  Any and all things 3.4 DOHC........... (Page 21)
Any and all things 3.4 DOHC........... by pavo_roddy
Started on: 11-22-2006 12:30 AM
Replies: 1247 (68217 views)
Last post by: fliphone on 01-06-2024 02:30 PM
CC Rider
Total ratings: 61
Report this Post07-11-2008 03:30 PM Click Here to See the Profile for CC RiderSend a Private Message to CC RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like it would work but you can't use it in Calif - no cat
Doug85GT
Total ratings: 128
Report this Post07-11-2008 03:36 PM Click Here to See the Profile for Doug85GTSend a Private Message to Doug85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
True. What if I move the muffler to the left or use a different muffler? A cat may fit in there.
Anyone know if Banzai ever put it in his car? The thread ended abruptly.
CC Rider
Total ratings: 61
Report this Post07-11-2008 03:38 PM Click Here to See the Profile for CC RiderSend a Private Message to CC RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will help you build a crossover when I get back form the 25th if you want?
Doug85GT
Total ratings: 128
Report this Post07-11-2008 03:43 PM Click Here to See the Profile for Doug85GTSend a Private Message to Doug85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the offer! I'll take you up on that.
I would guess that building one like yours would be better for performance since you have better bends in it.
Doug85GT
Total ratings: 128
Report this Post07-14-2008 11:27 PM Click Here to See the Profile for Doug85GTSend a Private Message to Doug85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I saw a thread where the cam specs were posted for the stock cams. The exhaust cam had 8 degs more duration and slightly more lift. I happen to have two sets of cams so I pulled out my spare set and had a close look at them. It appears that the intake and exhaust cams are interchangeable except that the exhaust cam is about 120 deg later than the intake cam. My cams are still in the housing so I'll have to take them out and then try to switch them to verify for sure if they are interchangable but they appears to be. The main problem I would see with doing this is getting the timing correct. I suppose the way to do it would be to torque down the stock exhaust cams at the stock setting, then turn the crank backwards 240 deg and then torque the exhaust cams converted to intake cams down.
Does anyone think that using 4 exhaust cams would work?
[This message has been edited by Doug85GT (edited 07-14-2008).]
FieroWannaBe
Report this Post07-16-2008 02:58 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
It was tried by someone on 60 degree v6, and Im not sure how it turned out. I dont think it went well, but as reassurance nothing turns our well on 60degreev6 in the DOHC section. It should help, but getting the timing right is the biggest hurdle.
Erik
Total ratings: 168
Report this Post07-16-2008 06:25 PM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a question about space in the engine bay and the exhaust. I saw this photo from another build thread:
Will this fit as is or would it require cutting the trunk?
no cutting required for that
CC Rider
Total ratings: 61
Report this Post07-17-2008 08:15 PM Click Here to See the Profile for CC RiderSend a Private Message to CC RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
To close to the alternator for me
olaf_fiero27
Report this Post07-18-2008 09:29 AM Click Here to See the Profile for olaf_fiero27Send a Private Message to olaf_fiero27Edit/Delete MessageReply w/QuoteDirect Link to This Post
Guys I'm having some issues with my swap. My car seems to start up and run just fine if its been sitting for 30 mins+. As soon as I drive it to work and shut it off, SOMETIMES it doesn't want to start right back up, I have to wait like 15 minutes and then she'll fire right up. So considering its got 400 kms on the motor everything is new, so my fuel pressure is good, new plugs and wires. So I'm thinking its my coil packs, they are in the stock location and the exhaust heatsheilds are installed along with some pipe wrap. I swapped them out for a good known used set, and they seemed to work fine for the first hour, but then yeilded the same kind of results. whats the best solution for me? reroute the packs?
Doug85GT
Total ratings: 128
Report this Post07-18-2008 10:08 AM Click Here to See the Profile for Doug85GTSend a Private Message to Doug85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't assume that it is your coil packs. You need to accurately identify the problem before you start changing parts out or you will end up wasting a lot of money. Start by bringing an old spark plug with you. The next time your car does not want to start, stick the old plug into one of your plug wires and have it touching something big and metal. Then crank the engine and verify that you are getting spark. If you are, then it is time to start checking for fuel.
It is very unlikely that all 3 coils in the coil pack would stop working all at once. If your problem is no spark, then you need to look at common elements such as the ignition module or maybe some loose wiring.
Erik
Total ratings: 168
Report this Post07-18-2008 02:01 PM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you check your fuel pressure to make sure? Also have you driven it further than just to work like, drive it around for awhile to see if it starts to cut out or just dies? My first impression is maybe its vapor locking. When it acts up try bleeding the the fuel injector rail to get any air that might be in it and try starting again.
