  Any and all things 3.4 DOHC........... (Page 12)
Any and all things 3.4 DOHC........... by pavo_roddy
Started on: 11-22-2006 12:30 AM
Replies: 1247 (67874 views)
Last post by: fliphone on 01-06-2024 02:30 PM
formulamoe
Report this Post10-13-2007 04:59 PM Click Here to See the Profile for formulamoeSend a Private Message to formulamoeEdit/Delete MessageReply w/QuoteDirect Link to This Post
93 DOHC in 87 Fiero. My A/C request turns on the FAN but does not engage the clutch. I tried to put two 10K resistors between pin C and pins A and B, but I do not think that 2.5Volts is the right value.
could someone tell me the voltage on pin C of the A/C pressure transducer when the A/C is operating correctly?
Thanks
I own page 12!!
[This message has been edited by formulamoe (edited 10-13-2007).]
slinger
Report this Post10-16-2007 08:45 PM Click Here to See the Profile for slingerSend a Private Message to slingerEdit/Delete MessageReply w/QuoteDirect Link to This Post
gotta but in here for a min, anyone know witch way the threds are on this bolt? its allmost striped out
sspeedstreet
Total ratings: 53
Report this Post10-16-2007 09:09 PM Click Here to See the Profile for sspeedstreetSend a Private Message to sspeedstreetEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by sspeedstreet (edited 10-16-2007).]
slinger
Report this Post10-17-2007 12:27 AM Click Here to See the Profile for slingerSend a Private Message to slingerEdit/Delete MessageReply w/QuoteDirect Link to This Post
or does it not come out..... my first dohc sorry.
Delirius
Report this Post10-17-2007 03:20 AM Click Here to See the Profile for DeliriusSend a Private Message to DeliriusEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had to drill that bolt out.
Fierobsessed
Total ratings: 147
Report this Post10-17-2007 04:45 AM Click Here to See the Profile for FierobsessedSend a Private Message to FierobsessedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Normal bolt, really fricken tight. Get a spare socket and weld it to the bolt if its too stripped. Whats a socket at autozone 4-5$? a worthy investment.
Emc209i
Total ratings: 225
Report this Post10-17-2007 11:03 AM Click Here to See the Profile for Emc209iSend a Private Message to Emc209iEdit/Delete MessageReply w/QuoteDirect Link to This Post
15mm Its normally threaded. Use heat and it will come off. Light a propain torch and heat it for about 15 seconds without melting the belt. Then use a breaker bar and a .5" socket. Then repeat with the motor in the car
slinger
Report this Post10-17-2007 12:33 PM Click Here to See the Profile for slingerSend a Private Message to slingerEdit/Delete MessageReply w/QuoteDirect Link to This Post
i dont have a welder so i might just drill it out its pritty striped, thanks guys
Emc209i
Total ratings: 225
Report this Post10-17-2007 12:54 PM Click Here to See the Profile for Emc209iSend a Private Message to Emc209iEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by Emc209i (edited 12-05-2008).]
sspeedstreet
Total ratings: 53
Report this Post10-17-2007 01:02 PM Click Here to See the Profile for sspeedstreetSend a Private Message to sspeedstreetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is there anything other than the stock harmonic damper available for our motors?
FieroWannaBe
Report this Post10-17-2007 01:04 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
A company used to make under drive pulleys, but has stropped. I don't know if any other under drive pulleys from other engines work, I'd bet that some do.
fieromadman
Total ratings: 63
Report this Post10-17-2007 02:31 PM Click Here to See the Profile for fieromadmanClick Here to visit fieromadman's HomePageSend a Private Message to fieromadmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
FFP stopped making under drive pullies? Hot damn, I should get in the buisness!
sspeedstreet
Total ratings: 53
Report this Post10-17-2007 03:05 PM Click Here to See the Profile for sspeedstreetSend a Private Message to sspeedstreetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not talking about the pulley, I mean the damper (the part the pulley bolts to).
FieroWannaBe
Report this Post10-17-2007 07:11 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am wondering if anyone has delt with the later manifolds with air pump provisions. Im not going to run a pump, so I guess I need to find a plug for the holes in the manifold, Has anyone delt with this issue?
sspeedstreet
Total ratings: 53
Report this Post10-17-2007 07:59 PM Click Here to See the Profile for sspeedstreetSend a Private Message to sspeedstreetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am wondering if anyone has dealt with the later manifolds with air pump provisions. I'm not going to run a pump, so I guess I need to find a plug for the holes in the manifold, Has anyone dealt with this issue?
By "later", do you mean '91 - '93? I wasn't aware any of the '94 - '97 motors had pumps. If it's a '91 - '93 manifold I'll trade you a non AIR manifold and we can just pay shipping to each other.
ltlfrari
Total ratings: 127
Report this Post10-17-2007 08:17 PM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd bet someone in CA would pay good money for those AIR manifolds, they are pretty hard to come by.
fieromadman
Total ratings: 63
Report this Post10-17-2007 08:27 PM Click Here to See the Profile for fieromadmanClick Here to visit fieromadman's HomePageSend a Private Message to fieromadmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
He bought a 96-97 engine if I am not mistaken... Interesting that it has those...
FieroWannaBe
Report this Post10-17-2007 09:06 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess by later I should say newer. Kind back asswards the way I said it. Its a 96 engine. So most engines dont have air manifolds? I had thought that with 94 and up almost all had the air injection.
