Yes, thank GOD I'm ahead by 5 of those brackets. LMK when you want it.
07:05 PM
Jan 19th, 2008
I'm very sorry to hear that! I hope you get back to normal hopefully. and thanks again, Thomas | quote | Originally posted by PURPLE REIGN:
Working on them now. Should have more sets by the end of the week. |
05:09 PM
MordacP Member Posts: 1300 From: Clovis, California, US Registered: Sep 2007
So, just to be sure. With these mounts, I can stick a 3800SC in my fiero? It sounds too good to be true.
10:42 PM
FierociousGT Member Posts: 2307 From: Registered: Jan 2007
PR, do you have a website with your products?
thx
11:36 PM
Jan 20th, 2008
| quote | Originally posted by MordacP:
So, just to be sure. With these mounts, I can stick a 3800SC in my fiero? It sounds too good to be true. |
Correct. Although you will want to install a dogbone, and of course finish the conversion | quote | Originally posted by FierociousGT:
thx |
Not yet. Been working on that, and had a small shop site put together, but put it on the back-burner cause I'm partnering up with a buddy and taking the website to a MUCH BIGGER level. About the size of a Jeg's or Summit Racing.
01:13 AM
Jan 21st, 2008
Purple Reign, when you see this please e-mail me.
Thanks, Thomas
06:11 PM
Jan 26th, 2008
Winkie Member Posts: 1159 From: bangor, PA Registered: Feb 2007
Hey
I need the front conversion bracket. PM me and I'll give you my info.
Thanks Ryan
04:32 PM
Feb 10th, 2008
War Hammer Member Posts: 377 From: Myrtle Beach, SC USA Registered: Jan 2008
Hi PR, I have an ACE converted 3800sc Series 1 88 Coupe. My Alt is on top. Is there a lower alt bracket for this combo? How much if so? Also since the alt is where a dogbone would go, is there a bracket so I can mount a dogbone on top as I don't have one now? Thanks, Paul ------------------ 1988 Fiero 3800SC Series 1 w/5spd Coilovers 18's w/Pirellis Corvette Dash Mod
1985 GT 1986 Notchie 1987 Notchie
01:00 AM
A1MEFGT8488 Member Posts: 37 From: CA, USA Registered: Jan 2008
Hello Purple Reign, I'd like to get a set for 88 cradle when available. Let me know, Thanks.
03:10 PM
| quote | Originally posted by War Hammer:
Thanks, Paul
At the beginning of this thread I showed a pic & pricing on the low Alt/dogbone bracket assembly. This is just one of a couple ways of solving the alternator & motor mount issue. Loyde also make a solution to this, so let me know which one you'd like. | quote | Originally posted by A1MEFGT8488:
Hello Purple Reign, I'd like to get a set for 88 cradle when available. Let me know, Thanks. |
Not a problem. I'll keep everyone updated as fast as they get done.
11:09 PM
Feb 11th, 2008
Not a problem. I'll keep everyone updated as fast as they get done. |
Hi PR, I looked at the beginning of the post but is states that I have to have the original bracket off my car. My car was converted by ACE to 3800sc series 1 and I do not have the piece you are talking about. What should I do? Thanks! Paul ------------------ 1988 Fiero 3800SC Series 1 w/5spd Coilovers 18's w/Pirellis Corvette Dash Mod
12:05 AM
Hi PR,
Thanks! Paul
My bad.......................I should have looked closer to your post. This works for a series 2, but I am working on doing this to the series 1 for "KEV". I haven't yet figured out how to do the mount part yet.
10:34 PM