If it is electrical related, maybe your fuel injectors are not firing. When it acts up, I would try squirting starting fluid to see if it fires, if it does then we know its a fuel related problem.
If so, then use noid light to see if the injectors are getting a signal, if not getting a signal I would check the crank sensor. Although your car is running good, there have been instances where the crank sensor wires need to be switched but in every case i've heard of so far, when that has needed to be done it is due to the car never wanting to start or will run really crappy like it is misfiring. Apparently the crank sensors can have reversed polarity which is a manufacturing flaw.
Doug85GT
Total ratings: 128
Report this Post07-18-2008 05:25 PM Click Here to See the Profile for Doug85GTSend a Private Message to Doug85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I found a solution to the water on the front plugs.
Northstar and the Aurora 4.0 V8 engines use a Delphi boot that completely seals the spark plug hole. Since those engine are descendants of the 3.4 DOHC, I grabbed one and walked over to a 3.4 DOHC that I saw in the junk yard. It fit like a glove. It is water tight. So I grabbed 8 of the boots. Pick-n-Pull charged me $5 for them @ $0.50 + tax and Pick-n-Pulls BS fees.
When I got home, I put a set on the front of my engine, then poured 1/2 liter of water over the 3 plug boots. I cleaned up the water, then pulled the boots out. Not a single drop of water got past the boots.
What I did was this:
1. Pulled the old wire out of the boot with needle nose pliers. Part of the insulation will still be in the boot.
2. Cut the boot open on the "short" side of the boot with a mini hack saw. This let me take the rest of the old wire insulation out.
3. I took a wire for my Duke and trimmed the lip off of the top of the boot with a pair of scissors. The stock 2.8 wires should work too. The important thing is the length of the wire and the shape of the spark plug boot.
4. Then I put the Duke wire on the spark plug and measured how deep it was in the whole. I cam up with 3 5/8" deeper into the hole.
5. Then I trimmed the Delphi boot back until there was 3 5/8" of boot that went beyond the seal. Then I slipped it over the wire just above the Duke wire's boot.
6. I pushed the whole thing down onto the spark plug. It make a solid contact and completely sealed.
I have a really crappy camera but I'll see if I can get some pictures later.
[This message has been edited by Doug85GT (edited 07-18-2008).]
olaf_fiero27
Report this Post07-19-2008 11:30 AM Click Here to See the Profile for olaf_fiero27Send a Private Message to olaf_fiero27Edit/Delete MessageReply w/QuoteDirect Link to This Post
Erik, yes I have driven it further than to work and back. I have an aftermarket fuel pressure gauge and it always has fuel pressure when it doesnt want to start. I changed the coils but left the module the same with the same results as before, sometimes it starts right after i shut it off sometimes not, ill check more into it today
Erik
Total ratings: 168
Report this Post07-19-2008 01:42 PM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
Olaf,
Then I would squirt some starting fluid into the intake and see if it starts, if it does then you have most likley have an injector issue. If it doesn't start, do as Doug suggests and check for spark. It could be the module
here is a toruble shooting guide for the ignition ..disregard the camshaft sensor since you are not running one
Erik
Total ratings: 168
Report this Post07-19-2008 01:57 PM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
Erik
Member since Jul 2002
Doug that is a great idea ..it would be nice to not have to cover the front valve cover
[This message has been edited by Erik (edited 07-19-2008).]
fourpoint9
Report this Post07-19-2008 05:55 PM Click Here to See the Profile for fourpoint9Click Here to visit fourpoint9's HomePageSend a Private Message to fourpoint9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like it's the starter heating up. I had the same type of problem.
I replaced the starter and added a Cool-It Thermo Tech Starter Heat Shield Wrap THT 14150
and added a Moroso Standard GM Starter Heatshield MOR-74300
Erik
Total ratings: 168
Report this Post07-19-2008 06:08 PM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
Olafs starter is working ..the engine just doesnt want to start while cranking sometimes due to either no fuel getting to it or something to do with the spark
Erik
Total ratings: 168
Report this Post07-20-2008 03:21 PM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is a difference in harmonic balancers between the early 91-93 manual equipped engines and auto equipped
The one on the left is from a 91 Cutlass Supreme International 5 speed car and the one on the right is off of a 92 auto equipped 3.4 DOHC out of a Grand Prix.
Its thinner and lighter in weight and smaller in diameter
[This message has been edited by Erik (edited 07-20-2008).]
Doug85GT
Total ratings: 128
Report this Post07-20-2008 04:29 PM Click Here to See the Profile for Doug85GTSend a Private Message to Doug85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is good to know. Since my engine is off of an auto car, I guess I will be ordering one from a manual car.
edit:
Bad news. I checked Napa, Autozone and Kragen. Kragen was the only one that had a harmonic balancer and it was a Comp Cams one for $404!
http://www.partsamerica.com...MfrPartNumber=870022
I'll have to check with GM later.
