  What Did You Do To Your Fiero...TODAY ? (Page 108)
This topic is 174 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79   80   81   82   83   84   85   86   87   88   89   90   91   92   93   94   95   96   97   98   99   100   101   102   103   104   105   106   107   108   109   110   111   112   113   114   115   116   117   118   119   120   121   122   123   124   125   126   127   128   129   130   131   132   133   134   135   136   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162   163   164   165   166   167   168   169   170   171   172   173   174
What Did You Do To Your Fiero...TODAY ? by cliffw
Started on: 08-27-2007 12:27 PM
Replies: 6930 (219389 views)
Last post by: Stingray92 on 04-19-2025 08:37 PM
PA-Joker
Report this Post09-13-2011 12:42 PM Click Here to See the Profile for PA-JokerSend a Private Message to PA-JokerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Played around with the radio...Found out I've had an aux setting this entire time. Finally hooked it up and took 'er for a spin!
Y_B_A_FOOL
Report this Post09-13-2011 12:56 PM Click Here to See the Profile for Y_B_A_FOOLSend a Private Message to Y_B_A_FOOLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well It wasn't today. But I bought a 0 mile rebuilt 2.8 motor, I think it is actually a 3.1 for $100. It seems to have a steel gaskets, the whole motor has been polished, it looks like it has forged pistons, the crank has been lightened and had metal added in places, and it has a crane cam, and hasa double timing chain. I am going to post photos but they were too high of a quality. Aparently the machine shop moved an still has the blue prints for it, somewhere. I am going to talk to them this week. I am so stoked about it though
NCTyphoonKid
Report this Post09-13-2011 01:07 PM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
put a axle seal in it since the one in it was leaking bad so after going through three seals I finally got it.
Jim_Martin29
Report this Post09-13-2011 04:04 PM Click Here to See the Profile for Jim_Martin29Send a Private Message to Jim_Martin29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by miketria:
attempted to use adhesive to keep the headliner from sagging.
Been there, a couple of time, never worked. The adhesive holds but the foam on the overhead that it is glued to fails. Once it starts falling it's time to replace it.
Jim Martin
White '86 GT
Monterey, California
Jim_Martin29
Report this Post09-13-2011 04:12 PM Click Here to See the Profile for Jim_Martin29Send a Private Message to Jim_Martin29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Jim_Martin29
Member since Jun 2010
That's my task for this coming weekend. I bought three seals, just in case, I hope I only bugger up one of them because I would like to change both.
I wanted to do it the weekend before last but I didn't bother to order a 30 mm socket so I can get the axle nut off. I figured that I could find one locally. Well, as it turns out no one in the area had a 30 mm socket, let alone a impact rated socket. So I had to order one from Rodney and he even stocks the impact rated socket.
Thanks Rodney for supporting us. I don't know what we would do without you!
Jim Martin
White '86 GT
NCTyphoonKid
Report this Post09-13-2011 05:04 PM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
It wasnt too bad I went through three of those seals. Third time was the charm thank god haha no more leaks
Jim_Martin29
Report this Post09-13-2011 05:07 PM Click Here to See the Profile for Jim_Martin29Send a Private Message to Jim_Martin29Edit/Delete MessageReply w/QuoteDirect Link to This Post
What did you use to drive the seals home?
I don't have a socket or anything the correct size so I went to Home Depot and got some PVC pipe and connectors that look to be the correct size. I guess I will see this weekend.
NCTyphoonKid
Report this Post09-13-2011 08:44 PM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used a 4x4 block of wood worked pretty well
Robert 2
Report this Post09-13-2011 09:13 PM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney sell a special tool for it too .
repnblvd
Report this Post09-14-2011 02:51 AM Click Here to See the Profile for repnblvdSend a Private Message to repnblvdEdit/Delete MessageReply w/QuoteDirect Link to This Post
I buffed the fender on my newest '86 GT. back to black... figured out, thanks to the forum, why my fuse kept popping to my courtesy light on my other '86 GT, damn trunk light grounding out. ha. check out the build... https://www.fiero.nl/forum/Forum1/HTML/086542.html
FieroMaster88
Total ratings: 168
Report this Post09-14-2011 09:37 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Installed my new shift boot and parking brake boot. Maybe I'll drive it to work tomorrow. Oh, and I'm buying an Indy Fiero.
pontiackid86
Total ratings: 344
Report this Post09-14-2011 09:45 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fixed the shifter cable alignment and drove it
Charlie64
Report this Post09-14-2011 10:25 PM Click Here to See the Profile for Charlie64Send a Private Message to Charlie64Edit/Delete MessageReply w/QuoteDirect Link to This Post
Installed my new Lloyd Mats
Admiring the shine....
and absolutely enjoying all the attention I've been getting in my car.
Totally OWNED a 370Z a few nights ago...since I was putting out more at the wheels than he had at the crank.
