3800 Conversion Mounts are back ! by PURPLE REIGN
Started on | : 10-30-2006 02:46 AM |
Replies | : 696 (49204 views) |
Last post by | : Twoolz on 05-07-2017 11:47 AM |
Nov 6th, 2006
PURPLE REIGN Member Posts: 4080 From: Minnesnowta ------------------ Land of White Gold Registered: Sep 2002
| quote | Originally posted by CETICARS:
which set to mount the 4t60 tranny to my other Ecotec swap an how much
The 2 trans adapter brackets are $55 each unless you want to use a poly mount below it to replace the stock rubber mount. The poly lower mounts are $60 each or $230 for all 4 pieces. [This message has been edited by PURPLE REIGN (edited 11-06-2006).]
11:34 AM
DILYSI Member Posts: 69 From: Indianapolis, IN Registered: Sep 2002
Will the manual mounts lower the trans (5 speed) any or will they still be at stock height?
12:40 PM
revin Member Posts: 8684 From: Pville, TX Registered: Aug 2001
greengoblin0129 Member Posts: 2670 From: Indy Registered: Mar 2005
So when are you going to start making the flywheel for the 3800SC swap
04:51 PM
darkhorizon Member Posts: 12279 From: Flint Michigan Registered: Jan 2006
| quote | Originally posted by PURPLE REIGN:
That's easy.......................a 3800 flywheel from a mid 90's F-body, machined down to the thickness of a stock Fiero flywheel  |
so true.
06:54 PM
07:04 PM
yea but its a pain to do it all lol
07:55 PM
10:14 PM
Nov 8th, 2006
RUNDLC Member Posts: 802 From: Elk Grove, California Registered: Jul 2005
Hi PurpleR, When will you ship?
Thanks
RUNDLC
08:07 PM
Nov 9th, 2006
| quote | Originally posted by RUNDLC:
Thanks
RUNDLC |
Bump
08:41 PM
Nov 10th, 2006
| quote | Originally posted by greengoblin0129: Bump |
Yesterday..................................  the larger orders will be shipped Monday due to a missing bracket. Also got delayed a little due to shipping problems on the last few orders. I guess USPS has been TOTALLY destroying the packages by the time they get there  so I shipped them UPS. [This message has been edited by PURPLE REIGN (edited 11-10-2006).]
11:47 AM
GT40 Kit 3.8 SC Member Posts: 306 From: Wilmington Delaware USA Registered: Aug 2003
Hey Purple, I have a 95 3800 SC Series 1, 4T60E in an 85 Kit Car. It was an ACE conversion with rubber mounts. The torque from this basicly stock motor allows the inner CV to hit the cradle on the right side. Does any of your stuff help me? Kevin ------------------ 85 Fiero-based ASPP GT-40 MarkII. 3800 S/C, Auto, Held suspension all around with 2" drop spindles and sport fr. end. RCC bump-steer correction. Mr. Mike's interior.
12:07 PM
Thanks Purple for the update and tracking!
RUNDLC
01:11 PM
Nov 11th, 2006
| quote | Originally posted by GT40 Kit 3.8 SC:
Yep....................you'll probably want to go with a replacement auto kit. Bill Sessions is in the same predicament. Until I can see pice of Ace's set-up, just replacing them is the only solution.
01:16 AM
Nov 15th, 2006
Hey Purple, I sent you an email to your Yahoo address. As soon as I know what I need, you will get my order. I'm not in any hurry, just want you to know I'm a definate. I can send you pix of the ACE mods to the cradle and copies of the drawings, if you like. Thanks, Kevin ------------------ 85 Fiero-based ASPP GT-40 MarkII. 3800 S/C, Auto, Held suspension all around with 2" drop spindles and sport fr. end. RCC bump-steer correction. Mr. Mike's interior.
09:17 AM
Mount received today!! Thanks Looks very solid.
RUNDLC
06:29 PM
Nov 17th, 2006
Still havn't received mine, and it's been 2 weeks now. I was hoping to get my engine in this weekend. Can you please send me a tracking #? [This message has been edited by greengoblin0129 (edited 11-17-2006).]
09:22 AM
dguy Member Posts: 2416 From: Beckwith Township, ON, Canada Registered: Jan 2003
Welcome back, Purple. Oh and check your PMs please.
09:34 AM
Im shipping today.........................can't believe I've been working till 2:00a.m. and still cant stay caught up on work.  I'll send you the tracking # etc. They have been sitting here with the shipping label on them.................
12:47 PM
SaLvAgEd Member Posts: 973 From: Knoxville, IA Registered: Mar 2004
Hey Purple... I just sent 60 bux thru paypal, for the front adaptor bracket... I also sent you a PM.
Thanks! -Matt
04:38 PM
Nov 18th, 2006
Nov 20th, 2006
Hey was just wondering if you got that shipped out today, and if you did I would like a tracking # because I took some days off next week so I could get the motor into the car. |
Well....................when you preprint the shipping label with Paypal for USPS all I get is a delivery confirmation # 420 46227 9101 1288 8230 0708 0048 35 so even though it was shipped 2 day priority, this is all I get. Anyhow, should be there Weds or Thurs.
06:29 PM
Nov 25th, 2006
SOULCRUSHER Member Posts: 1012 From: Waldorf, MD Registered: May 2004
Sorry for the delay, I finally got pics of my ACE mounts: Passenger side motor mount   Driverside rear trans mount  Driverside Front trans mount  The problem:  tranny is resting on the cradle!