2nd edit:
GM Parts Direct has one but it does not differentiate between auto and manual. It is also $113
http://www.trademotion.com/...1&displayCatalogid=0
[This message has been edited by Doug85GT (edited 07-20-2008).]
Erik
Total ratings: 168
Report this Post07-20-2008 05:43 PM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
edit:
2nd edit:
[URL=http://www.trademotion.com/partlocator/index.cfm?action=getJointLocator&siteid=214858&chapter=&Sectionids=10,0&groupid=10012&subgroupid=62097&componentid=0&make=28&model=Grand%20Prix&year=1992&graphicID=MWP037&callout=32&catalogid=1&displayCatalogid=0 ]http://www.trademotion.com/...1&displayCatalogid=0[/URL]
I doubt that you can get the smaller one nodays unless you get it off a used engine in a junkyard...I am still wondering why they made them different
procarnut
Report this Post07-20-2008 07:45 PM Click Here to See the Profile for procarnutSend a Private Message to procarnutEdit/Delete MessageReply w/QuoteDirect Link to This Post
A torque Converter is heavier than a Clutch, thus more twisting torque on the crank shaft. So you have to have more dampning absorption when you have more dynamic mass to steady. In slow motion, a Crank shaft actually twist due to the power stroke applied along the length of the shaft. The dampner have to absorb the shock/vibration applied to it. The Torque converter just adds to the momentum between fires.
olaf_fiero27
Report this Post07-20-2008 11:10 PM Click Here to See the Profile for olaf_fiero27Send a Private Message to olaf_fiero27Edit/Delete MessageReply w/QuoteDirect Link to This Post
anyone mount there coil packs near the strut tower or in the stock battery location?
Erik
Total ratings: 168
Report this Post07-20-2008 11:25 PM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
funny you should ask that..I have mine mounted on the front of the passenger side strut tower by the C500 connector and I just changed out my whole setup for a newer coilpak/module last night and my car runs better ..I had been having idle issues and some hesitation at times, intermitant stalling and not wanting to start again after shutting off ..I figure it was a module on its way out.
Olaf ..you should be able to unwrap your harness and move the DIS wires without much trouble..I left extra wiring in the circuit in case you decided to
Steven Snyder
Total ratings: 106
Report this Post07-21-2008 12:45 AM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting! That's good to know. So the manual ones must have a different pulley also to account for the smaller offset, correct?
Erik
Total ratings: 168
Report this Post07-21-2008 01:13 AM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
nope, the level of the mounting surface is the same ..just can't see that in the picture so, the pullies are the same
here is a pic from the top
the nice thing about the smaller balancer is that it has less mass which helps the engine to rev faster ..I estimate just from feel that the smaller balancer weighs a couple of pounds less
[This message has been edited by Erik (edited 07-21-2008).]
procarnut
Report this Post07-21-2008 01:16 AM Click Here to See the Profile for procarnutSend a Private Message to procarnutEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just logged in to ad this....I baught a undersize pully on e-bay from a person. Turned out I got the wrong one. 91-93 has a different offset than 94-97. I had to make a pully but used some of the specs to match with. So I'm not sure if it is a manual/Auto specific issue or just a year issue.
Erik
Total ratings: 168
Report this Post07-21-2008 01:19 AM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 96 engine and the pulley is the same as the 91-93
FieroWannaBe
Report this Post07-22-2008 10:26 AM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finally grew some balls and started to tackle the wiring, with some assistance from other members of course. The problem arises that I have a 96 engien running a 95 computer and harness. I have a few plug that dont match up and/or are in different locations.
On the 95 harness, all the intake connectors look like they are on the injector harness, everything but the map sensor could be plugged in. Does the 95 harness even use the map? I have a plug that looks identical to the cam position sensor plug, with different wires, I can find all the pinouts for the c10X connectors though. it is close but no cigar on the fit in the map sensor. I pretty sure its not the cam posistion sensor. The cam position sensor is not on the injector harness, correct?
There is no plug on the harness that looks like it connects to the 96 egr, I assume OBDII has a different style degr valve, i suspect this wierd triangle plug is the 95 degr plug
I have the plug, 3 prong round, coming from the firewall/front side of the harness, no idea what it connects to, nothing fits.
The EVAP thingers, I have one plug that fits for the 96 parts, the 96 has a valve and a flow sensor, does the 95 have the flow sensor becuase i only have a connector for the valve?
Does anyone have the 94-95 pinouts lurking on thier comp, I have the ECM pinouts from Josh's wiring thread, but thats all.
Sorry for the monsterquest worthy photos, cant find my digicam, only have my cellphone
Dont worry, plenty more question to come.
EDIT: pictures would be nice to see.