Ratfink
Report this Post09-15-2011 12:26 AM Click Here to See the Profile for RatfinkSend a Private Message to RatfinkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Walked right by it!
pontiackid86
Total ratings: 344
Report this Post09-15-2011 01:12 AM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Ratfink:
Walked right by it!
Lol did that to 2 of them today.
ULTRA-kV6
Report this Post09-15-2011 01:24 PM Click Here to See the Profile for ULTRA-kV6Send a Private Message to ULTRA-kV6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Started building "the ultimate center console/subwoofer enclosure". It'll be my 3rd one. I've never liked the "split" look of the console between the shifter surround & the arm rest/glovebox section. I also have never liked that the only choices we as Fiero owners have had as far as a sub console, are those that expose the sub. It's a good look for some, but i like my things "stealthy", so i'm building a box that will recess my 8" RF sub back about 1/2" with a finished grill over it. Ya won't even know it's in there.
falcon_ca
Report this Post09-15-2011 09:02 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
Started to work on the future gauges cluster
"I'm not driving too fast, . . . I'm just flying too low."
Work done 07-08 | Work done 08-09 | Work done 09-10 | Work done 10-11 |Work done 11-12 |
4.9 ongoing project |Parts for sale
Total ratings: 461
Report this Post09-16-2011 01:03 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pried my backing plate away from the rotor. (Got bent the other day when I had an axle boot replaced. made a gawdawful racket.)
Tried the Allante tune. It runs okay but some of the external inputs are different. (Power steering and brake inputs are different.)
Since I didn't have time to get it sorted before RFTH, I plugged the modded Deville tune back in. That's what I'd been running anyway.
Brucepts
Report this Post09-17-2011 09:23 AM Click Here to See the Profile for BruceptsClick Here to visit Brucepts's HomePageSend a Private Message to BruceptsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spent Friday afternoon digging through Skitime's left over Fiero parts that he is liquidating, so weird walking into his garage and not seeing his car sitting there!
He's moving on to other things and starting to enjoy his retirement. He showed me a project he is playing with, putting a Supercharger on his Tracker.
"There is no more formidable adversary than one who perceives he has nothing to lose." - Gen. George S. Patton
http://www.flowbenchtech.com
IFLYR22
Report this Post09-17-2011 09:20 PM Click Here to See the Profile for IFLYR22Send a Private Message to IFLYR22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Discovered the noise up front is the upper control arm mount on the front cross member of mine sheared itself from the cross member... new crossmember on order.
-Dave
dmcgreene
Report this Post09-18-2011 01:52 PM Click Here to See the Profile for dmcgreeneSend a Private Message to dmcgreeneEdit/Delete MessageReply w/QuoteDirect Link to This Post
received my rodney dickman idler pulley for Flyboy81 to install thursday
Old Lar
Total ratings: 214
Report this Post09-20-2011 12:22 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Having the axels replaced in my 88 GT. I wondered what that noise was. EGR valve works, but no vacuum get to it, so code 32. Also I'm having the battery box replaced. It is only money.
1986GTV8
Report this Post09-20-2011 06:01 PM Click Here to See the Profile for 1986GTV8Send a Private Message to 1986GTV8Edit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.youtube.com/watch?v=1yHl_vijrB0 Trying to get the V8 to run.
katatak
Total ratings: 82
Report this Post09-21-2011 01:46 AM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Showed to a few perspective buyers!
engine man
Report this Post09-21-2011 02:32 AM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
front brake calipers put new ones on got sick of fighting the sticking
balejumper
Report this Post09-21-2011 03:27 PM Click Here to See the Profile for balejumperSend a Private Message to balejumperEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fixing my exhaust leak on my 86 SE. Found out it was 2 broken bolts in the head on the FRONT manifold , removed the dogbone mount, and pulled the engine back toward the trunk 2 inches for a little more room, removed the A/C compressor and brackets, removed the manifold. Drilled out the two broken studs, retapped all 6 holes, got new gaskets, and now am going back out to install the parts and hope it's much quieter. Here's where a 2.5 would make this whole job easier, but the extra 2 cylinders are worth it.
FieroMaster88
Total ratings: 168
Report this Post09-21-2011 04:44 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got my Rodney Dickman lowering ball joints and my Fierostore front lowering springs for the 88. Finally going to get those cut springs out of there and have a smoother ride.
I also got everything set up for the Indy I purchased to be delivered on Saturday. I can't wait!
88 Coupe: 2.0L Turbo 4 Cylinder
84 Indy #64: Restoration Project!
katatak
Total ratings: 82
Report this Post09-21-2011 11:40 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sold it! Areva Derci Fiero!
rourke_87_T-Top
Report this Post09-22-2011 01:41 PM Click Here to See the Profile for rourke_87_T-TopSend a Private Message to rourke_87_T-TopEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Fiero Tom:
Got em installed yet ? Looking for a new wheels for my Formula.