04:57 PM
11:35 PM
Nov 27th, 2006
Hey Purple, I have an ACE kit too. My front motor mount is not like that. ACE required me to cut the front mount plate off of the cradle and weld on a plate, about 1" lower. Kevin ------------------ 85 Fiero-based ASPP GT-40 MarkII. 3800 S/C, Auto, Held suspension all around with 2" drop spindles and sport fr. end. RCC bump-steer correction. Mr. Mike's interior.
02:59 PM
Nov 28th, 2006
If it's in the same spot, then all you need to do is add a 1" spacer or move it back
01:51 AM
Nov 30th, 2006
I just wanted to give 2 thumbs-up to Purple Reign... I just received my front engine bracket, and I'm very happy with the quality of the part! The parts are thick, the cuts are smooth, and the welds are solid. I can't comment on the fit though... because I'm still collecting parts for my swap... With that being said, I can recommend this part to anyone who is considering buying a bracket somewhere else, or fabricating their own. This part is very hard to beat, especially for $60, shipped!
10:27 AM
tampalinc Member Posts: 776 From: Waukesha, WI Registered: May 2001
| quote | Originally posted by PURPLE REIGN: a dogbone mount such as the one pictured in the lower right corner..................
Can you tell me what poly kit you used and what size tubing was used to make the dogbone? I need to make one of those.
06:49 PM
spookything Member Posts: 268 From: Toronto, ON, Canada Registered: Oct 2003
I am going to tell my wife that I want to get your full auto mount set for Chrismas. Can you ship to Toronto Canada so that the mounts get here before Xmas? Rick ------------------
07:24 PM
Dec 1st, 2006
| quote | Originally posted by tampalinc:
Can you tell me what poly kit you used and what size tubing was used to make the dogbone? I need to make one of those. |
The round stock I use is called 2" 11ga electric cut. It will take the stock Fiero poly dogbone kit perfectly. The custom part of the dogbone is really easy to make yourself.
02:22 AM
| quote | Originally posted by spookything:
Rick
Yes but I'll have to ship them soon. In case customs has an issue. [This message has been edited by PURPLE REIGN (edited 12-01-2006).]
02:28 AM
Dec 3rd, 2006
Well she says I can have them for Christmas but I have to order them, I think I may be buying my own gift. Hmmmm. Well I am about to Pay Pal you. PLEASE DO NOT SHIP MINE UPS they rape us Canadians with brokerage fees to cross the border. US POST is the best to allow for comfortable sitting. Rick ------------------
08:16 AM
Rick
Interesting...........................the last guy I shipped to in Canada said not to go USPS cause it takes forever to get there  [This message has been edited by PURPLE REIGN (edited 12-03-2006).]
10:44 AM
Formula88 Member Posts: 53788 From: Raleigh NC Registered: Jan 2001
If I'm using your front mount adapter with stock engine mount and Getrag mounts, are there any clearance issues with the cradle/engine compartment? I know most swaps require some trimming - V8 needs to be shifted slightly and shock tower trimmed (at least on 88), and the 3.4DOHC requires modified decklid hinge mounts, while the Northstar requires heavy cradle mods. How about the 3800SC? Given the price of gas and my plans to swap in a Corvette power steering rack, a 3800SC is starting to look like a good compromise.
12:27 PM
Jncomutt Member Posts: 8902 From: Charlotte, NC Registered: Apr 2001
You should remake this one in steel. The manual guys have been breaking them alot, myself included. I'll probably be making one in another two weeks or so...  [This message has been edited by Jncomutt (edited 12-03-2006).]
01:47 PM
I have not reallyhad any trouble with US Post taking too long. Besides if it ships early this week it will have to get here by Christmas. She won't let me have it early anyways.
Rick
04:39 PM
| quote | Originally posted by Formula88:
If I'm using your front mount adapter with stock engine mount and Getrag mounts, are there any clearance issues with the cradle/engine compartment? I know most swaps require some trimming - V8 needs to be shifted slightly and shock tower trimmed (at least on 88), and the 3.4DOHC requires modified decklid hinge mounts, while the Northstar requires heavy cradle mods. How about the 3800SC? Given the price of gas and my plans to swap in a Corvette power steering rack, a 3800SC is starting to look like a good compromise. |
No clearance issues at all. The 3800 seems to fit better than the 2.8. The 3800 only had clearance issues after an intercooler is added. | quote | Originally posted by Jncomutt:
Thought about it, but I have only warranteed one of these that I have made. That one in the pic looks like too much material was cut away from the gusset section of the bracket. Sure death for aluminum. Who welded that one anyhow ???
06:01 PM
That weld was my repair after it broke there. It might not be pretty, but it didn't break in the same spot so no complaints. I don't have it as part of my alternator, just so you know, thats where the AC used to be. That bracket for me is just dogbone and tensioner. [This message has been edited by Jncomutt (edited 12-03-2006).]
06:59 PM
Exactly, but it still looks like there is a lot of material taken away from the gusset area. I tried to find as thin of tensioner as possible as to not cut up the strength of the bracket ( since we are only using one and not 2 like GM did. Any chance you can find a thinner tensioner or one with a different offset as to not cut up the bracket ??? [This message has been edited by PURPLE REIGN (edited 12-03-2006).]
08:03 PM