1986GT 4-speed DOHC and 1987GT Auto
[This message has been edited by FieroWannaBe (edited 07-22-2008).]
FieroWannaBe
Report this Post07-22-2008 05:47 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
FieroWannaBe
Member since Oct 2004
I have a feeling that so called 'map' sensor connector is actually the maf sensor connector isnt it?
I checked with the rockauto catalog and the egr connector is different, but can I re-pin my egr or should i just delete it and make a block off plate?
form the catalog, it appears the two use different map sensors as well, i hop i can use the 96 sensor, problem is I didnt see a plug on my harness depicted like the one in the catalog.
Emc209i
Total ratings: 225
Report this Post07-22-2008 06:02 PM Click Here to See the Profile for Emc209iSend a Private Message to Emc209iEdit/Delete MessageReply w/QuoteDirect Link to This Post
First of all, the 96 motors are equipped with both MAF and MAP. Secondly, the 95 harness only supports MAF.
The first plug is for the Cam sensor, and yes it is supposed to run through the injector mini harness. It does not plug into the map.
The second three prong plug is for the 91-95 EGR, you were right.
The third cable looks like the intake air charge temp. plug, but I could be wrong.
The evap. question: you're right again, the previous year dohcs use a different switch, but the red pronged plug is the correct plug for the older setup. I have no idea whether you use the newer one. The older style did not have a flow sensor.
I have the pinouts, get me your email.
[This message has been edited by Emc209i (edited 07-22-2008).]
Emc209i
Total ratings: 225
Report this Post07-22-2008 06:10 PM Click Here to See the Profile for Emc209iSend a Private Message to Emc209iEdit/Delete MessageReply w/QuoteDirect Link to This Post
Emc209i
Member since Apr 2005
Nope, the MAF sensor is external to the TB, and the connector you pointed out on the intake tube is the MAP. This might help:
Which is better for boost, capped or not? I'd ask Matt and some of the other turbo V6 guys what they've been doing.
FieroWannaBe
Report this Post07-22-2008 06:20 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
it would be awesome to get those pinouts, patond ( a t ) msoe . edu thnaks. thanks for all the info, I hope to get this all sorted out tomorrow so I can finish my wiring mess.
FieroWannaBe
Report this Post07-22-2008 06:22 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
FieroWannaBe
I have the MAF sensor, but it wasnt neer my engine when I was mocking up the wiring, but I did know the sensor was the map, just not the connector, its all a bit confusing right now.
Emc209i
Total ratings: 225
Report this Post07-22-2008 06:25 PM Click Here to See the Profile for Emc209iSend a Private Message to Emc209iEdit/Delete MessageReply w/QuoteDirect Link to This Post
lol, I feel ya. You'll get it. I sent the pintouts.
FieroWannaBe
Report this Post07-22-2008 06:27 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
so the first plug running through the injector harness is the cam position sensor, then the identical plug on the main harness is MAF, correct?
I'm still lost on the ghost three prong plug. It looks identical to the IAC plug, or identical to the TPS plug; one of the two. I don't remember right now. The plug is on the Main engine harness. Its not the IAT sensor, I have that on all set up and plugged in at the moment.
Does the 94-95 set up use two knock sensors? I have two sensors, with different plugs than my 95 harness has, and it has only one, plug on it, hould it have 2? I also hope these sensors are compatible.
Emc209i
Total ratings: 225
Report this Post07-22-2008 06:30 PM Click Here to See the Profile for Emc209iSend a Private Message to Emc209iEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, the plug will be for MAF not MAP. The OBD 1.5 only uses a single O2.
Let me go see if I can find out where that ghost plug goes.
Emc209i
Total ratings: 225
Report this Post07-22-2008 06:37 PM Click Here to See the Profile for Emc209iSend a Private Message to Emc209iEdit/Delete MessageReply w/QuoteDirect Link to This Post
Emc209i
Yeah I was right. There are two like that. One's IAC and the other is for the intake charge temp.
Emc209i
Total ratings: 225
Report this Post07-22-2008 06:41 PM Click Here to See the Profile for Emc209iSend a Private Message to Emc209iEdit/Delete MessageReply w/QuoteDirect Link to This Post
Emc209i
DAVID... OHHHHHH. I'm talking to David. I thought you were Jeff, don't ask why. I didn't even catch Paton. Ok. About the egr then, cap it and disable it on the chip. Making the newer style valve work will be a pain, as is the old one. Kill it.
FieroWannaBe
Report this Post07-22-2008 06:48 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
weird with the IAT, Im going to have to check again tomorrow to see, right now I have 3 sensors that are identical. or I unplugged the sensor and forgot.
FieroWannaBe
Report this Post07-22-2008 06:49 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
FieroWannaBe
on o2, thats good, but what about knock?