FieroWannaBe
Report this Post10-17-2007 09:11 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
FieroWannaBe
Member since Oct 2004
As some may see by the picture, I also need a water outlet for the pump.
fieromadman
Total ratings: 63
Report this Post10-17-2007 09:29 PM Click Here to See the Profile for fieromadmanClick Here to visit fieromadman's HomePageSend a Private Message to fieromadmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I may have a water manifold thingy for you. PM me your phone number, I'll be in Oconomowoc this comming weekend you can come over and scavenge through my spare parts or pick up that water outlet if your around. And neither of the 94-95 engines that I have seen had the air **** on them. Im suprised its on the 96. And quit pussy footing around and build some headers!
FieroWannaBe
Report this Post10-17-2007 09:31 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I do have a good friend thats a welder...
Emc209i
Total ratings: 225
Report this Post10-17-2007 10:52 PM Click Here to See the Profile for Emc209iSend a Private Message to Emc209iEdit/Delete MessageReply w/QuoteDirect Link to This Post
Let me know if Jeff doesn't have one. Shipping and it's your's.
RUNDLC
Report this Post10-17-2007 11:07 PM Click Here to See the Profile for RUNDLCSend a Private Message to RUNDLCEdit/Delete MessageReply w/QuoteDirect Link to This Post
Emc, if he does not take it I really need one too zip code 95624 LMK
Thanks RUNDLC
Emc209i
Total ratings: 225
Report this Post10-17-2007 11:14 PM Click Here to See the Profile for Emc209iSend a Private Message to Emc209iEdit/Delete MessageReply w/QuoteDirect Link to This Post
...California! ... California!
If he doesn't need I'd be happy to ship it your way.
fieromadman
Total ratings: 63
Report this Post10-18-2007 01:09 AM Click Here to See the Profile for fieromadmanClick Here to visit fieromadman's HomePageSend a Private Message to fieromadmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Paul you trying to copy my avatar? Ah yes... The dark side of REVS!
Emc209i
Total ratings: 225
Report this Post10-18-2007 02:07 AM Click Here to See the Profile for Emc209iSend a Private Message to Emc209iEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hahaha, no I actually thought about that after I changed it. Seriously no I wasn't. I have an Enzo gauge as my AIM icon. So I changed to that icon and then thought... I think the RX7 guage would look sexy there. So I found the new icon and then I realized it looked alot like yours. Sorry, if it bothers you let me know and I'll put the other one back up.
fieromadman
Total ratings: 63
Report this Post10-18-2007 02:55 AM Click Here to See the Profile for fieromadmanClick Here to visit fieromadman's HomePageSend a Private Message to fieromadmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was giving you **** . Now come and diagnose my car's idle.
sspeedstreet
Total ratings: 53
Report this Post10-19-2007 12:40 PM Click Here to See the Profile for sspeedstreetSend a Private Message to sspeedstreetEdit/Delete MessageReply w/QuoteDirect Link to This Post
As there apparently are no upgrades for our dampers, I've been looking at getting mine rebuilt. I think I'm going with http://members.aol.com/damperdoc/ . My damper is off a crate motor that's never been started, but it looks like it was used as a weight for a lobster pot. This outfit does black powder coating while it's apart. He'll do any color if you supply the powder. $80.00 with the powder coating or $65.00 without.
Delirius
Report this Post10-20-2007 08:44 AM Click Here to See the Profile for DeliriusSend a Private Message to DeliriusEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been searching around and I haven't found an affordable or complete rebuild kit for the LQ1. Can anyone direct me to a such place?
Delirius
Report this Post10-21-2007 04:47 AM Click Here to See the Profile for DeliriusSend a Private Message to DeliriusEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
Erik
Total ratings: 168
Report this Post10-21-2007 05:17 AM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
try gmpartsdirect.com
FieroWannaBe
Report this Post10-21-2007 01:45 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess I'll need to find a water outlet thinger. Emc209i, still got one? anyone else?
Emc209i
Total ratings: 225
Report this Post10-21-2007 04:48 PM Click Here to See the Profile for Emc209iSend a Private Message to Emc209iEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes.
FieroWannaBe
Report this Post10-21-2007 10:28 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
just checking the 3.4 has a 1.25in radiator hose right?
fieromadman
Total ratings: 63
Report this Post10-22-2007 03:54 AM Click Here to See the Profile for fieromadmanClick Here to visit fieromadman's HomePageSend a Private Message to fieromadmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, sorry about that Dave, I really thought that my spare engine had one on it, but I guess not. Keep us updated on the swap!
FieroWannaBe
Report this Post10-22-2007 08:59 AM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
does the spare engine have an alternator?
Delirius
Report this Post10-22-2007 12:34 PM Click Here to See the Profile for DeliriusSend a Private Message to DeliriusEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been searching that site for engine kits, and they do not have them. Actually I'm in need of a re-ring set. I tried autozone they had very nice prices how ever they do not ship to Sweden.
Erik
Total ratings: 168
Report this Post10-22-2007 01:06 PM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, If you wanted to paypal me the money or send it to me for parts and shipping, I could get them for you and send them to you.PM me if interested
[This message has been edited by Erik (edited 10-22-2007).]
Erik
Total ratings: 168
Report this Post10-22-2007 01:08 PM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
Erik
Member since Jul 2002
fieromadman
Total ratings: 63
Report this Post10-22-2007 03:28 PM Click Here to See the Profile for fieromadmanClick Here to visit fieromadman's HomePageSend a Private Message to fieromadmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Doesn't someone make a gapless ring kit for the 3.4? I could have sworn they did? Sealed Power maybe? I see you posted on 60degree, you should try searching over there for the gapless ring kit.
And no the spare engine doesnt have an alternator, the engine is in pieces, basically it is a short block right now with a few odds and ends on it. I just thought that the coolent thing was still on it, but I guess crate engines dont come with those on them.
Edit: check this out for info on gaples rings: http://www.60degreev6.com/s...hlight=gapless+rings Maybe that isnt a good route to go?
[This message has been edited by fieromadman (edited 10-22-2007).]