I finally bought tires for these wheels, BFG G-Force Super Sport A/S, Fronts 205/40/17 Rears 225/45/17. I'll have them installed and upload a pic next week.
balejumper
Report this Post09-22-2011 01:47 PM Click Here to See the Profile for balejumperSend a Private Message to balejumperEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put my 86 SE out for sale, ordered an inner tierod end for the Formula, approved vent designs for my 84 V8 car, contemplating selling my 85 GT as a parts car (I may use the rear bumper and decklid for my V8 car). Other than that, not much.
Ruffy
Report this Post09-24-2011 04:15 PM Click Here to See the Profile for RuffySend a Private Message to RuffyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will start off with yesterday being it took two days.
Went out at 3am to start my car for work and didn't start so I had to call off work. The key would turn and no buzz sound for the fuel pump. So what I did was go into my garage where I have another fiero and dropped the tank to get the pump out of it because the pump was almost new but motor bad. Then I dropped the tank of my daily driver to do the switch. I did and still nothing. That took a day trying to find out what was going on.
next day I went straight from work to get one and also pick up the accel super coil for my 4.9. Hey more power never hurt. I got back home and plugged in the new pump and still nothing! I almost lost all hope till I seen a relay that I couldn't keep my eye off. My build is a 4.9 LT with a Ford computer and injection. That relay was a fuel pump relay I found after typing in the item number on Google. The pump kicked right on yay! Plus I now have a new cap,rotor, and accel super coil
Khw
Total ratings: 134
Report this Post09-24-2011 05:19 PM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today I tested my paint gun on one fender to try to get the feel for it again (been over 5 years since I sprayed). I also wanted to see how much I'd ned to thin the paint to get it to flow right. Overall it looks pretty good, but that fender will be sanded down and resprayed. Tomorrow I plan to start shooting the color below the beltline. This will be a several weekend job as my painting space is cramped, but I'm finally getting to the paint . Oh, and I learned I can still control the gun, but my paint consistency judgement was a little off. The paint I sprayed needed to be thinned out just a little more.
[This message has been edited by Khw (edited 09-24-2011).]
Fiero88GT
Report this Post09-24-2011 08:30 PM Click Here to See the Profile for Fiero88GTSend a Private Message to Fiero88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
tried out a different wax on it
balejumper
Report this Post09-24-2011 10:51 PM Click Here to See the Profile for balejumperSend a Private Message to balejumperEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drove to Milwaukee with my Formula. Drove it in the rain for the first time. 480 miles round trip no problems, except check engine light came on - EGR code, no big deal. Headed to Minneapolis next weekend for a small get together at the Mall of America.
balejumper
Report this Post09-24-2011 10:54 PM Click Here to See the Profile for balejumperSend a Private Message to balejumperEdit/Delete MessageReply w/QuoteDirect Link to This Post
balejumper
Member since Jul 2011
While I was in Milwaukee I saw a Ferarri, that I am guessing was a kit car, but not positive. Is there anyone in the Delafield area with a Ferarri kit on their Fiero? It looked perfect, just wondering.
Godzilla
Report this Post09-24-2011 11:48 PM Click Here to See the Profile for GodzillaSend a Private Message to GodzillaEdit/Delete MessageReply w/QuoteDirect Link to This Post
was the sole fiero at the madison classics fall jeferson show today
lrn2internet
'86 SE v6
buger
Report this Post09-24-2011 11:52 PM Click Here to See the Profile for bugerClick Here to visit buger's HomePageSend a Private Message to bugerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has any one used a clay bar on their Fiero?
Godzilla
Report this Post09-24-2011 11:57 PM Click Here to See the Profile for GodzillaSend a Private Message to GodzillaEdit/Delete MessageReply w/QuoteDirect Link to This Post
no, but i did on my truck. worked freeking awsome.
katatak
Total ratings: 82
Report this Post09-25-2011 01:10 AM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got it ready to deliver to the new owner tomorrow - I'll get to take her for one last road trip! Going to be a sad trip!
Tinkrr
Report this Post09-25-2011 01:30 PM Click Here to See the Profile for TinkrrSend a Private Message to TinkrrEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have used Meguiar's clay bar kit on my fiero and am very pleased with the result.
I was given a few samples of Meguiar's gold Class liquid wax in my goody bag at the GTA Fiero Show. I was impressed with the product.
Before doing the Clay bar cleaning I went to Meguuiar's web site and got their recommendations for restoring my Fiero's origonal paint.
I did the clay bar cleaning, utilized the cleaner wax, and finished with their Gold Class Paste wax.
Before Clay Baring, the wing especially, felt like sand paper to the back of my fingers and smooth as glass after the treatment, not to mention a deep, highly lustrous shine.
[This message has been edited by Tinkrr (edited 09-25-2011).]
